Ubuntu Graphics Acceleration
Hi,
I am running Firefly-rk3288_Ubuntu_1604_ 2016_1018 and I found that the graphics is very slow. When I run the browser, scrolling is noticeably lagging. When I run glxgears, the FPS is about 72-82 FPS.
Can I know if GPU acceleration is working under Ubuntu for 3288?
With 2D acelaration you justa have Debian.
Firefly Post: http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=1793&highlight=debian
Latest from ROCKCHIP: http://rockchip.wikidot.com/debian
we don’t have any Linux disto in ARM rk3288 with graphics working well
Hi,
Does it mean that Ubuntu support for graphics is still very poor? And I should use Debian?
Yes ubuntu just have 3D graphics. Not have 2D so interface is totally lag. Try debian and test it. Have a lot of bugs too. Firefly have no OS working perfect… even android released by firefly team not work very well. Have some micro stutters in video playback. I’m trying create one webserver with my box, … but try Debian!
That is really sad to hear. From the website, it seems that the “powerful GPU”. I guess the “hardware” is powerful, but honestly, what is the point of a super powerful hardware without supporting software / OS? I will try out Debian… if that still doesn’t work, I might have to return it.
Yes it have powerfull graphics but no support. If you want small device for ubuntu do not buy ARM devices. This will not work 2D graphics and will have a lot of bugs and limitations. Buy other box for this propose.
Cheers
Thanks for the advice. I do need good 2D graphics as I using it for digital signage. Do you have any recommendations for similar hardware?
kfchoong Posted at 3/12/2017 22:38
Thanks for the advice. I do need good 2D graphics as I using it for digital signage. Do you have any …
id recommend hard kernel’s odroid boards. they have very decent performance with both cpu+gpu, decent priced and very well supported software wise so there shouldn’t be any real issues with 2d/3d acceleration, at least none I’ve noticed on my boards. the other bonus is that they have a very active forum that should help you out should you have any issues etc that you need help/advice with in relation to their products
http://www.hardkernel.com/main/main.php
Yes, but i have one Odroid ux4 and 2D graphics are not working 100% too. The most perfect OS is:
http://dev.odroid.com/viewtopic.php?f=96&t=26172
Very very hardwork inside!
not sure what issues you have with the xu4, but I’ve got an xu3 and C1 that both seem to run 2D/3D fine, so unless I’m not aware of something (and thats quite possible) then any of those boards should do what he needs to do without to much hassle. the main thing to point out is that Hardkernel have a very active forum community as well as a monthly magazine s there is decent support. the same cannot be said about firefly.
the other option he has would be to get a small x86 dev board that uses an atom of similar low spec cpu, these will outperform most arm boards that are available however the downside is that an x86 board is going to cost way more.
Thanks. May I know if the Odroid performs better with 2D graphics than the Firefly board? From the video, looks like it doesn’t have any problem doing hardware decoding of videos.
Hi AussieJohn.
I’m very interesting to install CentOS in one Low power consuming for WEBhost propose. You know some good Board for this??
Best Regards
i use my odroid xu4 for a variety of uses and so far video playback has been very good, no noticable stutters or anything like that, runs emulators etc pretty decent too.
now i haven’t done any direct comparisons between the XU4 and firefly, on paper the firefly has a better graphics core however without the support of decent drivers the odroid XU4 will outperform it currently. this will change should the firefly get real gfx driver support in the future. still the XU4 right now should do what you want, its fast, uses the big.Little cpu core structure for optimum power usage and has usb3 x2 as well as upgradable emmc flash modules. it uses the same cpu as the Samsung galaxy note 3 (if memory serves correct)
AussieJohn Posted at 4/28/2017 09:59
i use my odroid xu4 for a variety of uses and so far video playback has been very good, no noticable …
Thanks for the info. It is very helpful. Let me try out XU4.
Itcertkr 에서 출시한ECCouncil인증212-82 덤프는ECCouncil인증212-82 실제시험의 출제범위와 출제유형을 대비하여 제작된 최신버전 덤프입니다. 시험문제가 바뀌면 제일 빠른 시일내에 덤프를 업데이트 하도록 최선을 다하고 있으며 1년 무료 업데이트서비스를 제공해드립니다. 1년 무료 업데이트서비스를 제공해드리기에 시험시간을 늦추어도 시험성적에 아무런 페를 끼치지 않습니다. Itcertkr에 믿음을 느낄수 있도록 구매사이트마다 무료샘플 다운가능기능을 설치하였습니다.무료샘플을 체험해보시고Itcertkr을 선택해주세요.
人生は自転車に乗ると似ていて、やめない限り、倒れないから。IT技術職員として、周りの人はGoogle Professional-Cloud-Security-Engineer試験に合格し高い月給を持って、上司からご格別の愛護を賜り更なるジョブプロモーションを期待されますけど、あんたはこういうように所有したいますか。変化を期待したいあなたにGoogle Professional-Cloud-Security-Engineer試験備考資料を提供する権威性のあるIt-Passportsをお勧めさせていただけませんか。
Your article is awe-inducing, I’m grateful for your sharing! Pdf JN0-460 exam dump provides helpful, in-depth content, offered free for your academic needs.
