in gl2mark2 it has lower results than MIQI rk3288 board with 4.11 kernel
for example terrain on miqi 20fps and on rk3399 only 13 fps.
and now it lacks of vsync.
If you want get the score of the GPU performance. you need use the command “glmark2-es2 --off-screen”
because the limitation is the X11 driver. not the mali GPU.
So if you’ll upgrade kernel to 4.11 with this guy patches https://github.com/Miouyouyou/MyyQi
you’ve got higher results + VSYNC
–off-screen is not intrested because everyone wants to have fast desktop for everyday usage.
I notice you mentioned video acceleration in the title. Is there any support for hardware h.264 encoding or decoding yet on the command line, with e.g. ffmpeg?
Is Lunix still supported for Firefly-RK3399? I bought it for Linux because the documentation mentions dual boot, but it only boots into android. The closest resource I found was http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=1921
I downloaded the files below, but no instructions for SD install. without that the board is useless to me.
Firefly-rk3399_xubuntu1604_201703241137_Beta.7z
Firefly-rk3399_xubuntu1604_201704100952_Beta.7z
Also the information is more than 6 months old with no resolution. Please help.
Thank you for sharing your article, it was a real eye-opener. I’m sharing the PCA valid practice questions questions that helped me achieve my promotion and raise—get them for free today!
PassTIP 의 SAP인증 C-TS452-2022시험에 도전장을 던지셨나요? 현황에 만족하지 않고 열심히 하는 모습에 박수를 보내드립니다. SAP인증 C-TS452-2022시험을 학원등록하지 않고 많은 공부자료 필요없이PassTIP 에서 제공해드리는 SAP인증 C-TS452-2022덤프만으로도 가능합니다. 수많은 분들이 검증한SAP인증 C-TS452-2022덤프는 시장에서 가장 최신버전입니다.가격도 친근하구요.
Your article has truly left me speechless, thank you for sharing! Improve your IT abilities with free Plat-Arch-206 certification test questions. Wishing you success!
I was amazed at how much I benefited from reading it. This is the SC-900 exam experience exam that helped me get ahead with a promotion and pay raise. It’s free for everyone today. Wishing you all career success!
