Hi everyone,
I just build Lollipop with date: 2017-02-22, when i open camera, it show "Insert an SD card …"then i can’t change parameters or camera/video mode.
Can you give me how to fix it?
Thanks
Hi everyone,
Thanks
Hi ,does the latest official firmware have the same issue?
Hi isle, that’s exactly lastest firmware.
No , I mean the firmware you download from the baidupan or google driver.
not the firmware you made by yourself.
Hi isle,
Source is firefly-rk3288_android5.1_git_20170224.tar.gz then i builded by myseft.
Hi all,
I found that it’s not camera problem. There are error in Lollipop system: it can not access any kind memory.
Who can show me fix it?
Thanks
Hi ,
so ,you mean ,when use the official firmware ,there is no such issue.
But when you build a firmware by the source code, It has.
have you add something in your source code?
Hi, isle
No, i build source code without any modification.I chose kernel for normal or Reload also have same storage issue.
Hi
my colleague has just checked . build the source code with no modification have no such issue.
Could you please show us your kernel log?
Hi isle,
How to get kernal log?
Thanks.
Hi isle,
This is Kernel Log i get by mLogcat.
<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (haihoa@haihoa-Precision-Tower-3620) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Thu May 11 09:44:09 ICT 2017
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<6>[ 0.000000] hdmi init vic is -1
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(drm): base(0) size(0) align(0)
<6>[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
<6>[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<4>[ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0d73e00, node_mem_map c0e9d000
<7>[ 0.000000] Normal zone: 1520 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 194560 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 2576 pages used for memmap
<7>[ 0.000000] HighMem zone: 329728 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ef9000 s13376 r8192 d15296 u36864
<7>[ 0.000000] pcpu-alloc: s13376 r8192 d15296 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
<5>[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-11-26_09:28:44 hdmi.vic=-1
<6>[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 2026180k/2026180k available, 70972k reserved, 1302528K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0b8e454 (11802 kB)
<5>[ 0.000000] .init : 0xc0b8f000 - 0xc0be8440 ( 358 kB)
<5>[ 0.000000] .data : 0xc0bea000 - 0xc0d7b440 (1606 kB)
<5>[ 0.000000] .bss : 0xc0d7b440 - 0xc0e9c77c (1157 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start!
<3>[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
<3>[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 29
<4>[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 3
<6>[ 0.000000] channel:0, lkg:17
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:15
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.447926] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.447942] pid_max: default: 32768 minimum: 301
<6>[ 0.448059] Security Framework initialized
<6>[ 0.448075] SELinux: Initializing.
<7>[ 0.448110] SELinux: Starting in permissive mode
<6>[ 0.448149] Mount-cache hash table entries: 512
<6>[ 0.448789] Initializing cgroup subsys debug
<6>[ 0.448804] Initializing cgroup subsys memory
<6>[ 0.448830] Initializing cgroup subsys freezer
<6>[ 0.448860] CPU: Testing write buffer coherency: ok
<3>[ 0.449174] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.449188] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.449198] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.449207] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.449256] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.449306] Setting up static identity map for 0xc08502f8 - 0xc0850350
<6>[ 0.452455] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1763 (version 3.1)
<4>[ 0.526082] CPU1: Booted secondary processor
<6>[ 0.526115] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.545755] CPU2: Booted secondary processor
<6>[ 0.545779] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.565464] CPU3: Booted secondary processor
<6>[ 0.565487] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.565589] Brought up 4 CPUs
<6>[ 0.565618] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.565627] CPU: All CPU(s) started in SVC mode.
<6>[ 0.566362] devtmpfs: initialized
<6>[ 0.570549] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<6>[ 0.571638] pinctrl core: initialized pinctrl subsystem
<6>[ 0.571890] regulator-dummy: no parameters
<6>[ 0.585618] NET: Registered protocol family 16
<6>[ 0.587371] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.587690] ion_snapshot: 0x2e1b8000 map to 0xf0107000 and copy to 0xc0e77a4c (version 0.1)
<6>[ 0.587924] Registered FIQ tty driver
<3>[ 0.588329] fiq-debugger is disabled in device tree
<4>[ 0.588952] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.588982] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.588999] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.589015] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.589108] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.589172] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.589233] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.589295] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.589356] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.589417] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.589477] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.589538] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.589605] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.589668] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.589682] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.589693] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.589704] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.589785] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.589841] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.589901] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.589961] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.590016] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.590069] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.590123] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.590183] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.590238] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.590293] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.590327] rockchip_interrupts_register:bank_num=7
<7>[ 0.592203] of_get_named_gpio_flags exited with status 136
<4>[ 0.592215] of_get_gpio_init_config:gpio[0] = 136, value = 0
<4>[ 0.592272] rockchip_pinctrl_probe:init ok
<6>[ 0.599134] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.599222] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.599235] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.599409] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.599480] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.599492] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.599653] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.599724] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.599736] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.599903] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.599973] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.599986] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.600160] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.600234] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.600246] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.600416] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.600488] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.600500] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.600670] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.600746] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.600759] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.602448] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.602460] hw-breakpoint: maximum watchpoint size is 4 bytes.
<3>[ 0.603044] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
<4>[ 0.603065] DDR DEBUG: version 1.00 20150126
<4>[ 0.603093] DDR DEBUG: Channel a:
<4>[ 0.603102] DDR DEBUG: DDR3 Device
<4>[ 0.603115] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.603124] DDR DEBUG: Channel b:
<4>[ 0.603131] DDR DEBUG: DDR3 Device
<4>[ 0.603144] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.603153] DDR DEBUG: addr=0xd85000
<4>[ 0.603162] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.603171] DDR DEBUG: socAddr[0]=0xd85000, socAddr[1]=0xd85100
<4>[ 0.603181] DDR DEBUG: chAddr[0]=0xd85000, chAddr[1]=0xd85000
<4>[ 0.603192] DDR DEBUG: dtar[0]=0x501b0000, dtar[1]=0x501b0000
<4>[ 0.603246] DDR DEBUG: init success!!! freq=200MHz
<4>[ 0.603254] DDR DEBUG: Channel a:
<4>[ 0.603266] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.603279] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.603291] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.603304] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.603316] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.603325] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.603334] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.603342] DDR DEBUG: Channel b:
<4>[ 0.603353] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.603365] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.603378] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.603390] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.603401] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.603410] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.603418] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.628225] bio: create slab at 0
<6>[ 0.628719] Rockchip hdmi driver version 2.0
<6>[ 0.628719] .
<5>[ 0.629858] SCSI subsystem initialized
<6>[ 0.630018] usbcore: registered new interface driver usbfs
<6>[ 0.630062] usbcore: registered new interface driver hub
<6>[ 0.630149] usbcore: registered new device driver usb
<7>[ 0.630391] of_get_named_gpio_flags exited with status 14
<7>[ 0.630430] of_get_named_gpio_flags exited with status 12
<7>[ 0.631481] of_get_named_gpio_flags exited with status 15
<7>[ 0.631501] of_get_named_gpio_flags exited with status 16
<6>[ 0.632791] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.632905] of_get_named_gpio_flags exited with status 260
<7>[ 0.632924] of_get_named_gpio_flags exited with status 261
<6>[ 0.633436] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.633539] of_get_named_gpio_flags exited with status 201
<7>[ 0.633557] of_get_named_gpio_flags exited with status 202
<6>[ 0.633885] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.633981] of_get_named_gpio_flags exited with status 81
<7>[ 0.633999] of_get_named_gpio_flags exited with status 80
<6>[ 0.634172] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.634274] of_get_named_gpio_flags exited with status 241
<7>[ 0.634293] of_get_named_gpio_flags exited with status 242
<6>[ 0.634629] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.634754] media: Linux media interface: v0.10
<6>[ 0.634797] Linux video capture interface: v2.00
<6>[ 0.634852] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.634862] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.634883] PTP clock support registered
<4>[ 0.634941] i2c-core: driver [bq24296] using legacy suspend method
<4>[ 0.634951] i2c-core: driver [bq24296] using legacy resume method
<4>[ 0.635638] ion_drm_heap_create: 0@0
<6>[ 0.635767] Rockchip ion module is successfully loaded (v1.1)
<6>[ 0.635925] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.636330] Bluetooth: Core ver 2.16
<6>[ 0.636386] NET: Registered protocol family 31
<6>[ 0.636396] Bluetooth: HCI device and connection manager initialized
<6>[ 0.636412] Bluetooth: HCI socket layer initialized
<6>[ 0.636426] Bluetooth: L2CAP socket layer initialized
<6>[ 0.636452] Bluetooth: SCO socket layer initialized
<6>[ 0.636689] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.637385] act8846_i2c_probe,line=898
<4>[ 0.638359] act8846_parse_dt,line=746
<7>[ 0.638767] of_get_named_gpio_flags exited with status 238
<7>[ 0.638780] of_get_named_gpio_flags exited with status 6
<7>[ 0.638792] of_get_named_gpio_flags exited with status 234
<7>[ 0.638804] of_get_named_gpio_flags exited with status 259
<4>[ 0.638827] act8846_i2c_probe: act8846_pmic_hold=1
<4>[ 0.638849] act8846_i2c_probe: act8846_pmic_sleep=1
<4>[ 0.638864] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
<4>[ 0.638879] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
<6>[ 0.640953] act_dcdc1: 1200 mV
<6>[ 0.643908] vccio: 3300 mV
<6>[ 0.645769] vdd_logic: 700 ↔ 1500 mV at 1125 mV
<6>[ 0.648738] act_dcdc4: 2000 mV
<6>[ 0.649983] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.652289] act_ldo2: 1050 mV
<6>[ 0.654586] act_ldo3: 3300 mV
<6>[ 0.656891] act_ldo4: 3300 mV
<6>[ 0.659186] act_ldo5: 3300 mV
<6>[ 0.661512] act_ldo6: 1100 mV
<6>[ 0.663808] vcc_18: 1800 mV
<6>[ 0.666110] act_ldo8: 1850 mV
<6>[ 0.670849] vdd_arm: 712 ↔ 1500 mV at 1100 mV
<6>[ 0.675540] vdd_gpu: 712 ↔ 1500 mV at 900 mV
<4>[ 0.676293] rk808_i2c_probe,line=1355
<4>[ 0.677627] The device is not rk808 -11
<4>[ 0.677712] rk808: probe of 0-001b failed with error -11
<4>[ 0.677784] i2c-core: driver [rk818] using legacy suspend method
<4>[ 0.677795] i2c-core: driver [rk818] using legacy resume method
<6>[ 0.679464] Switching to clocksource arch_sys_counter
<6>[ 0.703114] rga: Module initialized.
<6>[ 0.703818] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.703990] rga: Driver loaded succesfully
<6>[ 0.704189] fb disp policy is box
<7>[ 0.704200] uboot-logo-on:0
<6>[ 0.704232] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.704244] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.704572] rk-screen rk_screen.8: rockchip screen probe success
<6>[ 0.704803] rk32-lvds rk32-lvds: rk32 lvds driver probe success
<3>[ 0.705167] rk32-edp ff970000.edp: screen is not edp!
<4>[ 0.705187] rk32-edp: probe of ff970000.edp failed with error -22
<3>[ 0.705650] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
<6>[ 0.705867] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.706172] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.706340] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.706507] graphics fb3: rockchip framebuffer registerd:fb3
<3>[ 0.707280] vop ver:3007236,unsupport output color:1
<6>[ 0.707418] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
<6>[ 0.707444] rk3288-lcdc lcdc0: wakeup from standby!
<4>[ 0.731273] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 0.740425] alloc_buffer:ion_phy_addr=0x10000000
<6>[ 0.753011] fb0:phy:10000000>>vir:f0191000>>len:0x1800000
<6>[ 0.753041] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x2e2a5000
<6>[ 0.753057] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
<3>[ 0.753276] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
<4>[ 0.753289] rk_fb_trsm_ops_get:un supported transmitter:0!
<6>[ 0.753570] graphics fb4: rockchip framebuffer registerd:fb4
<6>[ 0.753912] graphics fb5: rockchip framebuffer registerd:fb5
<6>[ 0.754078] graphics fb6: rockchip framebuffer registerd:fb6
<6>[ 0.754247] graphics fb7: rockchip framebuffer registerd:fb7
<6>[ 0.755005] unknow screen type: 0
<3>[ 0.755020] vop ver:3007236,unsupport output color:1
<6>[ 0.755082] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:60
<6>[ 0.755095] rk3288-lcdc lcdc1: wakeup from standby!
<6>[ 0.758837] fb4:phy:10000000>>vir:f0191000>>len:0x1800000
<6>[ 0.758853] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
<4>[ 0.759692] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.759822] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.759942] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.760063] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.760173] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.760292] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.760867] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.761023] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.761563] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.761714] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.762254] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.762400] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.762935] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.763080] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.764165] tc358749_hdmiin_probe!
<7>[ 0.764188] of_get_named_gpio_flags exited with status 245
<7>[ 0.764217] of_get_named_gpio_flags exited with status 229
<7>[ 0.764236] of_get_named_gpio_flags exited with status 264
<7>[ 0.764254] of_get_named_gpio_flags exited with status 265
<6>[ 0.764360] tc358749_hdmiin_probe OK!
<6>[ 0.764809] NET: Registered protocol family 2
<6>[ 0.765477] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
<6>[ 0.765610] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
<6>[ 0.765745] TCP: Hash tables configured (established 8192 bind 8192)
<6>[ 0.765797] TCP: reno registered
<6>[ 0.765813] UDP hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 0.765849] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 0.766052] NET: Registered protocol family 1
<6>[ 0.766655] Unpacking initramfs…
<6>[ 0.836768] Freeing initrd memory: 1304K (c4bf0000 - c4d36000)
<6>[ 0.837541] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.838147] vcodec_service: probe device ff9a0000.vpu_service
<4>[ 0.838349] vcodec_service: No reset resource define
<6>[ 0.838522] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 0.838609] vcodec_service: probe device ff9a0000.vpu_service
<6>[ 0.838624] vcodec_service: checking hw id 4831
<6>[ 0.839608] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 0.839650] vcodec_service: done
<6>[ 0.839659] vcodec_service: init success
<6>[ 0.839721] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.840059] vcodec_service: ff9c0000.hevc_service: power on
<6>[ 0.840120] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.840134] vcodec_service: checking hw id 6867
<6>[ 0.840690] vcodec_service: ff9c0000.hevc_service: power off…
<6>[ 0.840731] vcodec_service: done
<6>[ 0.840740] vcodec_service: init success
<4>[ 0.840878] rknandbase v1.0 2014-03-31
<4>[ 0.841018] rknand: probe of ff400000.nandc failed with error -1
<4>[ 0.841127] rknand_driver:ret = 0
<6>[ 0.842293] audit: initializing netlink socket (disabled)
<5>[ 0.842336] type=2000 audit(0.390:1): initialized
<4>[ 0.843146] bounce pool size: 64 pages
<6>[ 0.847732] fuse init (API version 7.22)
<6>[ 0.848103] msgmni has been set to 1447
<7>[ 0.848153] SELinux: Registering netfilter hooks
<6>[ 0.849849] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 0.849865] io scheduler noop registered
<6>[ 0.849875] io scheduler deadline registered
<6>[ 0.849962] io scheduler cfq registered (default)
<6>[ 0.851169] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
<4>[ 0.851843] IEP Power ON
<4>[ 0.851885] iep ion client create success!
<6>[ 0.852332] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x2e2a0000
<4>[ 0.852343] IEP Power OFF
<4>[ 0.852360] IEP Driver loaded succesfully
<4>[ 0.852461] Module initialized.
<6>[ 0.853306] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.853323] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 0.854729] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.854746] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<3>[ 0.855031] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
<3>[ 0.855045] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
<4>[ 0.855055] pwm_regulator_probe:error
<6>[ 0.855076] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
<4>[ 0.855286] rk_serial.c v1.8 2014-03-04
<6>[ 0.855517] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 0.855704] serial ff180000.serial: membase f017e000
<6>[ 0.855864] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
<6>[ 0.856049] serial ff190000.serial: membase f1992000
<6>[ 0.856191] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
<4>[ 0.856276] 2, baud is:115200
<4>[ 0.856676] --11
<6>[ 0.857881] console [ttyS2] enabled
<6>[ 0.858109] serial ff690000.serial: membase fed60000
<6>[ 0.858307] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
<6>[ 0.858478] serial ff1b0000.serial: membase f199c000
<6>[ 0.861275] loop: module loaded
<6>[ 0.861639] zram: Created 1 device(s) …
<4>[ 0.861722] i2c-core: driver [mpu6050B1] using legacy suspend method
<4>[ 0.861735] i2c-core: driver [mpu6050B1] using legacy resume method
<6>[ 0.861751] mpu_init: Probe name mpu6050B1
<6>[ 0.861906] ak8963_mod_init: Probe name ak8963_mod
<6>[ 0.862609] SCSI Media Changer driver v0.25
<6>[ 0.862931] tun: Universal TUN/TAP device driver, 1.6
<6>[ 0.862944] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 0.863063] vmac_init.
<3>[ 0.863638] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<6>[ 0.863655] stmmac_probe_config_dt: clock input/output? (input).
<6>[ 0.863668] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 0.863680] stmmac_probe_config_dt: RX delay(0x20).
<7>[ 0.863694] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 0.863709] of_get_named_gpio_flags exited with status 136
<7>[ 0.863719] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 0.863729] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 0.863740] stmmc_pltfr_init:
<3>[ 0.863749] stmmc_pltfr_init: ERROR: Get power-gpio failed.
<7>[ 0.863763] _gpio_request: gpio-136 (gmac_phy_reset) status -16
<3>[ 0.863772] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
<6>[ 0.863783] stmmc_pltfr_init: init for RGMII
<6>[ 0.863794] tx delay=0x30
<6>[ 0.863794] rx delay=0x20
<6>[ 0.863810] tx delay=0x30
<6>[ 0.863810] rx delay=0x20
<6>[ 0.864283] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 0.864294] Normal descriptors
<6>[ 0.864303] Ring mode enabled
<6>[ 0.864314] DMA HW capability register supported
<6>[ 0.864326] RX Checksum Offload Engine supported (type 2)
<6>[ 0.864336] TX Checksum insertion supported
<6>[ 0.864345] Wake-Up On Lan supported
<6>[ 0.864386] Enable RX Mitigation via HW Watchdog Timer
<6>[ 0.864833] PPP generic driver version 2.4.2
<6>[ 0.864973] PPP BSD Compression module registered
<6>[ 0.864985] PPP Deflate Compression module registered
<6>[ 0.865008] PPP MPPE Compression module registered
<6>[ 0.865022] NET: Registered protocol family 24
<6>[ 0.865059] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 0.865073] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 0.865086] Rockchip WiFi SYS interface (V1.00) …
<4>[ 0.865120] esp_mem_init enter date May 11 2017 09:43:52
<4>[ 0.865131] esp_mem_init VERSION [V2.5]
<4>[ 0.865179] esp_mem_init complete
<6>[ 0.865266] usbcore: registered new interface driver catc
<6>[ 0.865313] usbcore: registered new interface driver kaweth
<6>[ 0.865327] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 0.865367] usbcore: registered new interface driver pegasus
<6>[ 0.865407] usbcore: registered new interface driver rtl8150
<6>[ 0.865445] usbcore: registered new interface driver r8152
<6>[ 0.865458] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 0.865524] usbcore: registered new interface driver hso
<6>[ 0.865569] usbcore: registered new interface driver asix
<6>[ 0.865613] usbcore: registered new interface driver ax88179_178a
<6>[ 0.865654] usbcore: registered new interface driver cdc_ether
<6>[ 0.865693] usbcore: registered new interface driver cdc_eem
<6>[ 0.865731] usbcore: registered new interface driver dm9601
<6>[ 0.865768] usbcore: registered new interface driver dm9620
<6>[ 0.865815] usbcore: registered new interface driver smsc75xx
<6>[ 0.865864] usbcore: registered new interface driver smsc95xx
<6>[ 0.865905] usbcore: registered new interface driver gl620a
<6>[ 0.865944] usbcore: registered new interface driver net1080
<6>[ 0.865982] usbcore: registered new interface driver plusb
<6>[ 0.866022] usbcore: registered new interface driver rndis_host
<6>[ 0.866060] usbcore: registered new interface driver cdc_subset
<6>[ 0.866101] usbcore: registered new interface driver zaurus
<6>[ 0.866142] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 0.866210] usbcore: registered new interface driver int51x1
<6>[ 0.866252] usbcore: registered new interface driver kalmia
<6>[ 0.866292] usbcore: registered new interface driver ipheth
<6>[ 0.866334] usbcore: registered new interface driver sierra_net
<6>[ 0.866373] usbcore: registered new interface driver cx82310_eth
<6>[ 0.866421] usbcore: registered new interface driver cdc_ncm
<6>[ 0.866461] usbcore: registered new interface driver qmi_wwan
<6>[ 0.866553] usbcore: registered new interface driver cdc_mbim
<6>[ 0.866567] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<6>[ 0.869017] EHCI: ehci_rk_probe f1a40000 f1a40010
<6>[ 0.869036] rockchip_ehci_host ff500000.usb: EHCI Host Controller
<6>[ 0.869066] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 0.869434] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 0.886174] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
<6>[ 0.886260] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.886278] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.886293] usb usb1: Product: EHCI Host Controller
<6>[ 0.886306] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 0.886320] usb usb1: SerialNumber: ff500000.usb
<6>[ 0.886795] hub 1-0:1.0: USB hub found
<6>[ 0.886824] hub 1-0:1.0: 1 port detected
<6>[ 0.887016] EHCI: ehci_rk_probe ok
<6>[ 0.887127] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
<6>[ 0.887428] usbcore: registered new interface driver cdc_acm
<6>[ 0.887443] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 0.887497] usbcore: registered new interface driver usblp
<6>[ 0.887541] usbcore: registered new interface driver cdc_wdm
<6>[ 0.887610] usbcore: registered new interface driver usb-storage
<6>[ 0.887656] usbcore: registered new interface driver ums-alauda
<6>[ 0.887697] usbcore: registered new interface driver ums-cypress
<6>[ 0.887736] usbcore: registered new interface driver ums-datafab
<6>[ 0.887774] usbcore: registered new interface driver ums_eneub6250
<6>[ 0.887813] usbcore: registered new interface driver ums-freecom
<6>[ 0.887852] usbcore: registered new interface driver ums-isd200
<6>[ 0.887892] usbcore: registered new interface driver ums-jumpshot
<6>[ 0.887931] usbcore: registered new interface driver ums-karma
<6>[ 0.887970] usbcore: registered new interface driver ums-onetouch
<6>[ 0.888009] usbcore: registered new interface driver ums-sddr09
<6>[ 0.888050] usbcore: registered new interface driver ums-sddr55
<6>[ 0.888094] usbcore: registered new interface driver ums-usbat
<6>[ 0.888182] usbcore: registered new interface driver usbserial
<6>[ 0.888224] usbcore: registered new interface driver usbserial_generic
<6>[ 0.888258] usbserial: USB Serial support registered for generic
<6>[ 0.888298] usbcore: registered new interface driver option
<6>[ 0.888329] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 0.888426] usbcore: registered new interface driver trancevibrator
<6>[ 0.888439] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 0.888886] f1a80040
<4>[ 0.888901] Core Release: 3.10a
<4>[ 0.888917] Setting default values for core params
<4>[ 0.889057] Using Buffer DMA mode
<4>[ 0.889069] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.889081] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.889093] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.889104] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 0.889124] Dedicated Tx FIFOs mode
<4>[ 0.889145] pcd_init otg_dev = ee38a180
<6>[ 0.889306] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 0.889340] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
<6>[ 0.889376] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 0.889441] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.889458] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.889472] usb usb2: Product: DWC OTG Controller
<6>[ 0.889485] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 0.889499] usb usb2: SerialNumber: ff580000.usb
<6>[ 0.889970] hub 2-0:1.0: USB hub found
<6>[ 0.889996] hub 2-0:1.0: 1 port detected
<6>[ 0.890313] usb20_host: version 3.10a 21-DEC-2012
<4>[ 0.892846] f1b00040
<4>[ 0.892861] Core Release: 3.10a
<4>[ 0.892877] Setting default values for core params
<4>[ 0.892990] Using Buffer DMA mode
<4>[ 0.893001] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.893012] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.893024] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.893034] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 0.893061] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 0.893088] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
<6>[ 0.893123] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 0.893216] Init: Power Port (0)
<6>[ 0.893274] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.893291] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.893305] usb usb3: Product: DWC OTG Controller
<6>[ 0.893318] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 0.893331] usb usb3: SerialNumber: ff540000.usb
<6>[ 0.893757] hub 3-0:1.0: USB hub found
<6>[ 0.893780] hub 3-0:1.0: 1 port detected
<6>[ 0.894547] usbcore: registered new interface driver xpad
<6>[ 0.894608] usbcore: registered new interface driver usb_acecad
<6>[ 0.894657] usbcore: registered new interface driver aiptek
<6>[ 0.894705] usbcore: registered new interface driver gtco
<6>[ 0.894759] usbcore: registered new interface driver hanwang
<6>[ 0.894827] usbcore: registered new interface driver kbtab
<6>[ 0.894885] usbcore: registered new interface driver wacom
<4>[ 0.895164] sensor_register_slave:mma8452,id=17
<4>[ 0.895179] sensor_register_slave:gs_mc3230,id=23
<4>[ 0.895188] gsensor_init
<4>[ 0.895198] sensor_register_slave:mpu6880_acc,id=24
<4>[ 0.895209] sensor_register_slave:mpu6500_acc,id=25
<4>[ 0.895221] sensor_register_slave:cm3217,id=48
<4>[ 0.895231] sensor_register_slave:cm3218,id=49
<3>[ 0.895460] .. rk pwm remotectl v1.1 init
<6>[ 0.895711] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
<7>[ 0.898776] of_get_named_gpio_flags exited with status 228
<6>[ 0.900755] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 0.900810] i2c /dev entries driver
<6>[ 0.901488] IR NEC protocol handler initialized
<6>[ 0.901502] IR RC5(x) protocol handler initialized
<6>[ 0.901512] IR RC6 protocol handler initialized
<6>[ 0.901522] IR JVC protocol handler initialized
<6>[ 0.901532] IR Sony protocol handler initialized
<6>[ 0.901542] IR RC5 (streamzap) protocol handler initialized
<6>[ 0.901552] IR SANYO protocol handler initialized
<6>[ 0.901562] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 0.901720] usbcore: registered new interface driver uvcvideo
<6>[ 0.901732] USB Video Class driver (1.1.1)
<4>[ 0.901745] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
<7>[ 0.903214] of_get_named_gpio_flags exited with status 236
<4>[ 0.903236] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
<7>[ 0.903251] of_get_named_gpio_flags exited with status 236
<4>[ 0.903260] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
<4>[ 0.903297] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
<4>[ 0.903319] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
<4>[ 0.903358] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
<4>[ 0.903358]
<4>[ 0.903434] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 0.903587] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf19f8000 size: 0x4000)
<4>[ 0.904227] D1:camsys_platform_probe(1447): ff910000.isp memory:
<4>[ 0.904246] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xf1a20000 size: 0x10000)
<4>[ 0.904263] D1:camsys_platform_probe(1452): I2c memory (phy: 0x2d70f000 vir: 0xed70f000 size: 0x1000)
<4>[ 0.904278] D1:camsys_init_ext_fsh_module(20): init external flash module
<4>[ 0.904291] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
<6>[ 0.904725] test power disabled
<4>[ 0.904780] i2c-core: driver [bq27320] using legacy suspend method
<4>[ 0.904793] i2c-core: driver [bq27320] using legacy resume method
<4>[ 0.905134] rockchip_temp_probe,line=364
<6>[ 0.955056] tsadc ff280000.tsadc: initialized
<6>[ 0.955443] device-mapper: uevent: version 1.0.3
<6>[ 0.955689] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 0.955995] Bluetooth: HCI UART driver ver 2.2
<6>[ 0.956025] Bluetooth: HCI H4 protocol initialized
<6>[ 0.956038] Bluetooth: HCILL protocol initialized
<6>[ 0.956050] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
<6>[ 0.956063] rtk_btusb: Register usb char device interface for BT driver
<6>[ 0.956249] usbcore: registered new interface driver rtk_btusb
<4>[ 0.956882] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
<4>[ 0.960990] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 0.961204] cpuidle: using governor ladder
<6>[ 0.961218] cpuidle: using governor menu
<6>[ 0.961256] Synopsys Designware Multimedia Card Interface Driver
<6>[ 0.961268] MHSC version = Ver 2.00 2015-06-10
<4>[ 0.961581] dw cru_regsbase addr 0x1d8.
<4>[ 0.961594] dw cru_reset_offset val 3.
<6>[ 0.961609] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<3>[ 0.961655] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
<6>[ 0.961981] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 0.962152] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<7>[ 0.962184] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 0.962285] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 0.974742] 1358..dw_mci_set_ios: no card. [mmc0]
<6>[ 0.994488] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 0.994508] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<4>[ 0.994544] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<4>[ 0.994837] dw cru_regsbase addr 0x1d8.
<4>[ 0.994850] dw cru_reset_offset val 0.
<6>[ 0.994865] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<3>[ 0.994916] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
<6>[ 0.995702] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 0.995872] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
<7>[ 0.995901] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 0.996371] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 0.996452] 1358..dw_mci_set_ios: no card. [mmc1]
<4>[ 0.904840] hdmi->edidread:1
<6>[ 1.001050] hdmi output corlor mode is 3
<4>[ 1.001064] hdmi connect to lcdc1
<6>[ 1.001072] switch:en=1,lcdc_id=1,screen type=6,cur type=0
<4>[ 1.014099] 1358..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.026568] mmc0: BKOPS_EN bit is not set
<4>[ 1.028436] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
<6>[ 1.030716] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
<4>[ 1.030740] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<6>[ 1.030762] [mmc0] tuning regsbase addr 0x218.
<3>[ 1.031317] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
<3>[ 1.031327] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 1.031355] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
<3>[ 1.031399] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
<3>[ 1.031628] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-180 (17 len)
<3>[ 1.031640] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 214-282 (7 len)
<3>[ 1.031651] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-180 (17 len)
<3>[ 1.031661] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 90
<6>[ 1.031706] mmc0: new HS200 MMC card at address 0001
<6>[ 1.031969] mmcblk0: mmc0:0001 AGND3R 14.5 GiB
<6>[ 1.032295] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 1.032308] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 1.032318] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 1.032326] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 1.032335] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 1.032343] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 1.032351] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 1.032359] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 1.032367] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 1.032376] system: 0x012400000 – 0x042400000 (768 MB)
<6>[ 1.032384] metadata: 0x042400000 – 0x042800000 (4 MB)
<6>[ 1.032392] userdata: 0x042800000 – 0x082800000 (1024 MB)
<6>[ 1.032400] radical_update: 0x082800000 – 0x086800000 (64 MB)
<6>[ 1.032409] user: 0x086800000 – 0x3a3a00000 (12754 MB)
<6>[ 1.032437] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141358..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.033808] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 1.033815] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<4>[ 1.034107] dw cru_regsbase addr 0x1d8.
<4>[ 1.034115] dw cru_reset_offset val 1.
<6>[ 1.034125] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<3>[ 1.034162] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.034393] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 1.034526] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<7>[ 1.034548] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.034774] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.053447] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.073143] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.073160] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 1.073173] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<4>[ 1.073454] leds-gpio leds.27: pins are not configured from the driver
<7>[ 1.073473] of_get_named_gpio_flags exited with status 257
<7>[ 1.073481] of_get_named_gpio_flags exited with status 258
<7>[ 1.073490] of_get_named_gpio_flags exited with status 17
<7>[ 1.073498] of_get_named_gpio_flags exited with status 257
<7>[ 1.073584] of_get_named_gpio_flags exited with status 258
<7>[ 1.073635] of_get_named_gpio_flags exited with status 17
<6>[ 1.073741] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 1.075224] usbcore: registered new interface driver usbhid
<6>[ 1.075234] usbhid: USB HID core driver
<6>[ 1.075359] ashmem: initialized
<6>[ 1.075468] logger: created 256K log ‘log_main’
<6>[ 1.075563] logger: created 256K log ‘log_events’
<6>[ 1.075655] logger: created 256K log ‘log_radio’
<6>[ 1.075743] logger: created 256K log ‘log_system’
<7>[ 1.076597] of_get_named_gpio_flags exited with status 5
<7>[ 1.076606] of_get_named_gpio_flags exited with status 5
<6>[ 1.076841] input: rk29-keypad as /devices/ff100000.adc/key.30/input/input1
<3>[ 1.077670] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
<3>[ 1.077686] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
<3>[ 1.077698] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
<3>[ 1.077710] ES8323 2-0010: Error applying setting, reverse things back
<7>[ 1.077735] of_get_named_gpio_flags exited with status 10
<7>[ 1.077746] of_get_named_gpio_flags exited with status 239
<4>[ 1.078003] es8323 probe i2c recv ok
<6>[ 1.078931] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
<4>[ 1.079518] es8323_probe
<6>[ 1.250241] rk_fb_switch_screen: wait update_regs_wait timeout
<6>[ 1.250292] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
<6>[ 1.250324] pixel clk is 74250000 tmds clk is 74250000
<6>[ 1.250371] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
<4>[ 1.713092] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
<3>[ 1.713102] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
<4>[ 1.713111] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
<3>[ 1.713119] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
<4>[ 1.713128] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
<3>[ 1.713135] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
<4>[ 1.713143] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
<3>[ 1.713150] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
<4>[ 1.713158] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
<3>[ 1.713165] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
<4>[ 1.713173] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
<3>[ 1.713179] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
<4>[ 1.713187] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
<3>[ 1.713194] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
<4>[ 1.713202] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
<3>[ 1.713208] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
<4>[ 1.713216] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
<3>[ 1.713223] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
<4>[ 1.713231] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
<3>[ 1.713237] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
<4>[ 1.713245] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
<3>[ 1.713251] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
<4>[ 1.713259] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
<3>[ 1.713266] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
<4>[ 1.713274] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
<3>[ 1.713280] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
<4>[ 1.713289] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
<3>[ 1.713295] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
<4>[ 1.713303] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
<3>[ 1.713309] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
<4>[ 1.713317] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
<3>[ 1.713324] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
<4>[ 1.713342] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
<3>[ 1.713349] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
<4>[ 1.713357] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
<3>[ 1.713363] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
<4>[ 1.713371] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
<3>[ 1.713378] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
<4>[ 1.713386] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
<3>[ 1.713393] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
<4>[ 1.713400] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
<3>[ 1.713407] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
<4>[ 1.713415] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
<3>[ 1.713421] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
<3>[ 1.713545] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
<3>[ 1.713555] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
<3>[ 1.713564] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
<3>[ 1.713586] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
<3>[ 1.713605] ES8323 2-0010: ASoC: mux Differential Mux has no paths
<6>[ 1.719697] rockchip-es8323 rockchip-es8323.26: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
<6>[ 1.720061] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.26/sound/card0/input2
<6>[ 1.720454] u32 classifier
<6>[ 1.720461] Actions configured
<6>[ 1.720470] Netfilter messages via NETLINK v0.30.
<6>[ 1.720519] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 1.720778] ctnetlink v0.93: registering with nfnetlink.
<6>[ 1.720836] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 1.720843] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 1.721058] xt_time: kernel timezone is -0000
<6>[ 1.721212] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.721320] arp_tables: (C) 2002 David S. Miller
<6>[ 1.721355] TCP: cubic registered
<6>[ 1.721360] Initializing XFRM netlink socket
<6>[ 1.721531] NET: Registered protocol family 10
<6>[ 1.721941] mip6: Mobile IPv6
<6>[ 1.721960] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.722066] sit: IPv6 over IPv4 tunneling driver
<6>[ 1.722334] NET: Registered protocol family 17
<6>[ 1.722356] NET: Registered protocol family 15
<5>[ 1.722398] Bridge firewalling registered
<6>[ 1.722408] Ebtables v2.0 registered
<6>[ 1.722583] Bluetooth: RFCOMM TTY layer initialized
<6>[ 1.722609] Bluetooth: RFCOMM socket layer initialized
<6>[ 1.722615] Bluetooth: RFCOMM ver 1.11
<6>[ 1.722621] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 1.722627] Bluetooth: BNEP filters: protocol multicast
<6>[ 1.722636] Bluetooth: BNEP socket layer initialized
<6>[ 1.722642] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 1.722651] Bluetooth: HIDP socket layer initialized
<6>[ 1.722680] l2tp_core: L2TP core driver, V2.0
<6>[ 1.722691] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 1.722696] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 1.722879] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 1.722889] [WLAN_RFKILL]: can’t find rockchip,grf property
<6>[ 1.722895] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
<6>[ 1.722903] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 1.722910] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 1.722918] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 1.722932] of_get_named_gpio_flags exited with status 156
<6>[ 1.722937] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 1.722944] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 1.722950] of_get_named_gpio_flags exited with status 158
<6>[ 1.722955] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 1.722962] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 1.722987] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 1.722995] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 1.723030] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 1.723134] of_get_named_gpio_flags exited with status 147
<6>[ 1.723139] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 1.723150] of_get_named_gpio_flags exited with status 263
<6>[ 1.723154] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 263.
<7>[ 1.723161] of_get_named_gpio_flags exited with status 157
<6>[ 1.723165] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<7>[ 1.723172] of_get_named_gpio_flags exited with status 154
<6>[ 1.723177] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 1.723183] of_get_named_gpio_flags exited with status 159
<6>[ 1.723187] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 1.723229] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 1.723319] [BT_RFKILL]: ** disable irq
<6>[ 1.723404] [BT_RFKILL]: ap6335 device registered.
<4>[ 1.723982] rk3288_init_suspend
<4>[ 1.723992] rk3288_suspend_init enter
<4>[ 1.724191] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 1.724224] gpio_get_dts_info suspend:4
<4>[ 1.724230] gpio_get_dts_info resume:4
<4>[ 1.724236] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.724258] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.724374] clks_gating_suspend_init:clkgt info ok
<5>[ 1.724451] Registering SWP/SWPB emulation handler
<6>[ 1.724743] ddrfreq: verion 1.2 20140526
<6>[ 1.724755] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
<6>[ 1.724761] ddrfreq: auto-freq=0
<6>[ 1.724766] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 1.724770] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 1.724775] ddrfreq: auto-freq-table[2] 456MHz
<6>[ 1.724780] ddrfreq: auto-freq-table[3] 528MHz
<3>[ 1.740415] act_ldo3: operation not allowed
<6>[ 1.740422] rgb2hdmi_probe: turn on ldo3 done.
<3>[ 1.740671] act_ldo4: operation not allowed
<6>[ 1.740676] rgb2hdmi_probe: turn on ldo done.
<3>[ 1.740919] act_ldo2: operation not allowed
<6>[ 1.740925] rgb2hdmi_probe: turn on ldo2 done.
<3>[ 1.741177] act_ldo8: operation not allowed
<6>[ 1.741183] rgb2hdmi_probe: turn on ldo done.
<7>[ 1.741193] of_get_named_gpio_flags exited with status 226
<7>[ 1.741205] of_get_named_gpio_flags exited with status 227
<7>[ 1.741214] of_get_named_gpio_flags exited with status 155
<4>[ 1.741225] rgb2hdmi_probe: success. 7
<4>[ 1.741278] firefly_rgb2hdmi_get_enable 201, 0
<4>[ 1.741284] firefly_rgb2hdmi_get_status 207
<4>[ 1.741289] firefly_rgb2hdmi_set_enable 183 enable:1
<4>[ 1.741294] firefly_rgb2hdmi_enable 150 start
<4>[ 1.741299] firefly_switch_to_rgb 75
<6>[ 1.741305] switch:en=1,lcdc_id=0,screen type=1,cur type=1
<6>[ 1.988243] rk_fb_switch_screen: wait update_regs_wait timeout
<6>[ 1.988288] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
<4>[ 1.988317] HDMI ENABLE
<4>[ 1.988326] HDMI Devie connected 7
<4>[ 1.988330] firefly_rgb2hdmi_set_mode 226
<4>[ 1.988336] firefly_rgb2hdmi_set_mode 242 1280 720 60 74250000
<4>[ 1.988340] firefly_rgb2hdmi_enable 150 start
<4>[ 1.988345] firefly_switch_to_rgb 75
<6>[ 1.988351] switch:en=1,lcdc_id=0,screen type=1,cur type=1
<6>[ 2.244085] rk_fb_switch_screen: wait update_regs_wait timeout
<6>[ 2.244098] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
<6>[ 2.244138] regulator-dummy: disabling
<4>[ 2.244347] =======================================================
<4>[ 2.244355] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 2.244360] =======================================================
<4>[ 2.244365] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
<4>[ 2.244408] dhd_module_init: in
<4>[ 2.244414] ======== bcm_wlan_set_plat_data ========
<6>[ 2.244419] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
<4>[ 2.244438] host_oob_irq: 196
<4>[ 2.244443] host_oob_irq_flags=4
<4>[ 2.244446] dhd_wifi_platform_load: Enter
<4>[ 2.244457] pcd_pullup, is_on 0
<4>[ 2.244461] Power-up adapter ‘DHD generic adapter’
<4>[ 2.244476] wifi_platform_set_power = 1
<4>[ 2.244480] ======== PULL WL_REG_ON HIGH! ========
<6>[ 2.244486] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 2.244491] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 2.244493] file system registered
<6>[ 2.244500] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 2.244956] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 2.244965] android_usb gadget: Number of LUNs=2
<6>[ 2.244971] lun0: LUN: removable file: (no medium)
<6>[ 2.244976] lun1: LUN: removable file: (no medium)
<6>[ 2.245096] android_usb gadget: android_usb ready
<6>[ 2.245165] sensor_init: Probe name sensors
<4>[ 2.245179] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ 2.245700] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:05:02 UTC (1293883502)
<6>[ 2.251263] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
<6>[ 2.251901] usbcore: registered new interface driver snd-usb-audio
<6>[ 2.251908] ALSA device list:
<6>[ 2.251913] #0: RK_ES8323
<6>[ 2.251917] #1: RK-SPDIF-CARD
<4>[ 2.252097] 2, baud is:115200
<6>[ 2.252244] Freeing unused kernel memory: 356K (c0b8f000 - c0be8000)
<6>[ 2.352325] [WLAN_RFKILL]: wifi turn on power. 156
<7>[ 2.362134] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 2.363690] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 2.363707] SELinux: 1 users, 2 roles, 442 types, 0 bools, 1 sens, 1024 cats
<7>[ 2.363714] SELinux: 86 classes, 5368 rules
<7>[ 2.364495] SELinux: Completing initialization.
<7>[ 2.364501] SELinux: Setting up existing superblocks.
<7>[ 2.364514] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 2.364529] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 2.364578] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 2.364588] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 2.364601] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.364614] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 2.364763] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 2.373930] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 2.373944] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 2.373953] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 2.373961] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 2.373977] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 2.374020] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 2.374029] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.374047] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<5>[ 2.483588] type=1403 audit(1293883502.730:2): policy loaded auid=4294967295 ses=4294967295
<5>[ 2.487222] type=1404 audit(1293883502.730:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
<4>[ 2.558969] wifi_platform_bus_enumerate device present 1
<4>[ 2.558984] ======== Card detection to detect SDIO card! ========
<6>[ 2.558992] mmc2:mmc host rescan start!
<11>[ 2.602664] init: invalid gid ‘trace’
<11>[ 2.701279] init: /dev/hw_random not found
<6>[ 2.701352] keychord: using input dev ff680000.pwm for fevent
<6>[ 2.701368] keychord: using input dev rk29-keypad for fevent
<4>[ 2.701468] 2, baud is:115200
<7>[ 2.701862] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 2.702140] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.702418] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 2.703665] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.703819] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.705048] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<11>[ 2.706298] init: /dev/hw_random not found
<14>[ 2.707286] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 2.708091] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
<4>[ 2.710493] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
<6>[ 2.715057] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.715088] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 2.715153] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
<14>[ 2.715839] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 2.720671] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.720717] e2fsck: system: clean, 1882/42336 files, 112558/196608 blocks
<6>[ 2.724320] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 2.724346] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 2.724398] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
<6>[ 2.728164] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 2.728187] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<14>[ 2.728226] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
<4>[ 2.728504] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
<4>[ 2.729240] EXT4-fs (mmcblk0p11): warning: mounting unchecked fs, running e2fsck is recommended
<6>[ 2.729579] EXT4-fs (mmcblk0p11): mounted filesystem without journal. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.729598] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 2.729619] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
<14>[ 2.730159] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
<14>[ 2.739156] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.739193] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata was not cleanly unmounted, check forced.
<14>[ 2.739210] e2fsck: Pass 1: Checking inodes, blocks, and sizes
<14>[ 2.739224] e2fsck: Pass 2: Checking directory structure
<14>[ 2.739236] e2fsck: Pass 3: Checking directory connectivity
<14>[ 2.739248] e2fsck: Pass 4: Checking reference counts
<14>[ 2.739261] e2fsck: Pass 5: Checking group summary information
<14>[ 2.739274] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: 11/1024 files (0.0% non-contiguous), 42/1024 blocks
<14>[ 2.739291] e2fsck: e2fsck terminated by exit(1)
<6>[ 2.740657] EXT4-fs (mmcblk0p11): mounted filesystem without journal. Opts: noauto_da_alloc,discard
<7>[ 2.740681] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 2.740709] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
<14>[ 2.740753] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 2.741616] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
<14>[ 2.741655] fsck.f2fs: fsck.f2fs terminated by exit(255)
<14>[ 2.741898] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
<4>[ 2.742247] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
<6>[ 2.745723] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.745747] SELinux: initialized (dev mmcblk0p12, type ext4), uses xattr
<14>[ 2.745790] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
<14>[ 2.746620] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 2.751089] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.751127] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 11/65536 files, 8536/262144 blocks
<6>[ 2.754981] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
<7>[ 2.755008] SELinux: initialized (dev mmcblk0p12, type ext4), uses xattr
<14>[ 2.755046] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<11>[ 2.755068] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
<7>[ 2.755747] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<6>[ 2.774679] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
<6>[ 2.774775] mali ffa30000.gpu: Continuing without Mali clock control
<4>[ 2.774818] mali pd enabled
<4>[ 2.774830] clk enabled
<4>[ 2.774843] MALI_DVFS_STEP = 4, div_dvfs = 10
<6>[ 2.774853] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
<6>[ 2.774862] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
<6>[ 2.774872] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
<6>[ 2.774882] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
<3>[ 2.774974] turn on mali power
<6>[ 2.774987] kbase_platform_rk_init,register_reboot_notifier
<4>[ 2.775030] hrtimer: interrupt took 11958 ns
<6>[ 2.775129] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
<4>[ 2.775456] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
<6>[ 2.775893] mali ffa30000.gpu: Probed as mali0
<3>[ 2.776969] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 2.777611] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 2.778219] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 2.778991] zram0: detected capacity change from 0 to 533413888
<4>[ 2.810304] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 2.811833] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 2.813376] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 2.816128] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<6>[ 2.825711] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
<4>[ 2.864007] dwc_otg_hcd_enable, enable host controller
<6>[ 2.864014] EHCI: rk_ehci_hcd_enable, disable host controller
<6>[ 2.869379] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 2.869406] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 2.869470] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
<4>[ 2.871110] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
<6>[ 2.871137] mmc2: new high speed SDIO card at address 0001
<4>[ 2.887341] bcmsdh_register: register client driver
<4>[ 2.887437] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 2.887510] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 2.887521] bus num (host idx)=2, slot num (rca)=1
<4>[ 2.887530] found adapter info ‘DHD generic adapter’
<4>[ 2.887755] F1 signature read @0x18000000=0x16224335
<4>[ 2.903778] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
<4>[ 2.904323] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
<4>[ 2.904370] wifi_platform_get_mac_addr
<4>[ 2.904381] ======== bcm_wlan_get_mac_address ========
<6>[ 2.904390] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 2.904401] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 2.904410] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 2.904425] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
<4>[ 2.904651] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
<4>[ 2.904964] wl_create_event_handler(): thread:wl_event_handler:92 started
<4>[ 2.904969] tsk Enter, tsk = 0xecb6149c
<4>[ 2.905112] dhd_attach(): thread:dhd_watchdog_thread:93 started
<4>[ 2.905154] dhd_attach(): thread:dhd_dpc:94 started
<4>[ 2.905167] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
<4>[ 2.905216] dhd_attach(): thread:dhd_rxf:95 started
<4>[ 2.905231] dhd_deferred_work_init: work queue initialized
<4>[ 2.905343] dhdsdio_probe_init: set use_rxchain 1 from config.txt
<3>[ 2.911402] EXT4-fs (mmcblk0p12): Unrecognized mount option “background_gc=on” or missing value
<4>[ 2.914094] Dongle Host Driver, version 1.201.59.5 (r506368)
<4>[ 2.914094] Compiled in drivers/net/wireless/bcmdhd on May 11 2017 at 09:43:59
<4>[ 2.914463] Register interface [wlan0] MAC: e0:76:d0:f0:9c:cf
<4>[ 2.914463]
<4>[ 2.914483] dhd_prot_ioctl : bus is down. we have nothing to do
<4>[ 2.914523] bcmsdh_oob_intr_unregister: Enter
<4>[ 2.914529] bcmsdh_oob_intr_unregister: irq is not registered
<4>[ 2.914540] dhd_txglom_enable: enable 0
<4>[ 2.914545] dhd_bus_devreset: WLAN OFF DONE
<4>[ 2.914578] wifi_platform_set_power = 0
<4>[ 2.914584] ======== PULL WL_REG_ON LOW! ========
<6>[ 2.914591] [WLAN_RFKILL]: rockchip_wifi_power: 0
<14>[ 2.917543] bat_cap: oldcap path is /sys/devices/ff100000.adc
<11>[ 2.917607] bat_cap: oldcap_path no exist
<6>[ 2.917755] binder: 151:151 transaction failed 29189, size 0-0
<11>[ 2.918396] init: Warning! Service displayd needs a SELinux domain defined; please fix!
<11>[ 2.922148] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 2.922180] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 2.922434] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 2.923000] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.923019] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.923067] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.923078] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.923103] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.923113] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.923127] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.923136] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<4>[ 2.924467] 0,baud is:9600
<4>[ 2.924596] 1, baud is:115200
<4>[ 2.924734] 1, baud is:115200
<4>[ 2.924820] 0,baud is:9600
<4>[ 2.925996] 2, baud is:115200
<11>[ 2.926817] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<11>[ 2.928310] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 2.928770] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 2.928953] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<11>[ 2.929191] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
<7>[ 2.930113] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<3>[ 2.930644] android_usb: already disabled
<6>[ 2.933529] read descriptors
<6>[ 2.933543] read strings
<4>[ 2.933572] pcd_pullup, is_on 1
<4>[ 2.968190] Using Buffer DMA mode
<4>[ 2.968205] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 2.968212] Multiprocessor Interrupt Enhancement - disabled
<4>[ 2.968220] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 2.968227] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 3.011708] Init: Power Port (0)
<6>[ 3.021459] [WLAN_RFKILL]: wifi shut off power.
<6>[ 3.021472] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 3.021479] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 3.021540] dhd_module_init: Exit err=0
<4>[ 3.088719] firefly_rgb2hdmi_get_enable 201, 1
<4>[ 3.088784] firefly_rgb2hdmi_get_status 207
<4>[ 3.089005] firefly_rgb2hdmi_set_mode 226
<4>[ 3.089013] firefly_rgb2hdmi_set_mode 242 1280 720 60 74250000
<4>[ 3.089431] firefly_rgb2hdmi_set_enable 183 enable:1
<4>[ 3.089438] firefly_rgb2hdmi_enable 150 start
<4>[ 3.089443] firefly_switch_to_rgb 75
<6>[ 3.089451] switch:en=1,lcdc_id=0,screen type=1,cur type=1
<4>[ 3.178167] dhd_open: Enter ee08f800
<4>[ 3.178180]
<4>[ 3.178180] Dongle Host Driver, version 1.201.59.5 (r506368)
<4>[ 3.178180] Compiled in drivers/net/wireless/bcmdhd on May 11 2017 at 09:43:59
<4>[ 3.178192] wl_android_wifi_on in 1
<4>[ 3.178199] wl_android_wifi_on in 2: g_wifi_on=0
<4>[ 3.178204] wifi_platform_set_power = 1
<4>[ 3.178209] ======== PULL WL_REG_ON HIGH! ========
<6>[ 3.178215] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 3.178221] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 3.178227] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<38>[ 3.242284] logd.auditd: start
<6>[ 3.277321] [WLAN_RFKILL]: wifi turn on power. 156
<4>[ 3.356045] Indeed it is in host mode hprt0 = 00021501
<6>[ 3.365861] rk_fb_switch_screen: wait update_regs_wait timeout
<6>[ 3.365883] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
<4>[ 3.365958] HDMI ENABLE
<4>[ 3.483940] sdio_reset_comm():
<6>[ 3.486940] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
<4>[ 3.486951] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
<4>[ 3.505491] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 3.508503] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 3.511524] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 3.516955] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<6>[ 3.533163] usb 3-1: new high-speed USB device number 2 using usb20_host
<4>[ 3.533228] Indeed it is in host mode hprt0 = 00001101
<6>[ 3.642870] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 3.642906] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 3.643147]
<4>[ 3.643147]
<4>[ 3.643147] dhd_bus_devreset: == WLAN ON ==
<4>[ 3.643210] F1 signature read @0x18000000=0x16224335
<4>[ 3.645203] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
<4>[ 3.645521] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
<4>[ 3.645661] dhdsdio_probe_init: set use_rxchain 1 from config.txt
<4>[ 3.648824] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
<4>[ 3.648840] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_bcm4339a0_ag.bin
<4>[ 3.648847] Final fw_path=/system/etc/firmware/fw_bcm4339a0_ag.bin
<4>[ 3.648853] Final nv_path=/system/etc/firmware/nvram_AP6335.txt
<4>[ 3.648858] Final conf_path=/system/etc/firmware/config.txt
<6>[ 3.730189] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
<6>[ 3.730201] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 3.730208] usb 3-1: Product: USB 2.0 Hub [MTT]
<6>[ 3.731233] hub 3-1:1.0: USB hub found
<6>[ 3.731294] hub 3-1:1.0: 4 ports detected
<11>[ 3.902373] healthd: No charger supplies found
<12>[ 3.902386] healthd: No battery devices found
<7>[ 3.929190] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<4>[ 3.976258] NVRAM version: AP6335_NVRAM_V1.7_04102014
<4>[ 3.976764] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
<6>[ 4.005518] usb 3-1.4: new low-speed USB device number 3 using usb20_host
<6>[ 4.038125] rk3288-lcdc lcdc0: blank mode:0
<6>[ 4.062737] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x2e2a8000
<6>[ 4.107793] usb 3-1.4: New USB device found, idVendor=093a, idProduct=2510
<6>[ 4.107807] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 4.107814] usb 3-1.4: Product: USB Optical Mouse
<6>[ 4.107820] usb 3-1.4: Manufacturer: PixArt
<6>[ 4.110839] input: PixArt USB Optical Mouse as /devices/ff540000.usb/usb3/3-1/3-1.4/3-1.4:1.0/input/input3
<6>[ 4.111184] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-ff540000.usb-1.4/input0
<4>[ 4.149134] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
<4>[ 4.149279] bcmsdh_oob_intr_register: Enter
<4>[ 4.149285] bcmsdh_oob_intr_register: HW_OOB enabled
<4>[ 4.149290] bcmsdh_oob_intr_register OOB irq=196 flags=4
<4>[ 4.149347] bcmsdh_oob_intr_register: enable_irq_wake
<4>[ 4.149728] dhd_conf_set_band: Set band 0
<4>[ 4.150051] dhd_preinit_ioctls: Set tcpack_sup_mode 0
<4>[ 4.150063] wifi_platform_get_mac_addr
<4>[ 4.150069] ======== bcm_wlan_get_mac_address ========
<6>[ 4.150076] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 4.150083] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 4.150088] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 4.159417] Firmware up: op_mode=0x0005, MAC=e0:76:d0:f0:9c:cf
<4>[ 4.159429] dhd_conf_set_country: Set country CN, revision 38
<4>[ 4.204416] Country code: CN (CN/38)
<4>[ 4.204609] dhd_conf_set_roam: Set roam_off 1
<4>[ 4.206106] dhd_conf_set_txbf: set txbf 1
<4>[ 4.212996] Firmware version = wl0: Apr 3 2014 12:12:42 version 6.37.32.28.2_ip (r424058)
<4>[ 4.213010] Driver: 1.201.59.5 (r506368)
<4>[ 4.213010] Firmware: wl0: Apr 3 2014 12:12:42 version 6.37.32.28.2_ip (r424058)
<4>[ 4.213179] dhd_txglom_enable: enable 1
<4>[ 4.213185] dhd_conf_set_disable_proptx: set disable_proptx 0
<4>[ 4.214114] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
<4>[ 4.216892] wl_android_wifi_on: Success
<4>[ 4.270576] dhd_open: Exit ret=0
<4>[ 4.369955] dhd_stop: Enter ee08f800
<4>[ 4.375499] wl_android_wifi_off in 1
<4>[ 4.375508] wl_android_wifi_off in 2: g_wifi_on=1
<4>[ 4.375718] dhdsdio_isr : bus is down. we have nothing to do
<4>[ 4.375732] bcmsdh_oob_intr_unregister: Enter
<4>[ 4.375749] dhd_txglom_enable: enable 0
<4>[ 4.375754] dhd_bus_devreset: WLAN OFF DONE
<4>[ 4.375783] wifi_platform_set_power = 0
<4>[ 4.375789] ======== PULL WL_REG_ON LOW! ========
<6>[ 4.375794] [WLAN_RFKILL]: rockchip_wifi_power: 0
<6>[ 4.477780] [WLAN_RFKILL]: wifi shut off power.
<6>[ 4.477801] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 4.477807] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 4.477817] wl_android_wifi_off out
<4>[ 4.477824] dhd_stop: Exit
<4>[ 8.691072] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.691089] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.691097] D1:camsys_open(739): camsys_marvin(ee38b310) is opened!
<4>[ 8.691190] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 8.691202] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 8.691212] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 8.691227] of_get_named_gpio_flags exited with status 237
<7>[ 8.691232] of_get_named_gpio_flags exited with status 237
<4>[ 8.691236] rockchip_gpio_request:GPIO7-13
<4>[ 8.691245] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 8.691250] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 8.691259] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x15
<4>[ 8.691267] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x20742c,result=0x20742c
<4>[ 8.691274] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 8.691293] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 8.696350] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 8.696361] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 8.696465] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 8.696493] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 8.697559] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 8.698694] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 8.699771] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<4>[ 8.703456] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 8.703470] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 8.703481] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 8.704559] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 8.704588] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 8.706643] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 8.706654] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.706660] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.706667] D1:camsys_release(763): camsys_marvin(ee38b310) is closed
<6>[ 8.777871] [otg id chg] last id -1 current id 1
<4>[ 8.777890] PortPower off
<4>[ 8.777896] rk_battery_charger_detect_cb , battery_charger_detect 6
<4>[ 8.881776] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.881789] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.881796] D1:camsys_open(739): camsys_marvin(ee38b310) is opened!
<4>[ 8.881896] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
<7>[ 8.881906] _gpio_request: gpio-79 (camsys_gpio) status -16
<3>[ 8.881913] E:camsys_extdev_register(239): Request RK30_PIN2_PB7(79) failed
<4>[ 8.881919] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
<7>[ 8.881927] _gpio_request: gpio-11 (camsys_gpio) status -16
<3>[ 8.881931] E:camsys_extdev_register(239): Request RK30_PIN0_PB3(11) failed
<4>[ 8.881938] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 8.881946] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 8.882041] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
<4>[ 8.887451] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 8.887463] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 8.887567] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 8.887597] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 8.888716] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 8.890168] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 8.891234] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
<3>[ 8.894470] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
<4>[ 8.894549] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
<4>[ 8.894565] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 8.894576] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 8.895659] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 8.895696] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 8.897755] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
<4>[ 8.897770] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 8.897780] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.897786] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.897793] D1:camsys_release(763): camsys_marvin(ee38b310) is closed
<4>[ 8.899526] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.899537] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 8.899544] D1:camsys_open(739): camsys_marvin(ee38b310) is opened!
<4>[ 8.899627] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 8.899652] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 8.904696] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 8.904708] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 8.904812] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 8.904841] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 8.905905] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 8.906962] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 8.908018] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 8.911346] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 8.911356] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 8.911362] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 8.912439] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 8.912469] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 8.914523] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 8.914537] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.914543] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 8.914550] D1:camsys_release(763): camsys_marvin(ee38b310) is closed
<36>[ 8.935361] type=1400 audit(1293883509.280:4): avc: denied { execute } for pid=456 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=317 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=0
<4>[ 8.945367] Using Buffer DMA mode
<4>[ 8.945379] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 8.945384] Multiprocessor Interrupt Enhancement - disabled
<4>[ 8.945390] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 8.945396] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 8.955144] es8323_mic_state_ctrl read:
<4>[ 8.955187] mic_state_switch 0
<4>[ 8.955194] hp_det = 0,insert hp
<4>[ 8.955198] hp mic use intern
<4>[ 9.437139] vbus detect**
<4>[ 9.439328] rk_battery_charger_detect_cb , battery_charger_detect 1
<4>[ 9.616368] Using Buffer DMA mode
<4>[ 9.616385] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 9.616391] Multiprocessor Interrupt Enhancement - disabled
<4>[ 9.616397] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 9.616403] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 9.616441] soft connect!!!
<4>[ 9.715147] USB RESET
<6>[ 9.801641] android_work: sent uevent USB_STATE=CONNECTED
<6>[ 9.822991] android_usb gadget: high-speed config #1: android
<6>[ 9.823102] android_work: sent uevent USB_STATE=CONFIGURED
<6>[ 23.679903] warning: `main’ uses 32-bit capabilities (legacy support in use)
<12>[ 37.389163] healthd: battery none chg=
<6>[ 37.610304] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 37.610326] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 37.610334] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 37.610342] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 37.610348] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 37.610354] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 37.610363] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>[ 37.943518] acc_open
<6>[ 37.943547] acc_release
<4>[ 38.076201] phy_power_on: enable = 1
<4>[ 38.115609] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 38.115649] eth0: device MAC address 72:8a:28:11:d5:dc
<6>[ 38.119772] libphy: stmmac: probed
<6>[ 38.119784] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
<6>[ 38.119792] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
<6>[ 40.945595] pm policy 0 → 1
<36>[ 42.522950] type=1400 audit(1293883543.420:5): avc: denied { write } for pid=1504 comm=“Binder_3” name=“/” dev=“mmcblk0p12” ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=0
<4>[ 42.523528] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 42.523539] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 42.523547] D1:camsys_open(739): camsys_marvin(ee38b310) is opened!
<4>[ 42.523839] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 420000000 Hz) in turn on
<4>[ 42.523874] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 42.523980] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 42.523990] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 42.524381] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 42.528223] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 42.538318] ------------[ cut here ]------------
<4>[ 42.538342] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
<4>[ 42.538349] autorequest GPIO-11
<4>[ 42.538355] Modules linked in: mali_kbase
<4>[ 42.538366] CPU: 1 PID: 1354 Comm: Binder_3 Not tainted 3.10.0 #1
<4>[ 42.538385] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
<4>[ 42.538399] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
<4>[ 42.538410] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
<4>[ 42.538420] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
<4>[ 42.538433] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
<4>[ 42.538447] [] (gpiod_direction_output+0x80/0x2b0) from [] (camsys_sysctl+0x288/0x458)
<4>[ 42.538458] [] (camsys_sysctl+0x288/0x458) from [] (camsys_ioctl+0x378/0x630)
<4>[ 42.538469] [] (camsys_ioctl+0x378/0x630) from [] (do_vfs_ioctl+0x210/0x240)
<4>[ 42.538479] [] (do_vfs_ioctl+0x210/0x240) from [] (SyS_ioctl+0x50/0x6c)
<4>[ 42.538491] [] (SyS_ioctl+0x50/0x6c) from [] (ret_fast_syscall+0x0/0x30)
<4>[ 42.538498] —[ end trace e4ccbf8c3a42e969 ]—
<4>[ 42.538518] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 42.538621] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 42.538712] ------------[ cut here ]------------
<4>[ 42.538727] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
<4>[ 42.538732] autorequest GPIO-79
<4>[ 42.538737] Modules linked in: mali_kbase
<4>[ 42.538747] CPU: 1 PID: 1354 Comm: Binder_3 Tainted: G W 3.10.0 #1
<4>[ 42.538762] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
<4>[ 42.538771] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
<4>[ 42.538781] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
<4>[ 42.538791] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
<4>[ 42.538801] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
<4>[ 42.538812] [] (gpiod_direction_output+0x80/0x2b0) from [] (camsys_sysctl+0x234/0x458)
<4>[ 42.538823] [] (camsys_sysctl+0x234/0x458) from [] (camsys_ioctl+0x378/0x630)
<4>[ 42.538834] [] (camsys_ioctl+0x378/0x630) from [] (do_vfs_ioctl+0x210/0x240)
<4>[ 42.538842] [] (do_vfs_ioctl+0x210/0x240) from [] (SyS_ioctl+0x50/0x6c)
<4>[ 42.538852] [] (SyS_ioctl+0x50/0x6c) from [] (ret_fast_syscall+0x0/0x30)
<4>[ 42.538858] —[ end trace e4ccbf8c3a42e96a ]—
<4>[ 42.538895] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<3>[ 42.539965] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 42.539978] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 42.540086] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 42.540699] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 42.540800] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<3>[ 42.542755] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 42.542770] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 42.542811] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 42.542909] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 42.543254] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<4>[ 42.543468] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<3>[ 42.545682] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 42.545699] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 42.735968] D1:camsys_mrv_iommu_cb(276): map fd 36 ,client fd 39
<4>[ 42.735968]
<6>[ 42.735998] rk_iommu ff914000.isp_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x2e2af000
<4>[ 42.761562] D1:camsys_mrv_iommu_cb(276): map fd 43 ,client fd 39
<4>[ 42.761562]
<6>[ 42.761581] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
<4>[ 42.786783] D1:camsys_mrv_iommu_cb(276): map fd 45 ,client fd 39
<4>[ 42.786783]
<6>[ 42.786804] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
<4>[ 42.813064] D1:camsys_mrv_iommu_cb(276): map fd 49 ,client fd 39
<4>[ 42.813064]
<6>[ 42.813082] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
<4>[ 42.876437] D1:camsys_rk3288_mipihpy_cfg(109): mipi phy 1 standby!
<3>[ 42.876453] W:camsys_phy_ops(478): mipiphy->phy_index(-1198523284) != extdev->phy.info.mipi.phy_index(1)!
<4>[ 42.876667] D1:camsys_rk3288_mipihpy_cfg(219): mipi phy(1) turn on(lane: 0x3 bit_rate: 600Mbps)
<4>[ 43.040137] D1:camsys_rk3288_mipihpy_cfg(109): mipi phy 1 standby!
<4>[ 43.042621] D1:camsys_mrv_iommu_cb(276): map fd 49 ,client fd 39
<4>[ 43.042621]
<6>[ 43.043052] rk_iommu ff914000.isp_mmu: (isp_mmu) 3 times left to be disabled
<3>[ 43.043063] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 2e2af000 delayed
<4>[ 43.043609] D1:camsys_mrv_iommu_cb(276): map fd 45 ,client fd 39
<4>[ 43.043609]
<6>[ 43.044029] rk_iommu ff914000.isp_mmu: (isp_mmu) 2 times left to be disabled
<3>[ 43.044037] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 2e2af000 delayed
<4>[ 43.044545] D1:camsys_mrv_iommu_cb(276): map fd 43 ,client fd 39
<4>[ 43.044545]
<6>[ 43.044968] rk_iommu ff914000.isp_mmu: (isp_mmu) 1 times left to be disabled
<3>[ 43.044977] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 2e2af000 delayed
<4>[ 43.045495] D1:camsys_mrv_iommu_cb(276): map fd 36 ,client fd 39
<4>[ 43.045495]
<4>[ 43.047300] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 43.048033] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 43.050611] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 43.050902] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<3>[ 43.051990] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 43.052005] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 43.054051] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 43.054168] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 43.054257] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 43.054345] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<3>[ 43.055418] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 43.055431] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 43.055482] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 43.055498] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 43.055504] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 43.055513] D1:camsys_release(763): camsys_marvin(ee38b310) is closed
<4>[ 43.133608] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 43.133622] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 43.133630] D1:camsys_open(739): camsys_marvin(ee38b310) is opened!
<4>[ 43.133953] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 420000000 Hz) in turn on
<4>[ 43.133966] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 43.134070] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 43.134080] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 43.134178] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 43.136240] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 43.450992] D1:camsys_mrv_iommu_cb(276): map fd 46 ,client fd 33
<4>[ 43.450992]
<6>[ 43.451035] rk_iommu ff914000.isp_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x2e2af000
<4>[ 43.451736] D1:camsys_mrv_iommu_cb(276): map fd 47 ,client fd 33
<4>[ 43.451736]
<6>[ 43.451755] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
<4>[ 43.452644] D1:camsys_mrv_iommu_cb(276): map fd 48 ,client fd 33
<4>[ 43.452644]
<6>[ 43.452663] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
<4>[ 43.453463] D1:camsys_mrv_iommu_cb(276): map fd 49 ,client fd 33
<4>[ 43.453463]
<6>[ 43.453482] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
<4>[ 43.454096] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
<3>[ 43.454117] W:camsys_phy_ops(478): mipiphy->phy_index(-1197954508) != extdev->phy.info.mipi.phy_index(0)!
<4>[ 43.454331] D1:camsys_rk3288_mipihpy_cfg(219): mipi phy(0) turn on(lane: 0xf bit_rate: 648Mbps)
<4>[ 43.569287] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
<4>[ 43.569811] D1:camsys_mrv_iommu_cb(276): map fd 49 ,client fd 33
<4>[ 43.569811]
<6>[ 43.569917] rk_iommu ff914000.isp_mmu: (isp_mmu) 3 times left to be disabled
<3>[ 43.569927] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 2e2af000 delayed
<4>[ 43.570201] D1:camsys_mrv_iommu_cb(276): map fd 48 ,client fd 33
<4>[ 43.570201]
<6>[ 43.570297] rk_iommu ff914000.isp_mmu: (isp_mmu) 2 times left to be disabled
<3>[ 43.570306] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 2e2af000 delayed
<4>[ 43.570565] D1:camsys_mrv_iommu_cb(276): map fd 47 ,client fd 33
<4>[ 43.570565]
<6>[ 43.570661] rk_iommu ff914000.isp_mmu: (isp_mmu) 1 times left to be disabled
<3>[ 43.570672] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 2e2af000 delayed
<4>[ 43.570899] D1:camsys_mrv_iommu_cb(276): map fd 46 ,client fd 33
<4>[ 43.570899]
<4>[ 45.129085] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 45.129131] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 45.129144] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.129152] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 45.129161] D1:camsys_release(763): camsys_marvin(ee38b310) is closed
<4>[ 46.862541] Current WiFi chip is AP6210.
<4>[ 47.247036] Current WiFi chip is AP6210.
<4>[ 47.249216] Current WiFi chip is AP6210.
<6>[ 47.271964] [BT_RFKILL]: bt shut off power
<36>[ 47.469125] type=1400 audit(1293883548.450:6): avc: denied { write } for pid=1665 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12615 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
<6>[ 47.882101] [BT_RFKILL]: ENABLE UART_RTS
<6>[ 47.990276] [BT_RFKILL]: DISABLE UART_RTS
<6>[ 47.990326] [BT_RFKILL]: bt turn on power
<4>[ 48.679666] 0,baud is:9600
<4>[ 48.679729] 0,baud is:9600
<4>[ 48.679759] 0,baud is:115200
<4>[ 48.685890] 0,baud is:1500000
<4>[ 48.719686] Current WiFi chip is AP6210.
<4>[ 49.305062] 0,baud is:115200
<4>[ 49.508486] 0,baud is:1500000
<6>[ 50.096033] [BT_RFKILL]: bt shut off power
<4>[ 68.007331] pcd_pullup, is_on 0
<11>[ 68.016186] init: untracked pid 464 killed by signal 1
<6>[ 68.027780] read descriptors
<6>[ 68.027895] read strings
<4>[ 68.028038] pcd_pullup, is_on 1
<4>[ 68.477370] soft reconnect
<4>[ 68.657434] Using Buffer DMA mode
<4>[ 68.657454] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 68.657462] Multiprocessor Interrupt Enhancement - disabled
<4>[ 68.657470] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 68.657478] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 68.657521] soft connect!!!
<4>[ 68.756391] USB RESET
<6>[ 68.864537] android_usb gadget: high-speed config #1: android
<6>[ 68.866240] android_work: sent uevent USB_STATE=CONFIGURED
Please help me resolve this issue.
Thanks
please show the result of “df -lh” in shell.
The content of the article is rich and logical, and it has given me many ideas. Get the 300-810 Pass4sure study materials exam questions for free—wishing you all the best in your exams!
