I have noticed that from time to time, the RK3399 will show distorted/corrupted graphics. Once device is reset, it is not function for some time. Attempt various workaround, multiple power cycle, disconnect all connectors but power, manual MASKROM flash boot, never obtain loader.
I discovered that my board has a physical issue. Heat/cold affected functionality. Later I discovered that applying slight pressure to the Rockchip restores functionality. Bad solder joints? broken traces? not sure. In the case of bad solder joints, can’t i just take a heat gun to the board? or will that cook/damage the board?
This is such a brilliant article, thank you for sharing your perspective. Free Valid C-TS462-2023 exam fee questions for everyone. Wishing you success in your exams!
I’m sincerely grateful for your article, it left a strong impression. The comprehensive content in CMMC-CCP new test cram sheet file is offered free, hoping it helps your progress.
This article has given me a lot of space for reflection, and I’ve gained a lot. The Latest 300-435 examprep questions are free! Best of luck with your exams and preparations!
만약 시험만 응시하고 싶으시다면 우리의 최신Oracle 1z1-809자료로 시험 패스하실 수 있습니다. Pass4Test 의 학습가이드에는Oracle 1z1-809인증시험의 예상문제, 시험문제와 답 임으로 100% 시험을 패스할 수 있습니다.우리의Oracle 1z1-809시험자료로 충분한 시험준비하시는것이 좋을것 같습니다. 그리고 우리는 일년무료 업데이트를 제공합니다.
