[Issue] Mali GPU not working in ubuntu
Hello, the Mali GPU does not work in ubuntu, I tried to flash the latest image “Firefly-RK3399_Android6.0_201702281427.img” but image will not flash.
I inspected ubuntu4.img, and inspected /etc/init.d/rockchip.sh, it references “libmali-rk-midgard-r13p0-r0p0_1.5-4_armhf.deb” and “libmali-rk-dev_1.5-4_armhf.deb” which can be found at https://github.com/rockchip-linux/rk-rootfs-build/tree/master/packages/armhf/libmali but these DEBs are not avail for arm64.
I attempted to install the ones in the arm64 folder on GitHub, but I softbrick Firefly-RK3399
Any ideas?
check this:
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=1876&extra=page%3D1
Yes, I have tried to flash that image in both linux, and windows. In windows, download firmware fails at 22%. in linux it fails at 708769K.
I will try again
Ok, its working now, seems to have been the board issue i mentioned in another post, I will use heat gun soon to attempt fix.
I’m so impressed by your article, thank you for your amazing share! Valid C_P2WBW_2505 test sample provides excellent materials, and they are free to access.
