[Fireprime] OTA is possible?
Hi,
I’m now using 3128 Lollipop 5.1 version.
I want to use OTA to upgrade Android system parts.
I followed your documenet to produce OTA packages.
But I have got compile errors.
make clean
make -j4
make otapackage
I got errors.
I need help to fix thses errors.
Thank you in advance.
host Executable:fs_config(out/host/linux-x86/obj32/EXECUTABLES/fs_config_intermediates/fs_config)
Install:out/host/linux-x86/bin/fs_config
No RK Loader forTARGET_DEVICE rk312x to otapackage
package addresource.img to BOOT and RECOVERY
No uboot foruboot/uboot.img to otapackage
No trust foruboot/trust.img to otapackage
No charge foruboot/charge.img to otapackage
No parameter forTARGET_DEVICE rk312x to otapackage
Package target files:out/target/product/rk312x/obj/PACKAGING/target_files_intermediates/rk312x-target_files-eng.jsmoon.zip
building image fromtarget_files RECOVERY…
Traceback (mostrecent call last):
File"./build/tools/releasetools/make_recovery_patch", line 68, in
main(sys.argv[1:])
File"./build/tools/releasetools/make_recovery_patch", line 39, in main
input_dir, “RECOVERY”)
File"/home/jsmoon/work/prj_wallpad/fireprime_emmc/build/tools/releasetools/common.py",line 419, in GetBootableImage
info_dict)
File"/home/jsmoon/work/prj_wallpad/fireprime_emmc/build/tools/releasetools/common.py",line 376, in BuildBootableImage
p4= Run(sign_cmd)
File"/home/jsmoon/work/prj_wallpad/fireprime_emmc/build/tools/releasetools/common.py",line 86, in Run
return subprocess.Popen(args, **kwargs)
File"/usr/lib/python2.7/subprocess.py", line 710, in init
errread, errwrite)
File"/usr/lib/python2.7/subprocess.py", line 1327, in _execute_child
raise child_exception
OSError: [Errno 2] Nosuch file or directory
make: ***[out/target/product/rk312x/obj/PACKAGING/target_files_intermediates/rk312x-target_files-eng.jsmoon.zip]오류 1
#### make failed tobuild some targets (03:33 (mm:ss)) ####
do you have the latest sdk?
or try this patch:
projects / tvbox-51.git / commitdiff
? search:
re
summary | shortlog | log | commit | commitdiff | tree
raw | patch (parent: 37383c6)
Android->OTA:modify OTA complie issue
author cjp <service@t-firefly.com>
Tue, 23 Feb 2016 08:27:39 +0000 (16:27 +0800)
committer cjp <service@t-firefly.com>
device/rockchip/common/releasetools.py patch | blob | history
diff --git a/device/rockchip/common/releasetools.py b/device/rockchip/common/releasetools.py
index 83e75b9..38399c8 100755 (executable)
— a/device/rockchip/common/releasetools.py
+++ b/device/rockchip/common/releasetools.py
@@ -134,8 +134,8 @@ def IncrementalOTA_InstallEnd(info):
InstallTrust(trust_target, info.target_zip, info)
else:
print “trust unchanged; skipping”
  • try:
  • try:
    loader_uboot_target = info.target_zip.read(“uboot.img”)
    except KeyError:
    loader_uboot_target = None
I got solved!!
Thank you!
Through this article, my work thinking has significantly improved. Free GES-C01 exam book exam questions—your key to career growth and a better salary!
I’m grateful to have come across such a fantastic article. The rich resources in Exam SAFe-Practitioner certification cost are provided at no cost to enhance your understanding.
This article is simply breathtaking, thank you for sharing it with us! I used the New H19-619_V1.0 exam practice to get promoted and get a pay raise. Now it’s free to all. I hope you all get promoted soon!
This article is absolutely stunning, I appreciate you sharing it. The Latest exam camp 401 free exam papers are free for all! Best of luck to everyone!
This article is outstanding, thank you for letting us read it. Here’s the Reliable MB-700 exam camp materials test material for free. Best of luck in your exams!
