OV13850 AF algorithm
Hi Folks,
I wanted to change the speed of AF algorith in OV13850 camera. The current speed (when streaming 1080p-video) is 67 ms between each consective steps by the VCM (8 steps in total form 10 cm to inifinite postion of the VCM). Though, the streaming is 30 fps at this resolution, but the AF fps are half of that (15 fps, 67 ms), which means that there is frame skipping when implementing AF.
I belive to the change the AF speed I have to have access to the code of (libisp_silicomimageisp_api.so) in the following directoryfirefly-rk3288\hardware\rk29\camera\Config.
Could any one help me to confrim the source code of the .so file is avaialbe? or where can I change such AF speed for OV13850, which file I should make the changes?
Your prompt response is highly appreciated.
try to change the fps in the “OV13850.xml” file.
Hi Sheba, Isle,
I also would like to modify the autofocus algorithm.
I’d like to experiment the assistance of a distance sensor to optimize autofocus.
How can we get the libisp_silicomimageisp_api.so source code ?
This article is truly outstanding, thank you for sharing. Free VMA latest exam name study resources available for all—good luck!
I feel so inspired after reading this article, thank you for the share! New B2C-Commerce-Architect learning materials offers valuable insights, and it’s all free.
What an extraordinary article, I’m truly thankful for your share! Grab your free Valid examcollection AZ-500 test questions—promotion and salary increases await!
Avayaの77202T証明書は優れていますが、毎年正常に取得できる人はまれであり、77202T試験の難しさと学習のプレッシャーにより、生徒は落胆します。 しかし、私たちCertShikenにとって、これらはもはや問題ではありません。 過去数年間、私たちのチームは何百もの業界の専門家を招き、昼夜を問わず数々の課題を経験し、最終的に完全な学習製品を形成しました。77202T試験トレントは、Avaya IP Office™ Platform Implement Online Test証明書。
What a fantastic article, thank you for sharing such an amazing piece! Get the OGEA-101 interactive questions questions that helped me get promoted and earn more—offered to you for free!
