System freezing when replaced with another eMMC
How to reproduce:
- Replace the original 32GB Samsung eMMC with another manufacturer’s eMMC
- Download Firefly-RK3399_Android6.0_201703181519.img using AndroidTool
- After downloading and rebooting, the system will freeze after proceeding to the following kernel log.(Attached the full log.)> …
[ 1.715125] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.717158] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.718873] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.721783] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.733657] u?
[ 1.782257] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
I have tested eMMCs from other manufacturers (Sandisk, Micron, Hynix Toshba, etc.) but all have the same problem except for the original soldered eMMC.
It is the same symptom in other types of memory even made by Samsung.
Somebody please help me.
teraterm_20170420_172652_recovery.zip (14.7 KB)
I modified the mmc driver to print all eMMC commands.
As a result, I confirmed that the system had access to the RPMB area of eMMC at the point of the problem.
Does the platform check the authenticated eMMC to limit its operation?
[ 1.571560] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.573428] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.575325] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.578638] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.587821] mmc1: CMD(6) = 0x03B30301 <== Select RPMB Area
[ 1.587946] mmc1: CMD(13) = 0x00010000
[ 1.588021] mmc1: CMD(13) = 0x00010000
[ 1.588143] mmc1: CMD(25) = 0x00000000
[ 1.588276] mmc1: CMD(13) = 0x00010000
[ 1.588421] mmc1: CMD(18) = 0x00000000 < read somthing
[ 1.588735] mmc1: CMD(13) = 0x00010000
[ 1.588923] mmc1: CMD(6) = 0x03B30001 <== Select RPMB Area
[ 1.589101] mmc1: CMD(13) = 0x00010000
was the issue resolved?
I came across the same issue, and please teach me how to modify mmc driver to print all emmc commands
Your article was incredibly impactful, thank you for this insight. The FCSS_SDW_AR-7.4 Testking learning materials content is very good, and it’s available to everyone for free.
This article has truly been inspiring, thanks for sharing! Best of luck to everyone! The Valid HPE7-A03 test camp pdf exam papers are now shared for free!
PassTIP에서 제공해드리는 SAP인증 C_S4FCF_2023덤프는 가장 출중한SAP인증 C_S4FCF_2023시험전 공부자료입니다. 덤프품질은 수많은 IT인사들로부터 검증받았습니다. SAP인증 C_S4FCF_2023덤프뿐만아니라 PassTIP에서는 모든 IT인증시험에 대비한 덤프를 제공해드립니다. IT인증자격증을 취득하려는 분들은PassTIP에 관심을 가져보세요. 구매의향이 있으시면 할인도 가능합니다. 고득점으로 패스하시면 지인분들께 추천도 해주실거죠?
