Hello, I defined a mount point in /etc/fstab and does not start and I do not get the terminal to get the mount point, how can I fix the problem?
show us your “/etc/fstab” file .
isle Posted at 4/24/2017 15:49
It does not start, the screen turns on and goes black, but it does not show me anything else
What I can do?
get the X log in '/var/log/Xorg.0.log" from uart. then post it up.
isle Posted at 4/28/2017 10:42
How do I do it? If you don’t let me do anything, I don’t start any OS
Sounds stupid but touch any key on the keyboard and I shut down the screen and start linux and I could get the mount point that was in /etc/fstab
about serial debug :
http://wiki.t-firefly.com/index.php/Firefly-RK3288/Serial_debug/en
This article is a gem, thank you for sharing it with us! Best of luck in your exams! Valid test L5M6 format questions are available for free!
Fast2test는 고객님께서 첫번째Cisco 100-140-KR시험에서 패스할수 있도록 최선을 다하고 있습니다. 만일 어떤 이유로 인해 고객이 첫 번째 시도에서 실패를 한다면, Fast2test는 고객에게Cisco 100-140-KR덤프비용 전액을 환불 해드립니다.환불보상은 다음의 필수적인 정보들을 전제로 합니다.
Das IT-Expertenteam von ZertPruefung haben eine kurzfristige Schulungsmethode nach ihren Kenntnissen und Erfahrungen bearbeitet. Diese Dumps könne Ihnen effektiv helfen, in kurzer Zeit den erwarteten Effekt zu erzielen, besonders für diejenigen, die arbeiten und zuleich lernen. ZertPruefung kann Ihnen viel Zeit und Energir ersparen. Wählen Sie ZertPruefung und Sie werden Ihre wünschten Schulungsmaterialien zur Salesforce Mule-Arch-202 Zertifizierungsprüfung bekommen.
