Technical briefing for Firefly-RK3399 Android7.1 Updates firmware and Codes
Android7.1 update
  1. Support HDMI, DP dual display, support different features
  2. support tf card, remote control, headphones, microphone, spdif, Gigabit Ethernet, wifi, Bluetooth, mipi camera, dvp camera, PCIe SSD / SATA, 7.85eDP display, usb3.0, 4G module.
    USB3.0 test speed
    USB3.0 theoretical value can reach 500M / s, using high-speed USB3.0 storage disk to test as a example:
    read speed 270.3M/
write speed 329.0M/s
UI:
Android7.1 AnTuTu score is higher higher 10,000 points than Android6.0 system version
please log in Baidu Pan to download Android SDK,and upgrade to the latest commit:c77e39c Init the Firefly-RK3399 7.1 SDK
gitlab git@gitlab.com:TeeFirefly/FireNow-Nougat.git
Update codes:
git pull gitlab firefly-rk3399:firefly-rk3399
Download the latest firmware:
Google Drive
JDK Installation
sudo add-apt-repository ppa:openjdk-r/ppa
sudo apt-get update
sudo apt-get install openjdk-8-jdk</font>
Default compilation :HDMI+DP
./FFTo</font></font>ols/make.sh -j8
./FFTools/mkupdate/mkupdate.sh</font>
Compile EDP7.85
./FFTools/make.sh -j8 -d rk3399-firefly-edp -l rk3399_firefly_edp_box-userdebug
./FFTools/mkupdate/mkupdate.sh -l rk3399_firefly_edp_box-userdebug</font>
Website: http://www.t-firefly.com
Wiki: http://wiki.t-firefly.com
Community: http://developer.t-firefly.com
Buy: https://t-firefly.taobao.com/
Technical Group (QQ): 431139193 | 586343230
I used Android 7.1 img file.
There is no menu about mobile network in setup menu.
I hope that I can see new firmware with eDP and good working mobile network (NO ROAMING AT HOME) version ASAP.
Thx.
First off, thanks for sharing the code.
To id2ego (and others), I’ve got a build for eDP from the FireNow-Nougat repository. 7.85" touchscreen working well, haven’t tried the 4G module yet. Could probably put this image somewhere people can get it from. Cheers.
exyn Posted at 6/8/2017 00:07
To id2ego (and others), I’ve got a build for eDP from the …
Thx. I had already used the image.
But, It’s same problem that can’t use mobile networks.
Anyway…
May I ask you something?
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=1926&extra=page%3D1
If you can solve this problem, please let me know.
Thx.
I’m amazed by this article, thank you for sharing it. Hope the PCEP-30-02 reliable vce test simulator exam goes smoothly – wish me luck!
Thank you for the article, it really broadened my outlook. I hope the Latest exam CNX-001 certification cost content helps you, and it’s totally free.
I’m truly amazed by your article, thank you for your generosity! Here’s the free Reliable real exam CIS-RCI questions and answers material for everyone. Good luck!
