Attempting to shutdown the board causes it to reboot. Is there a fix for this? I can be reproduced by issuing the following command:
sudo shutdown -h now
please update the kernel/resource image by the latest source code
http://wiki.t-firefly.com/index.php/Firefly-RK3399/Build_kernel/en
then try again.
Using the latest kernel, the problem remains. The device reboots instead of powering down.
really? but, I have check it is power down,not reboot.
The issue occurs using the “Firefly-rk3399_xubuntu1604_201705111112.7z” image from download page:
https://drive.google.com/drive/folders/0B7HO8lbGgAqAX2oyZkg2QVQwZjA
Did you have this issue when using the latest kernel ? ![]()
Yes, the issue occurs using both the kernel in the image mentioned and the latest kernel compiled from source.
Is this uboot reversion related to the issue?
https://gitlab.com/TeeFirefly/uboot/commit/d557a4163f00215ab1a3254c43cb8ae1a4823ee8
Revert "plat: rk3399: add virtual poweroff support"
Change-Id: I59231ba6280c0e4e89cf61704701c03a3a287c5e
Signed-off-by: shengfei Xu <xsf@rock-chips.com>
I have the same issue. Now I just use
sudo halt
Seems to be related to poweroff and ACPI stuff indeed…
The same issue here with Ubuntu - with latest kernel compiled from the source codes.
Same here, the shutdown/poweroff commands causes reboot. I’m using the latest image in Baidu Pan: Firefly-rk3399_xubuntu1604_201707041527.7z
I’m also having problem when I try to boot the system from MMC with a SDCard inserted into TFCard slot. The system don’t boot in this case.
Are there some fixes to these problems?
This article is a true masterpiece, thank you for sharing. New composite test DA0-001 offers outstanding content, all for free.
I really appreciate your article, it has deeply impacted me. Improve your IT skills and access free Reliable PEGACPSA24V1 dumps book. Wishing you the best of luck!
I can’t thank you enough for your article, it really made an impression. Boost your IT knowledge with free L5M6 valid test simulator online. Wishing you success in your exams!
It’s truly astonishing, thank you for the share! Strengthen your IT skills with free Detailed C-THR89-2505 study plan. Wishing you the best of luck!
It really broadened my horizons. Here’s the PEGACPDC25V1 valid soft simulations test that got me promoted and raised. Today, it’s free for everyone! Hope you achieve your professional goals!
Your article was a pleasant surprise, thank you for sharing it. With the help of this Manufacturing-Cloud-Professional reliable exam cram, I earned a promotion and salary increase. Now I’m offering it for free. Wishing you all the best in your career!
