After connected USB3 screen, boot problem
Hi,
For a new project, we are trying to use a RK3399 cards. We like it for the DP port in 60 fps.
We are using Ubuntu Firefly-rk3399_xubuntu1604_201705111112 image.
So, when I connect a HD screen in HDMI, no problem.
If I connect a 4k screen with USB3 to Displayport, nothing appear. OK, perhaps need reboot.
After reboot, i loose the graphic interface of Ubuntu.
But after that, impossible to come back to graphic interface. Only solution, reflash.
Do you have any idea ?
And, how to activated properly the Dpe port to have 4k display ?
Regards
This is the same issue I reported in a different thread. If you connect a 4K monitor to USB-C, the board will not boot. Only a 1080p will work.
  1. shutdown
  2. connect a 1080p display to USB-C
  3. power on the board
Attaching a USB-C display while the board is running does not work. Attaching a 4K display to USB-C does not work. Attaching a 4K display to HDMI only works at 1080p. In summary, at this time, there is no 4K support for this board. Hopefully, this issue will get fixed.
OK thanks.
I have no USB C 1080 monitor so impossible to have graphic interface running after connecting a USB c 4k monitor.
If I connect a hdmi after, only CLI interface
In HMDI, I can go to 2560*1440 with a 4k.
I will wait..
Did you have to use a special HDMI cable for 2560*1440? I am getting a USB-C to HDMI adapter shortly and would like to know how this would work.
The article is very rich in content and has introduced me to many new perspectives. Mule-Arch-201 latest test cram sheet provides a range of useful materials for free, hoping they help you progress.
I’m in awe of your article, thank you so much for sharing! The AT-510 exam discount system helped me secure a promotion and salary increase. Now, I’m sharing it for free. Best of luck in your career!
Wenn Sie sorgen darum, dass die Vorbereitungszeit für Linux Foundation KCNA nicht genug ist oder wie die autoritative Prüfungsunterlagen finden können, dann können Sie ganz beruhigt sein. Wir EchteFrage bieten Ihnen die neuesten Prüfungsunterlagen der Linux Foundation KCNA, die Ihnen helfen können, innerhalb einer kurzen Zeit auf die Linux Foundation KCNA Prüfung vorbereitet zu sein. Wir besitzen die autoritativen Prüfungsunterlagen sowie erfahrens und verantwortungsvolles Team. Das Ziel aller Bemühungen von uns ist, dass Sie die Linux Foundation KCNA Prüfung unbelastet bestehen.
