Ubuntu Ethernet connection unavailable
I bought the second RK3399 4Gb card and can not configure the network.
On the first board (I bought it 2 month ago), everything was OK.
Initially, there was an android. In the android everything is OK (wifi and ethernet work perfectly), so I think that is software problem or you changed some hardware and didn’t update ubuntu image.
I installed Firefly-rk3399_xubuntu1604_201704271809.
WIFI is working. I made all possible tests for the ethernet nearptwork. I found nothing strange.
“ping” and “traceroute” hangs, “arp” show default gateway if i input static ip address in Network Manager
I found that sometimes the MAC address of eth0 changes. Can be on different firmware, but I’m not sure.
I can provide any information you need.
please refer : https://gitlab.com/TeeFirefly/linux-kernel/commit/d0ad8bcdd913ef2b0222fb790c9f88dfc08fc1e5
you need make the kernel.img and update it.
http://wiki.t-firefly.com/index.php/Firefly-RK3399/Build_kernel/en
Thx, for help. I got compilation error when i compiled on the Firefly board. On my Ubuntu desktop compilation success.
OBJCOPY arch/arm64/boot/Image
./scripts/mkkrnlimg: 1: ./scripts/mkkrnlimg: Syntax error: “(” unexpected
arch/arm64/Makefile:144: recipe for target ‘kernel.img’ failed
make: *** [kernel.img] Error 2
I not understand how to change offset of Kernel Partition. I can’t update kernel.img by Android Tool. When i unpacked firware I got only that files:
master@server:~/Kernel/image$ img_unpack Firefly-RK3399_Ubuntu16.04_201703181519.img img
rom version: 6.0.1
build time: 2017-03-18 15:20:22
chip: 33333043
checking md5sum…OK
master@server:~/Kernel/image/img$ afptool -unpack update.img update
Check file…OK
------- UNPACK -------
package-file 0x00000800 0x000000FD
RKLoader.bin 0x00001000 0x0003E94E
parameter 0x00040000 0x00000290
trust.img 0x00040800 0x00400000
uboot.img 0x00440800 0x00400000
linux-boot.img 0x00840800 0x01344000
linux-rootfs.img 0x01B84800 0xBDC00000
RESERVED 0x00000000 0x00000000
update-script 0xBF784800 0x000003A5
recover-script 0xBF785000 0x0000010A
How can I update kernel.img on my Firefly board?
oh, please unpack the version of 201705111112.img .that is the latest firmware.
First of alI I flashed device last firware 201705111112
  1. Next I unpacked 201705111112.img
package-file 0x00000800 0x0000013D
rk3399_loader_v1.07.105.bin 0x00001000 0x0003E94E
parameter 0x00040000 0x0000022A
linux-kernel.img 0x00840800 0x01192E4C
linux-resource.img 0x019D3800 0x0003FA00
ubuntu1604arm64-rootfs.img 0x01A13800 0x87AF2000
update-script 0x89505800 0x00000416
recover-script 0x89506000 0x0000010A
UnPack OK!
  1. Changed adresses in android tool at first tab
  2. Selected compiled images
     kernel.img
     resource.img
  3. Click Run (flashing..ok)
After that Ubuntu can’t start.
Other way
I replaced the files: linux-kernel.img, linux-resource.img
with my own and pack new release firware by this link http://wiki.t-firefly.com/index. … en#Extract_Firmware
After i flashed new firware Ubuntu not load correctly (Black screen).
Welcome to Ubuntu 16.04.2 LTS!
[    1.809040] systemd[1]: Set hostname to <firefly>.
[    1.836811] random: systemd: uninitialized urandom read (16 bytes read, 28 bi                                                     ts of entropy available)
[    1.841980] wifi_platform_bus_enumerate device present 1
[    1.842459] ======== Card detection to detect SDIO card! ========
[    1.842858] random: systemd-cryptse: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
[    1.843928] mmc2:mmc host rescan start!
[    1.850603] random: systemd-sysv-ge: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
[    1.854268] random: systemd-gpt-aut: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
[    1.855401] random: systemd-gpt-aut: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
[    1.856356] random: systemd-gpt-aut: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
[    1.856468] random: systemd-sysv-ge: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
[    1.858484] random: systemd-gpt-aut: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
[    1.876276] vendor storage:20160801 ret = 0
[    2.017199] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    2.018617] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    2.019412] systemd[1]: Reached target Encrypted Volumes.
[  OK  ] Reached target Encrypted Volumes.
[    2.020374] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    2.021337] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    2.022516] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    2.023405] systemd[1]: Started Forward Password Requests to Wall Directory W                                                     atch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    2.024561] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    2.025784] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    2.028195] systemd[1]: Starting Remount Root and Kernel File Systems...
[    2.031736] systemd[1]: Starting Create Static Device Nodes in /dev...
[    2.035330] systemd[1]: Mounting Debug File System...
[    2.041457] systemd[1]: Starting Load Kernel Modules...
[    2.043389] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    2.051429] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    2.054111] systemd[1]: Starting Journal Service...
[    2.058155] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    2.060663] systemd[1]: Starting Set console keymap...
[    2.061467] systemd[1]: Reached target User and Group Name Lookups.
[  OK  ] Reached target User and Group Name Lookups.
[    2.062683] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    2.063680] systemd[1]: Reached target Remote File Systems (Pre).
[  OK  ] Reached target Remote File Systems (Pre).
[    2.064971] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    2.070176] systemd[1]: Mounted Debug File System.
[  OK  ] Mounted Debug File System.
[    2.071854] systemd[1]: Started Remount Root and Kernel File Systems.
[  OK  ] Started Remount Root and Kernel File Systems.
[    2.077937] systemd[1]: Started Create Static Device Nodes in /dev.
[  OK  ] Started Create Static Device Nodes in /dev.
[    2.079573] systemd[1]: systemd-modules-load.service: Main process exited, co                                                     de=exited, status=1/FAILURE
[    2.081167] systemd[1]: Failed to start Load Kernel Modules.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[    2.082321] systemd[1]: systemd-modules-load.service: Unit entered failed sta                                                     te.
[    2.083400] systemd[1]: systemd-modules-load.service: Failed with result 'exi                                                     t-code'.
[    2.098661] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 233
[    2.104801] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[    2.105349] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[    2.123073] bcmsdh_register: register client driver
[    2.123679] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[    2.124239] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[    2.124660] bus num (host idx)=2, slot num (rca)=1
[    2.125102] found adapter info 'DHD generic adapter'
[    2.125579] sdioh_attach: set sd_f2_blocksize 128
[    2.126382] F1 signature read @0x18000000=0x17224356
[    2.130010] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[    2.131020] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[    2.131687] wifi_platform_get_mac_addr
[    2.132027] ======== bcm_wlan_get_mac_address ========
[    2.132476] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[    2.132956] [WLAN_RFKILL]: get_wifi_addr_vendor: rk_vendor_read wifi mac addr                                                     ess failed (-1)
[    2.133697] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[    2.134213] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmwa                                                     re/config.txt
[    2.136037] wl_create_event_handler(): thread:wl_event_handler:c7 started
[    2.136092] tsk Enter, tsk = 0xffffffc0ed241be8
[    2.137234] wl_escan_attach: Enter
[    2.137557] wl_escan_init: Enter
[    2.138094] wl_create_event_handler(): thread:wl_escan_handler:c8 started
[    2.138151] tsk Enter, tsk = 0xffffffc0ed2701b0
[    2.139237] dhd_attach(): thread:dhd_watchdog_thread:c9 started
[    2.139805] dhd_attach(): thread:dhd_dpc:ca started
[    2.139825] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[    2.140802] dhd_attach(): thread:dhd_rxf:cb started
[    2.141251] dhd_deferred_work_init: work queue initialized
[    2.142799] systemd[1]: Mounting Configuration File System...
[    2.145355] systemd[1]: Starting Apply Kernel Variables...
[    2.148122] systemd[1]: Mounting FUSE Control File System...
[    2.151035] systemd[1]: Starting udev Kernel Device Manager...
[    2.151597] Dongle Host Driver, version 1.363.59.144.1 (r)
[    2.152803] Register interface [wlan0]  MAC: ac:83:f3:9e:4a:6e
[    2.152803]
[    2.152853] wl_event_handler: was terminated
[    2.152965] wl_destroy_event_handler(): thread:wl_event_handler:c7 terminated                                                      OK
[    2.152971] dhd_wl_ioctl: returning as busstate=0
[    2.153693] bcmsdh_oob_intr_unregister: Enter
[    2.153695] bcmsdh_oob_intr_unregister: irq is not registered
[    2.153712] dhd_txglom_enable: enable 0
[    2.153716] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[    2.153717] dhd_conf_set_txglom_params: txglom_bucket_size=0
[    2.153719] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_                                                     txglom=0
         Starting Load/Save Random Seed...
         Starting udev Coldplug all Devices...
[  OK  ] Mounted Configuration File System.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Set console keymap.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
         Starting LSB: AppArmor initialization...
         Starting Set console font and keymap...
         Starting Tell Plymouth To Write Out Runtime Data...
[  OK  ] Started Journal Service.
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Tell Plymouth To Write Out Runtime Data.
[  OK  ] Started udev Kernel Device Manager.
[    2.274233] Unable to handle kernel NULL pointer dereference at virtual addre                                                     ss 00000000
[    2.275004] pgd = ffffffc0ed13d000
[    2.275302] [00000000] *pgd=0000000000000000, *pud=0000000000000000
[    2.275854] Internal error: Oops: 86000005 [#1] SMP
[    2.276279] Modules linked in:
[    2.276551] CPU: 5 PID: 241 Comm: udevadm Not tainted 4.4.55 #1
[    2.277065] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (                                                     DT)
[    2.277708] task: ffffffc0ed2d4980 ti: ffffffc0ed310000 task.ti: ffffffc0ed31                                                     0000
[    2.278359] PC is at 0x0
[    2.278585] LR is at _raw_spin_lock+0x20/0x2c
[    2.278964] pc : [<0000000000000000>] lr : [<ffffff8008baaf98>] pstate: a0000                                                     145
[    2.279605] sp : ffffffc0ed313b90
[    2.279893] x29: ffffffc0ed313b90 x28: ffffffc0ed310000
[    2.280359] x27: ffffff8008bc2000 x26: 000000000000004f
[    2.280823] x25: 000000000000011d x24: 0000000000000030
[    2.281289] x23: 0000000000000000 x22: ffffffc0ee5b86c0
[    2.281753] x21: 0000000000000000 x20: 0000000000000000
[    2.282219] x19: ffffffc0ee5b8718 x18: 0000000000000a03
[    2.282683] x17: 0000007fb685b230 x16: ffffff80081a9e6c
[    2.283147] x15: 0000000000000080 x14: 000000ff02010100
[    2.283611] x13: ffffffff00000000 x12: 0000000000000000
[    2.284075] x11: 0000000000040004 x10: 0000000000000000
[    2.284540] x9 : ffffffc0ed8e701c x8 : fefefefefefefeff
[    2.285006] x7 : 00000055c36b6d00 x6 : 0000000000000fe4
[    2.285470] x5 : 0000000000000003 x4 : 0000000000000000
[    2.285935] x3 : ffffff80090e5000 x2 : 00000000000000d6
[    2.286400] x1 : 0000000000000005 x0 : ffffffc0ed2d4980
[    2.286865]
[    2.286865] LR: 0xffffff8008baaf18:
[    2.287296] af18  8b000021 c802fe61 35ffffa2 d5033bbf 17ffffda a94153f3 a9425                                                     bf5 f9401bf7
[    2.288025] af38  a8c67bfd d65f03c0 a9be7bfd 910003fd f9000bf3 aa0003f3 aa1e0                                                     3e0 d503201f
[    2.288752] af58  aa1303e0 97d4e008 35000040 14000002 52800020 f9400bf3 a8c27                                                     bfd d65f03c0
[    2.289478] af78  a9be7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 d503201f aa130                                                     3e0 97d4dfa4
[    2.290206] af98  f9400bf3 a8c27bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa000                                                     3f4 aa1e03e0
[    2.290933] afb8  d503201f d53b4233 d50342df aa1403e0 97d4df97 aa1303e0 a9415                                                     3f3 a8c27bfd
[    2.291660] afd8  d65f03c0 a9be7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 d5032                                                     01f d50342df
[    2.292386] aff8  aa1303e0 97d4df8a f9400bf3 a8c27bfd d65f03c0 a9be7bfd 91000                                                     3fd f9000bf3
[    2.293115]
[    2.293115] SP: 0xffffffc0ed313b10:
[    2.293546] 3b10  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 00000                                                     11d 00000000
[    2.294272] 3b30  0000004f 00000000 08bc2000 ffffff80 ed310000 ffffffc0 ed313                                                     b90 ffffffc0
[    2.294998] 3b50  08baaf98 ffffff80 ed313b90 ffffffc0 00000000 00000000 a0000                                                     145 00000000
[    2.295725] 3b70  ee5b8718 ffffffc0 00000000 00000000 00000000 00000080 081b1                                                     9e4 ffffff80
[    2.296452] 3b90  ed313bb0 ffffffc0 08392990 ffffff80 ee5b8718 ffffffc0 081b0                                                     8e8 ffffff80
[    2.297179] 3bb0  ed313bd0 ffffffc0 081b0914 ffffff80 ed313cb0 ffffffc0 00000                                                     000 00000000
[    2.297906] 3bd0  ed313c10 ffffffc0 081b0f1c ffffff80 ed313cb0 ffffffc0 ee5b8                                                     6c0 ffffffc0
[    2.298633] 3bf0  ed313e10 ffffffc0 00000003 00000000 ed313e58 ffffffc0 00000                                                     015 00000000
[    2.299360]
[    2.299360] X0: 0xffffffc0ed2d4900:
[    2.299791] 4900  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.300518] 4920  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.301244] 4940  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.301970] 4960  00ff00ff 00ff00ff 00ff00ff 00ff00ff 00ff00ff 00ff00ff 00ff0                                                     0ff 00ff00ff
[    2.302697] 4980  00000000 00000000 ed310000 ffffffc0 00000002 00404100 00000                                                     000 00000000
[    2.303424] 49a0  00000000 00000000 00000001 000000e1 fffb7433 00000000 ef2fd                                                     5c0 ffffffc0
[    2.304151] 49c0  00000005 00000001 00000078 00000078 00000078 00000000 08bc8                                                     548 ffffff80
[    2.304878] 49e0  00000400 00000000 00400000 00000000 00000001 00000000 00000                                                     000 00000000
[    2.305606]
[    2.305606] X3: 0xffffff80090e4f80:
[    2.306037] 4f80  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.306763] 4fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.307489] 4fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.308215] 4fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.308941] 5000  00000e12 00000e12 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.309668] 5020  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.310394] 5040  05600000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.311120] 5060  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.311847]
[    2.311847] X9: 0xffffffc0ed8e6f9c:
[    2.312278] 6f9c  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.313004] 6fbc  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.313730] 6fdc  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.314456] 6ffc  00000000 ed8e701c ffffffc0 c36b6d00 00000055 00000000 00000                                                     000 00000001
[    2.315183] 701c  7379732f 79730000 616c702f 726f6674 65642f6d 65636976 66662                                                     f73 66336638
[    2.315910] 703c  692e3030 756d6d6f 00746500 00000000 65747379 0000006d 6f746                                                     16c 464f0a72
[    2.316637] 705c  4d4f435f 49544150 5f454c42 65723d30 616c7567 2d726f74 65786                                                     966 464f0a64
[    2.317364] 707c  4d4f435f 49544150 5f454c42 0a313d4e 41444f4d 5341494c 3a666                                                     f3d 6363764e
[    2.318092]
[    2.318092] X13: 0xfffffffeffffff80:
[    2.318530] ff80  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
[    2.319262] ffa0  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
[    2.319991] ffc0  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
[    2.320721] ffe0  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
[    2.321450] 0000  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
[    2.322179] 0020  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
[    2.322908] 0040  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
[    2.323638] 0060  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
[    2.324367]
[    2.324367] X16: 0xffffff80081a9dec:
[    2.324806] 9dec  aa1e03e0 aa0103f3 d503201f aa1403e0 9100a3a1 97ffff0d 35000                                                     080 9100a3a0
[    2.325533] 9e0c  aa1303e1 97ffff27 93407c00 a94153f3 a8c97bfd d65f03c0 a9b77                                                     bfd 910003fd
[    2.326259] 9e2c  a90153f3 aa0003f4 aa1e03e0 aa0103f3 d503201f aa1403e0 9100a                                                     3a1 97ffff0a
[    2.326985] 9e4c  35000080 9100a3a0 aa1303e1 97ffff15 93407c00 a94153f3 a8c97                                                     bfd d65f03c0
[    2.327711] 9e6c  a9b67bfd 910003fd a90153f3 aa0003f4 aa1e03e0 f90013a1 aa020                                                     3f3 f90017a3
[    2.328438] 9e8c  d503201f f94013a1 2a1403e0 f94017a3 9100e3a2 97fffeb5 35000                                                     080 9100e3a0
[    2.329165] 9eac  aa1303e1 97fffeff 93407c00 a94153f3 a8ca7bfd d65f03c0 a9b77                                                     bfd 910003fd
[    2.329892] 9ecc  a90153f3 aa0003f4 aa1e03e0 aa0103f3 d503201f 2a1403e0 9100a                                                     3a1 97fffe89
[    2.330620]
[    2.330620] X19: 0xffffffc0ee5b8698:
[    2.331058] 8698  ee5ba408 ffffffc0 ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000                                                     000 00000000
[    2.331784] 86b8  00000000 00000000 00200000 00000002 00000000 00000000 00000                                                     000 00000000
[    2.332511] 86d8  ee5b86c0 ffffffc0 00000000 00000001 ee5b86f8 ffffffc0 ed630                                                     000 ffffffc0
[    2.333237] 86f8  0000002f dead4ead ffffffff 00000000 ffffffff ffffffff 00000                                                     000 00000000
[    2.333964] 8718  64af64ae dead4ead 00000005 00000000 ed2d4980 ffffffc0 00000                                                     00a 00000000
[    2.334691] 8738  00000000 00000000 edde2000 ffffffc0 00000000 dead4ead ef0ee                                                     000 ffffffc0
[    2.335417] 8758  ee5b8758 ffffffc0 ee5b8758 ffffffc0 ee5b8768 ffffffc0 ee5b8                                                     768 ffffffc0
[    2.336144] 8778  ee5e2408 ffffffc0 ee5b8840 ffffffc0 00000000 00000000 ed630                                                     148 ffffffc0
[    2.336872]
[    2.336872] X22: 0xffffffc0ee5b8640:
[    2.337311] 8640  00030003 dead4ead ffffffff ffffffc0 ffffffff ffffffff 00000                                                     000 ffffffc0
[    2.338038] 8660  00000000 00000000 ede0b800 ffffffc0 00000000 00000000 00000                                                     000 00000000
[    2.338764] 8680  ee5ba4d0 ffffffc0 ee5b85a8 ffffffc0 eec0e330 ffffffc0 ee5ba                                                     408 ffffffc0
[    2.339491] 86a0  ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000 00000                                                     000 00000000
[    2.340218] 86c0  00200000 00000002 00000000 00000000 00000000 00000000 ee5b8                                                     6c0 ffffffc0
[    2.340945] 86e0  00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0 00000                                                     02f dead4ead
[    2.341672] 8700  ffffffff 00000000 ffffffff ffffffff 00000000 00000000 64af6                                                     4ae dead4ead
[    2.342399] 8720  00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000 00000                                                     000 00000000
[    2.343126]
[    2.343126] X27: 0xffffff8008bc1f80:
[    2.343564] 1f80  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.344290] 1fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.345015] 1fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.345741] 1fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.346467] 2000  081e9718 ffffff80 081e9fac ffffff80 081ea550 ffffff80 081ea                                                     590 ffffff80
[    2.347194] 2020  081ea6fc ffffff80 081c88f8 ffffff80 081c894c ffffff80 081c8                                                     9a0 ffffff80
[    2.347922] 2040  081c8a38 ffffff80 081c8a80 ffffff80 081c8ac8 ffffff80 081c8                                                     b40 ffffff80
[    2.348649] 2060  081c8b80 ffffff80 081c8bc0 ffffff80 081c8c30 ffffff80 081c8                                                     c6c ffffff80
[    2.349377]
[    2.349377] X28: 0xffffffc0ed30ff80:
[    2.349815] ff80  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.350542] ffa0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
[    2.351268] ffc0  ffff0000 ffff0000 00000000 000000c0 ed38ae00 ffffffc0 ed38a                                                     e00 ffffffc0
[    2.351995] ffe0  00000300 00000001 00000000 00000000 00ff00ff 00ff00ff 00ff0                                                     0ff 00ff00ff
[    2.352721] 0000  00000002 00000000 ffffffff ffffffff ed2d4980 ffffffc0 00000                                                     000 00000005
[    2.353448] 0020  57ac6e9d 00000000 c3b0e580 ffffffbd c3b0e540 ffffffbd c3b0e                                                     500 ffffffbd
[    2.354175] 0040  c3b0e4c0 ffffffbd c3b0e480 ffffffbd c3b0e440 ffffffbd c3b0e                                                     400 ffffffbd
[    2.354902] 0060  c3b0e3c0 ffffffbd c3b0e380 ffffffbd c3b0e340 ffffffbd c3b0e                                                     300 ffffffbd
[    2.355629]
[    2.355629] X29: 0xffffffc0ed313b10:
[    2.356068] 3b10  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 00000                                                     11d 00000000
[    2.356794] 3b30  0000004f 00000000 08bc2000 ffffff80 ed310000 ffffffc0 ed313                                                     b90 ffffffc0
[    2.357521] 3b50  08baaf98 ffffff80 ed313b90 ffffffc0 00000000 00000000 a0000                                                     145 00000000
[    2.358248] 3b70  ee5b8718 ffffffc0 00000000 00000000 00000000 00000080 081b1                                                     9e4 ffffff80
[    2.358974] 3b90  ed313bb0 ffffffc0 08392990 ffffff80 ee5b8718 ffffffc0 081b0                                                     8e8 ffffff80
[    2.359701] 3bb0  ed313bd0 ffffffc0 081b0914 ffffff80 ed313cb0 ffffffc0 00000                                                     000 00000000
[    2.360427] 3bd0  ed313c10 ffffffc0 081b0f1c ffffff80 ed313cb0 ffffffc0 ee5b8                                                     6c0 ffffffc0
[    2.361155] 3bf0  ed313e10 ffffffc0 00000003 00000000 ed313e58 ffffffc0 00000                                                     015 00000000
[    2.361881]
[    2.362012] Process udevadm (pid: 241, stack limit = 0xffffffc0ed310020)
[    2.362594] Stack: (0xffffffc0ed313b90 to 0xffffffc0ed314000)
[    2.363093] 3b80:                                   ffffffc0ed313bb0 ffffff80                                                     08392990
[    2.363773] 3ba0: ffffffc0ee5b8718 ffffff80081b08e8 ffffffc0ed313bd0 ffffff80                                                     081b0914
[    2.364452] 3bc0: ffffffc0ed313cb0 0000000000000000 ffffffc0ed313c10 ffffff80                                                     081b0f1c
[    2.365131] 3be0: ffffffc0ed313cb0 ffffffc0ee5b86c0 ffffffc0ed313e10 00000000                                                     00000003
[    2.365810] 3c00: ffffffc0ed313e58 0000000000000015 ffffffc0ed313c30 ffffff80                                                     081b21a8
[    2.366489] 3c20: 0000000000000000 ffffffc0ed313cb0 ffffffc0ed313c70 ffffff80                                                     081b3508
[    2.367168] 3c40: 00000000ffffff9c 0000000000000000 ffffffc0ed8e7000 ffffffc0                                                     ed313e10
[    2.367847] 3c60: 00000000ffffff9c 0000000000000040 ffffffc0ed313d80 ffffff80                                                     081b3670
[    2.368527] 3c80: 0000000000000000 00000000ffffff9c 00000000ffffff9c 00000055                                                     c36b6d00
[    2.369207] 3ca0: ffffffc0ed8e7000 0000000000000000 ffffffc0edaac020 ffffffc0                                                     ee5b86c0
[    2.369886] 3cc0: 000000030637760b ffffffc0ed8e701d 0000000000000000 ffffffc0                                                     ed5a0a20
[    2.370565] 3ce0: ffffffc0ed630000 0000000200001000 00000000000000d6 00000000                                                     00000000
[    2.371244] 3d00: ffffffc0ed313d08 00000000ffffff9c 00000000ffffff9c ffffff80                                                     090ee000
[    2.371924] 3d20: 00000055c36b6d00 0000000000000000 ffffffc0ed313d80 ffffff80                                                     081b3658
[    2.372603] 3d40: 0000000000000000 00000000ffffff9c 00000000ffffff9c 00000055                                                     c36b6d00
[    2.373282] 3d60: ffffffc0ed313e58 ffffffc0ed8e7000 0000000000000000 ffffff9c                                                     00000002
[    2.373961] 3d80: ffffffc0ed313dc0 ffffff80081a99e8 0000000000000000 00000000                                                     ffffffea
[    2.374640] 3da0: ffffffc0ed60f058 00000055c36b6d00 ffffffc0ed313e10 00000000                                                     00000000
[    2.375319] 3dc0: ffffffc0ed313e20 ffffff80081a9ea4 0000007fe41fb2f0 ffffffff                                                     ffffff9c
[    2.375998] 3de0: ffffffffffffffff 0000007fb68a261c 0000000080000000 ffffff80                                                     081ae4c8
[    2.376678] 3e00: ffffffc0ed313eb0 0000000000000100 ffffffc0ed313e30 ffffff80                                                     081a9fdc
[    2.377357] 3e20: 0000000000000000 ffffff80080826f0 0000000000000000 00000055                                                     c36b6cb4
[    2.378036] 3e40: 00000055c36b6d00 0000000000000100 ffffffffffffffff 0000007f                                                     b68a46e8
[    2.378715] 3e60: 0000000060000000 0000000000000015 000000000000011d 00000000                                                     0000004e
[    2.379394] 3e80: ffffff8008bc2000 ffffff80080826f0 0000000000000000 00000000                                                     00000063
[    2.380073] 3ea0: 0000000000000000 00000000e41fb330 ffffffc0edaac020 ffffffc0                                                     ed60f000
[    2.380752] 3ec0: ffffffffffffff9c 00000055c36b6d00 0000007fe41fb2f0 00000000                                                     00000100
[    2.381431] 3ee0: 00000055c36b6d00 0000000000001011 00000055c36b6d01 00000000                                                     00000003
[    2.382110] 3f00: 000000000000004f 0000007fb692a9a0 aa82000000000000 00000000                                                     00040004
[    2.382789] 3f20: 0000000000000000 ffffffff00000000 000000ff02010100 00000000                                                     00000080
[    2.383469] 3f40: 0000007fb692a008 0000007fb685b230 0000000000000a03 00000055                                                     c36b6cb1
[    2.384148] 3f60: 00000055c36b6cb4 00000055c36b7d00 0000000000000000 0000007f                                                     e41fb2f0
[    2.384827] 3f80: 000000000000002f 00000055c36b6d04 00000055c36b6d00 00000055                                                     c36b6d00
[    2.385506] 3fa0: 0000000000000003 0000007fe41fb280 0000007fb68269cc 0000007f                                                     e41fb280
[    2.386185] 3fc0: 0000007fb68a261c 0000000080000000 ffffffffffffff9c 00000000                                                     0000004f
[    2.386864] 3fe0: 0000000000000000 0000000000000000 0000000000000000 00000000                                                     00000000
[    2.387542] Call trace:
[    2.387757] Exception stack(0xffffffc0ed3139c0 to 0xffffffc0ed313af0)
[    2.388316] 39c0: ffffffc0ee5b8718 0000008000000000 ffffffc0ed313b90 00000000                                                     00000000
[    2.388995] 39e0: ffffffc0ed313a00 ffffff8008bab068 ffffffc0ef0ec080 ffffff80                                                     0819cef4
[    2.389674] 3a00: ffffffc0ed313b00 ffffff800819d004 0000000000000140 ffffffc0                                                     ef0e9100
[    2.390353] 3a20: 00000000024000c0 ffffff80081bab68 ffffffc0edde2000 0000007f                                                     e41fb410
[    2.391032] 3a40: 00000055c36b6a50 00000000fffffffe 00000000ffffffea ffffffc0                                                     ed310000
[    2.391711] 3a60: ffffffc0ed2d4980 0000000000000005 00000000000000d6 ffffff80                                                     090e5000
[    2.392390] 3a80: 0000000000000000 0000000000000003 0000000000000fe4 00000055                                                     c36b6d00
[    2.393069] 3aa0: fefefefefefefeff ffffffc0ed8e701c 0000000000000000 00000000                                                     00040004
[    2.393748] 3ac0: 0000000000000000 ffffffff00000000 000000ff02010100 00000000                                                     00000080
[    2.394426] 3ae0: ffffff80081a9e6c 0000007fb685b230
[    2.394850] [<          (null)>]           (null)
[    2.395263] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[    2.395780] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[    2.396234] [<ffffff80081b0f1c>] complete_walk+0x48/0x94
[    2.396696] [<ffffff80081b21a8>] path_lookupat+0xc4/0x120
[    2.397165] [<ffffff80081b3508>] filename_lookup+0x6c/0xc8
[    2.397642] [<ffffff80081b3670>] user_path_at_empty+0x54/0x60
[    2.398142] [<ffffff80081a99e8>] vfs_fstatat+0x74/0xc0
[    2.398589] [<ffffff80081a9ea4>] SyS_newfstatat+0x38/0x58
[    2.399060] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[    2.399522] Code: bad PC value
[    2.399830] ---[ end trace 9960da25090fce5d ]---
[    9.291374] BUG: spinlock lockup suspected on CPU#4, systemctl/250
[    9.291921]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
[    9.292649] CPU: 4 PID: 250 Comm: systemctl Tainted: G      D         4.4.55 #1
[    9.293283] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[    9.293925] Call trace:
[    9.294148] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[    9.294619] [<ffffff8008088368>] show_stack+0x20/0x28
[    9.295061] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[    9.295502] [<ffffff80080e2d88>] spin_dump+0x88/0x94
[    9.295934] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
[    9.296435] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[    9.296905] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[    9.297421] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[    9.297875] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[    9.298359] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[    9.298821] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[    9.299276] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[    9.299737] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[    9.300177] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[    9.306388] BUG: spinlock lockup suspected on CPU#3, systemd-udevd/254
[    9.306973]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
[    9.307658] BUG: spinlock lockup suspected on CPU#1, systemd-udevd/260
[    9.307662]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
[    9.307667] CPU: 1 PID: 260 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
[    9.307669] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[    9.307671] Call trace:
[    9.307678] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[    9.307683] [<ffffff8008088368>] show_stack+0x20/0x28
[    9.307688] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[    9.307692] [<ffffff80080e2d88>] spin_dump+0x88/0x94
[    9.307695] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
[    9.307700] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[    9.307706] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[    9.307711] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[    9.307714] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[    9.307718] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[    9.307721] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[    9.307725] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[    9.307728] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[    9.307732] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[    9.308909] BUG: spinlock lockup suspected on CPU#2, systemd/1
[    9.308913]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
[    9.308917] CPU: 2 PID: 1 Comm: systemd Tainted: G      D         4.4.55 #1
[    9.308918] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[    9.308919] Call trace:
[    9.308923] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[    9.308927] [<ffffff8008088368>] show_stack+0x20/0x28
[    9.308930] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[    9.308934] [<ffffff80080e2d88>] spin_dump+0x88/0x94
[    9.308937] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
[    9.308940] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[    9.308943] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[    9.308946] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[    9.308949] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[    9.308952] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[    9.308955] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[    9.308958] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[    9.308960] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[    9.308963] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[    9.312359] BUG: spinlock lockup suspected on CPU#0, systemd-udevd/261
[    9.312364]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
[    9.312367] CPU: 0 PID: 261 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
[    9.312369] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[    9.312370] Call trace:
[    9.312374] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[    9.312377] [<ffffff8008088368>] show_stack+0x20/0x28
[    9.312381] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[    9.312384] [<ffffff80080e2d88>] spin_dump+0x88/0x94
[    9.312387] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
[    9.312390] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[    9.312393] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[    9.312396] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[    9.312399] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[    9.312402] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[    9.312405] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[    9.312408] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[    9.312410] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[    9.312413] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[    9.335524] CPU: 3 PID: 254 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
[    9.336190] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[    9.336832] Call trace:
[    9.337050] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[    9.337522] [<ffffff8008088368>] show_stack+0x20/0x28
[    9.337964] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[    9.338406] [<ffffff80080e2d88>] spin_dump+0x88/0x94
[    9.338840] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
[    9.339342] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[    9.339815] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[    9.340330] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[    9.340787] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[    9.341274] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[    9.341738] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[    9.342195] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[    9.342659] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[    9.343101] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[    9.426198] BUG: spinlock lockup suspected on CPU#5, systemd-udevd/258
[    9.426768]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
[    9.427499] CPU: 5 PID: 258 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
[    9.428163] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[    9.428804] Call trace:
[    9.429019] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[    9.429490] [<ffffff8008088368>] show_stack+0x20/0x28
[    9.429929] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[    9.430369] [<ffffff80080e2d88>] spin_dump+0x88/0x94
[    9.430801] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
[    9.431300] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[    9.431770] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[    9.432284] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[    9.432738] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[    9.433222] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[    9.433684] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[    9.434137] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[    9.434599] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[    9.435038] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[   28.137891] NMI watchdog: BUG: soft lockup - CPU#0 stuck for 23s! [systemd-udevd:261]
[   28.137894] NMI watchdog: BUG: soft lockup - CPU#1 stuck for 23s! [systemd-udevd:260]
[   28.137901] Modules linked in:
[   28.137902]
[   28.137906] CPU: 1 PID: 260 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
[   28.137908] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[   28.137910] task: ffffffc0eb44e200 ti: ffffffc0ed350000 task.ti: ffffffc0ed350000
[   28.137915] PC is at do_raw_spin_lock+0x128/0x158
[   28.137918] LR is at do_raw_spin_lock+0x104/0x158
[   28.137920] pc : [<ffffff80080e2f4c>] lr : [<ffffff80080e2f28>] pstate: 00000145
[   28.137921] sp : ffffffc0ed353b20
[   28.137926] x29: ffffffc0ed353b20 x28: ffffffc0ed350000
[   28.137929] x27: ffffff8008bc2000 x26: 0000000000000038
[   28.137932] x25: 000000000000011d x24: 0000000000000030
[   28.137935] x23: 0000000000000000 x22: ffffffc0ee5b86c0
[   28.137938] x21: 00000000016e3600 x20: 00000000016e3600
[   28.137941] x19: ffffffc0ee5b8718 x18: 0000000000000a03
[   28.137944] x17: 0000007f7bce8230 x16: ffffff80081a4304
[   28.137947] x15: 0000000000000048 x14: 0ffffffffffffffd
[   28.137951] x13: 0000000000000038 x12: 0101010101010101
[   28.137954] x11: ff7f7f7f7f7f7f7f x10: fdff333376ff2f60
[   28.137957] x9 : 7f7f7f7f7f7f7f7f x8 : ffffff8009255e34
[   28.137960] x7 : 0000000000000001 x6 : ffffffc0f7efd060
[   28.137963] x5 : 0000000000000000 x4 : ffffffc0ed353e90
[   28.137966] x3 : ffffffc0ed353fe0 x2 : 00000000000064ae
[   28.137969] x1 : 000000000000001e x0 : 0000000064b064ae
[   28.137972]
[   28.137972] PC: 0xffffff80080e2ecc:
[   28.137981] 2ecc  900080a0 d2807d14 d2800015 f946dc00 9b147c14 eb1402bf 540001a0 f9800271
[   28.137989] 2eec  885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60 340002a0 d2800020
[   28.137997] 2f0c  910006b5 940a8a4c 17fffff3 d0006ac1 aa1303e0 9116c821 97ffff77 f9800271
[   28.138005] 2f2c  885ffe60 11404001 88027e61 35ffffa2 4ac04001 340000c1 d50320bf d503205f
[   28.138013] 2f4c  485ffe62 4a404041 35ffffa1 d5384100 b9401c01 b9000a61 f94013f5 f9400800
[   28.138021] 2f6c  f9000a60 a94153f3 a8c37bfd d65f03c0 a9be7bfd 910003fd f9000bf3 aa0003f3
[   28.138028] 2f8c  aa1e03e0 d503201f f9800271 885ffe61 4ac14020 35000080 11404021 88007e61
[   28.138036] 2fac  35ffff60 6b1f001f 1a9f17e0 340000c0 d5384101 b9401c22 b9000a62 f9400821
[   28.138038]
[   28.138038] LR: 0xffffff80080e2ea8:
[   28.138047] 2ea8  97ffffbb f9800271 885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60
[   28.138054] 2ec8  34000480 900080a0 d2807d14 d2800015 f946dc00 9b147c14 eb1402bf 540001a0
[   28.138062] 2ee8  f9800271 885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60 340002a0
[   28.138070] 2f08  d2800020 910006b5 940a8a4c 17fffff3 d0006ac1 aa1303e0 9116c821 97ffff77
[   28.138078] 2f28  f9800271 885ffe60 11404001 88027e61 35ffffa2 4ac04001 340000c1 d50320bf
[   28.138086] 2f48  d503205f 485ffe62 4a404041 35ffffa1 d5384100 b9401c01 b9000a61 f94013f5
[   28.138094] 2f68  f9400800 f9000a60 a94153f3 a8c37bfd d65f03c0 a9be7bfd 910003fd f9000bf3
[   28.138102] 2f88  aa0003f3 aa1e03e0 d503201f f9800271 885ffe61 4ac14020 35000080 11404021
[   28.138104]
[   28.138104] SP: 0xffffffc0ed353aa0:
[   28.138112] 3aa0  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 0000011d 00000000
[   28.138119] 3ac0  00000038 00000000 08bc2000 ffffff80 ed350000 ffffffc0 ed353b20 ffffffc0
[   28.138127] 3ae0  080e2f28 ffffff80 ed353b20 ffffffc0 080e2f4c ffffff80 00000145 00000000
[   28.138135] 3b00  ee5b8718 ffffffc0 016e3600 00000000 00000000 00000080 08e3c5b2 ffffff80
[   28.138143] 3b20  ed353b50 ffffffc0 08baaf98 ffffff80 ee5b8718 ffffffc0 00000000 00000000
[   28.138151] 3b40  00000000 00000000 081af0e4 ffffff80 ed353b70 ffffffc0 08392990 ffffff80
[   28.138159] 3b60  ee5b8718 ffffffc0 081b08e8 ffffff80 ed353b90 ffffffc0 081b0914 ffffff80
[   28.138167] 3b80  ed353d40 ffffffc0 00000000 00000000 ed353bd0 ffffffc0 081b1dfc ffffff80
[   28.138169]
[   28.138169] X3: 0xffffffc0ed353f60:
[   28.138178] 3f60  5b054210 00000055 00000008 00000000 00000001 00000000 5b08c000 00000055
[   28.138185] 3f80  5b08b000 00000055 ce10cb50 0000007f ce10cb40 0000007f 88a42c70 00000055
[   28.138193] 3fa0  88a3c950 00000055 ce10c7d0 0000007f 7bce0b60 0000007f ce10c7d0 0000007f
[   28.138201] 3fc0  7bd2fa90 0000007f 80000000 00000000 ffffff9c ffffffff 00000038 00000000
[   28.138209] 3fe0  00000000 00000000 00000000 00000000 00ff00ff 00ff00ff 00ff00ff 00ff00ff
[   28.138217] 4000  40646461 7375622f 616c702f 726f6674 72642f6d 72657669 6f722f73 68636b63
[   28.138225] 4020  642d7069 43410070 4e4f4954 6464613d 56454400 48544150 75622f3d 6c702f73
[   28.138233] 4040  6f667461 642f6d72 65766972 722f7372 636b636f 2d706968 53007064 59534255
[   28.138235]
[   28.138235] X4: 0xffffffc0ed353e10:
[   28.138243] 3e10  ed353e80 ffffffc0 081a4340 ffffff80 ffffff9c ffffffff 5b054210 00000055
[   28.138250] 3e30  ffffffff ffffffff 7bd2fa90 0000007f 80000000 00000000 00000015 00000000
[   28.138258] 3e50  ed353e70 ffffffc0 ce10ca80 0000007f ed353e70 ffffffc0 00020000 ffff0000
[   28.138266] 3e70  00000024 00000100 00000001 ffffff80 00000000 00000000 080826f0 ffffff80
[   28.138274] 3e90  00000000 00000000 00000007 00000000 00000000 00000000 ce10ca80 0000007f
[   28.138282] 3eb0  00080000 00000000 00000000 00000000 ffffff9c ffffffff ce10ca80 0000007f
[   28.138289] 3ed0  00080000 00000000 00000000 00000000 00000008 00000000 00080000 00000000
[   28.138297] 3ef0  5b054212 00000055 5b054216 00000055 00000038 00000000 7f7f7f7f 7f7f7f7f
[   28.138299]
[   28.138299] X6: 0xffffffc0f7efcfe0:
[   28.138307] cfe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138315] d000  edccf940 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138322] d020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138330] d040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138337] d060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138345] d080  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138353] d0a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138360] d0c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138362]
[   28.138362] X8: 0xffffff8009255db4:
[   28.138370] 5db4  302f3037 38303278 2ac8aaf6 00000002 0029003c 82000000 66663c5b 66666666
[   28.138378] 5dd4  38303038 33346131 5d3e3034 53795320 65706f5f 2b74616e 63337830 3478302f
[   28.138386] 5df4  00000038 2ac8b9c6 00000002 002c003c 82000000 66663c5b 66666666 38303038
[   28.138394] 5e14  36323830 5d3e3066 306c6520 6376735f 6b616e5f 302b6465 2f343278 38327830
[   28.138402] 5e34  2adab014 00000002 00320044 06000000 3a475542 69707320 636f6c6e 6f6c206b
[   28.138409] 5e54  70756b63 73757320 74636570 6f206465 5043206e 2c322355 73797320 646d6574
[   28.138417] 5e74  0000312f 2adac12b 00000002 004f0060 06000000 636f6c20 30203a6b 66666678
[   28.138425] 5e94  63666666 35656530 31373862 2e202c38 6967616d 64203a63 34646165 2c646165
[   28.138429]
[   28.138429] X16: 0xffffff80081a4284:
[   28.138437] 4284  2a0403e5 9400f465 2a1503e0 aa1303e1 94007125 aa1403e0 93407eb4 94003bc6
[   28.138444] 42a4  aa1403e0 a94153f3 a9425bf5 a94363f7 a8c77bfd d65f03c0 a9bd7bfd 910003fd
[   28.138452] 42c4  a90153f3 f90013f5 aa0003f5 aa1e03e0 aa0103f4 aa0203f3 d503201f aa1503e1
[   28.138461] 42e4  320f0282 2a1303e3 12800c60 97ffff71 f94013f5 a94153f3 a8c37bfd d65f03c0
[   28.138469] 4304  a9bc7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 f90017a1 f9001ba2 f9001fa3
[   28.138476] 4324  d503201f f9401ba2 2a1303e0 f94017a1 f9401fa3 320f0042 97ffff5e f9400bf3
[   28.138484] 4344  a8c47bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 aa1e03e0 aa0103f3
[   28.138492] 4364  d503201f 2a1303e2 aa1403e0 52804821 97ffffd2 a94153f3 a8c27bfd d65f03c0
[   28.138495]
[   28.138495] X19: 0xffffffc0ee5b8698:
[   28.138502] 8698  ee5ba408 ffffffc0 ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000
[   28.138510] 86b8  00000000 00000000 00200000 00000002 00000000 00000000 00000000 00000000
[   28.138518] 86d8  ee5b86c0 ffffffc0 00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0
[   28.138526] 86f8  0000002f dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[   28.138534] 8718  64b564ae dead4ead 00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000
[   28.138542] 8738  00000000 00000000 edde2000 ffffffc0 00000000 dead4ead ef0ee000 ffffffc0
[   28.138549] 8758  ee5b8758 ffffffc0 ee5b8758 ffffffc0 ee5b8768 ffffffc0 ee5b8768 ffffffc0
[   28.138557] 8778  ee5e2408 ffffffc0 ee5b8840 ffffffc0 00000000 00000000 ed630148 ffffffc0
[   28.138560]
[   28.138560] X22: 0xffffffc0ee5b8640:
[   28.138567] 8640  00030003 dead4ead ffffffff ffffffc0 ffffffff ffffffff 00000000 ffffffc0
[   28.138577] 8660  00000000 00000000 ede0b800 ffffffc0 00000000 00000000 00000000 00000000
[   28.138586] 8680  ee5ba4d0 ffffffc0 ee5b85a8 ffffffc0 eec0e330 ffffffc0 ee5ba408 ffffffc0
[   28.138594] 86a0  ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000 00000000 00000000
[   28.138602] 86c0  00200000 00000002 00000000 00000000 00000000 00000000 ee5b86c0 ffffffc0
[   28.138610] 86e0  00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0 0000002f dead4ead
[   28.138619] 8700  ffffffff 00000000 ffffffff ffffffff 00000000 00000000 64b564ae dead4ead
[   28.138626] 8720  00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000 00000000 00000000
[   28.138629]
[   28.138629] X27: 0xffffff8008bc1f80:
[   28.138637] 1f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138645] 1fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138652] 1fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138660] 1fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138668] 2000  081e9718 ffffff80 081e9fac ffffff80 081ea550 ffffff80 081ea590 ffffff80
[   28.138676] 2020  081ea6fc ffffff80 081c88f8 ffffff80 081c894c ffffff80 081c89a0 ffffff80
[   28.138684] 2040  081c8a38 ffffff80 081c8a80 ffffff80 081c8ac8 ffffff80 081c8b40 ffffff80
[   28.138692] 2060  081c8b80 ffffff80 081c8bc0 ffffff80 081c8c30 ffffff80 081c8c6c ffffff80
[   28.138694]
[   28.138694] X28: 0xffffffc0ed34ff80:
[   28.138702] ff80  00000018 00000000 88a42b48 00000055 00000003 00000000 88a50600 00000055
[   28.138710] ffa0  0000000e 00000000 ce10cc40 0000007f 5b01bd18 00000055 ce10cc40 0000007f
[   28.138718] ffc0  7bd3c240 0000007f 60000000 00000000 00000004 00000000 00000016 00000000
[   28.138725] ffe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138733] 0000  00000002 00000000 ffffffff ffffffff eb44e200 ffffffc0 00010000 00000001
[   28.138741] 0020  57ac6e9d 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138748] 0040  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[   28.138756] 0060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.138758]
[   28.138758] X29: 0xffffffc0ed353aa0:
[   28.138766] 3aa0  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 0000011d 00000000
[   28.138773] 3ac0  00000038 00000000 08bc2000 ffffff80 ed350000 ffffffc0 ed353b20 ffffffc0
[   28.138781] 3ae0  080e2f28 ffffff80 ed353b20 ffffffc0 080e2f4c ffffff80 00000145 00000000
[   28.138789] 3b00  ee5b8718 ffffffc0 016e3600 00000000 00000000 00000080 08e3c5b2 ffffff80
[   28.138797] 3b20  ed353b50 ffffffc0 08baaf98 ffffff80 ee5b8718 ffffffc0 00000000 00000000
[   28.138805] 3b40  00000000 00000000 081af0e4 ffffff80 ed353b70 ffffffc0 08392990 ffffff80
[   28.138813] 3b60  ee5b8718 ffffffc0 081b08e8 ffffff80 ed353b90 ffffffc0 081b0914 ffffff80
[   28.138821] 3b80  ed353d40 ffffffc0 00000000 00000000 ed353bd0 ffffffc0 081b1dfc ffffff80
[   28.138821]
[   28.138826] Kernel panic - not syncing: softlockup: hung tasks
[   28.138830] CPU4: stopping
[   28.138833] CPU: 4 PID: 250 Comm: systemctl Tainted: G      D      L  4.4.55 #1
[   28.138834] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[   28.138835] Call trace:
[   28.138837] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[   28.138839] [<ffffff8008088368>] show_stack+0x20/0x28
[   28.138841] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[   28.138844] [<ffffff800808d944>] handle_IPI+0x134/0x240
[   28.138845] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
[   28.138847] Exception stack(0xffffffc0f7f40000 to 0xffffffc0f7f40130)
[   28.138849] 0000: ffffffc0eb4639f0 0000008000000000 ffffffc0eb463b20 ffffff80080e2f4c
[   28.138851] 0020: 0000000000000145 0000000000000030 ffffffc0f7f3c060 0000000000000000
[   28.138853] 0040: ffffffc0eb463b20 ffffffc0eb4639f0 0000000000000000 0000000000000000
[   28.138854] 0060: ffffffc0ed2d5ea0 0000000000000000 0000000000000000 0000000000000000
[   28.138856] 0080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138858] 00a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138859] 00c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138861] 00e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138862] 0100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138864] 0120: 0000000000000000 0000000000000000
[   28.138866] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[   28.138868] [<ffffff80080e2f4c>] do_raw_spin_lock+0x128/0x158
[   28.138869] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[   28.138871] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[   28.138873] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[   28.138875] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[   28.138876] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[   28.138878] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[   28.138880] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[   28.138881] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[   28.138883] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[   28.138884] CPU5: stopping
[   28.138887] CPU: 5 PID: 258 Comm: systemd-udevd Tainted: G      D      L  4.4.55 #1
[   28.138888] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[   28.138888] Call trace:
[   28.138891] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[   28.138893] [<ffffff8008088368>] show_stack+0x20/0x28
[   28.138895] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[   28.138897] [<ffffff800808d944>] handle_IPI+0x134/0x240
[   28.138898] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
[   28.138900] Exception stack(0xffffffc0f7f55000 to 0xffffffc0f7f55130)
[   28.138902] 5000: ffffffc0eb4b39f0 0000008000000000 ffffffc0eb4b3b20 ffffff80080e2f4c
[   28.138904] 5020: 0000000000000145 0000000000000030 ffffffc0f7f51060 0000000000000000
[   28.138905] 5040: ffffffc0eb4b3b20 ffffffc0eb4b39f0 0000000000000000 0000000000000000
[   28.138907] 5060: ffffffc0eb44dea0 0000000000000000 0000000000000000 0000000000000000
[   28.138908] 5080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138910] 50a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138911] 50c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138913] 50e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138915] 5100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138916] 5120: 0000000000000000 0000000000000000
[   28.138917] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[   28.138919] [<ffffff80080e2f4c>] do_raw_spin_lock+0x128/0x158
[   28.138921] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[   28.138923] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[   28.138925] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[   28.138927] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[   28.138929] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[   28.138930] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[   28.138932] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[   28.138933] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[   28.138935] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[   28.138938] CPU2: stopping
[   28.138943] CPU: 2 PID: 1 Comm: systemd Tainted: G      D      L  4.4.55 #1
[   28.138945] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[   28.138945] Call trace:
[   28.138950] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[   28.138953] [<ffffff8008088368>] show_stack+0x20/0x28
[   28.138957] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[   28.138961] [<ffffff800808d944>] handle_IPI+0x134/0x240
[   28.138964] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
[   28.138967] Exception stack(0xffffffc0f7f16000 to 0xffffffc0f7f16130)
[   28.138971] 6000: ffffffc0ef1179f0 0000008000000000 ffffffc0ef117b20 ffffff80080e2f4c
[   28.138974] 6020: 0000000000000145 0000000000000030 ffffffc0f7f12060 0000000000000000
[   28.138978] 6040: ffffffc0ef117b20 ffffffc0ef1179f0 0000000000000000 0000000000000000
[   28.138980] 6060: ffffffc0ef2088e0 0000000000000000 0000000000000000 0000000000000000
[   28.138984] 6080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138987] 60a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138990] 60c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138992] 60e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138995] 6100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.138998] 6120: 0000000000000000 0000000000000000
[   28.139001] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[   28.139004] [<ffffff80080e2f4c>] do_raw_spin_lock+0x128/0x158
[   28.139007] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[   28.139011] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[   28.139013] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[   28.139017] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[   28.139020] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[   28.139022] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[   28.139025] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[   28.139028] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[   28.139031] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[   28.139033] CPU3: stopping
[   28.139037] CPU: 3 PID: 254 Comm: systemd-udevd Tainted: G      D      L  4.4.55 #1
[   28.139038] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[   28.139039] Call trace:
[   28.139043] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
[   28.139047] [<ffffff8008088368>] show_stack+0x20/0x28
[   28.139050] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
[   28.139053] [<ffffff800808d944>] handle_IPI+0x134/0x240
[   28.139056] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
[   28.139059] Exception stack(0xffffffc0f7f2b000 to 0xffffffc0f7f2b130)
[   28.139062] b000: ffffffc0ed3179f0 0000008000000000 ffffffc0ed317b20 ffffff80080e2f4c
[   28.139066] b020: 0000000000000145 0000000000000030 ffffffc0f7f27060 0000000000000000
[   28.139069] b040: ffffffc0ed317b20 ffffffc0ed3179f0 0000000000000000 0000000000000000
[   28.139072] b060: ffffffc0eb44ada0 0000000000000000 0000000000000000 0000000000000000
[   28.139075] b080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.139078] b0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.139081] b0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.139084] b0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.139087] b100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   28.139089] b120: 0000000000000000 0000000000000000
[   28.139092] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
[   28.139095] [<ffffff80080e2f4c>] do_raw_spin_lock+0x128/0x158
[   28.139098] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
[   28.139102] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
[   28.139105] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
[   28.139108] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
[   28.139111] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
[   28.139114] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
[   28.139117] [<ffffff80081a4224>] do_sys_open+0x170/0x208
[   28.139119] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
[   28.139122] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
[   28.294977] Modules linked in:
[   28.295246]
[   28.295381] CPU: 0 PID: 261 Comm: systemd-udevd Tainted: G      D      L  4.4.55 #1
[   28.296046] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
[   28.296690] task: ffffffc0eb44ee40 ti: ffffffc0eb4c8000 task.ti: ffffffc0eb4c8000
[   28.297342] PC is at do_raw_spin_lock+0x128/0x158
[   28.297753] LR is at do_raw_spin_lock+0x104/0x158
[   28.298164] pc : [<ffffff80080e2f4c>] lr : [<ffffff80080e2f28>] pstate: 00000145
[   28.298807] sp : ffffffc0eb4cbb20
[   28.299097] x29: ffffffc0eb4cbb20 x28: ffffffc0eb4c8000
[   28.299564] x27: ffffff8008bc2000 x26: 0000000000000038
[   28.300031] x25: 000000000000011d x24: 0000000000000030
[   28.300498] x23: 0000000000000000 x22: ffffffc0ee5b86c0
[   28.300965] x21: 00000000016e3600 x20: 00000000016e3600
[   28.301432] x19: ffffffc0ee5b8718 x18: 0000000000000a03
[   28.301899] x17: 0000007f7bce8230 x16: ffffff80081a4304
[   28.302365] x15: 0000000000000058 x14: 0ffffffffffffffd
[   28.302832] x13: 0000000000000038 x12: 0101010101010101
[   28.303298] x11: 7f7f7f7f7f7f7f7f x10: 52ff333376ff2f60
[   28.303766] x9 : 7f7f7f7f7f7f7f7f x8 : ffffff80092567cc
[   28.304232] x7 : 0000000000000000 x6 : ffffffc0f7ee8060
[   28.304699] x5 : 0000000000000000 x4 : ffffffc0eb4cbe90
[   28.305167] x3 : ffffffc0eb4cbfe0 x2 : 00000000000064ae
[   28.305633] x1 : 000000000000001c x0 : 0000000064b264ae
[   28.306100]
[   28.306100] PC: 0xffffff80080e2ecc:
[   28.306533] 2ecc  900080a0 d2807d14 d2800015 f946dc00 9b147c14 eb1402bf 540001a0 f9800271
[   28.307267] 2eec  885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60 340002a0 d2800020
[   28.308000] 2f0c  910006b5 940a8a4c 17fffff3 d0006ac1 aa1303e0 9116c821 97ffff77 f9800271
[   28.308734] 2f2c  885ffe60 11404001 88027e61 35ffffa2 4ac04001 340000c1 d50320bf d503205f
[   28.309467] 2f4c  485ffe62 4a404041 35ffffa1 d5384100 b9401c01 b9000a61 f94013f5 f9400800
[   28.310200] 2f6c  f9000a60 a94153f3 a8c37bfd d65f03c0 a9be7bfd 910003fd f9000bf3 aa0003f3
[   28.310934] 2f8c  aa1e03e0 d503201f f9800271 885ffe61 4ac14020 35000080 11404021 88007e61
[   28.311668] 2fac  35ffff60 6b1f001f 1a9f17e0 340000c0 d5384101 b9401c22 b9000a62 f9400821
[   28.312402]
[   28.312402] LR: 0xffffff80080e2ea8:
[   28.312835] 2ea8  97ffffbb f9800271 885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60
[   28.313568] 2ec8  34000480 900080a0 d2807d14 d2800015 f946dc00 9b147c14 eb1402bf 540001a0
[   28.314302] 2ee8  f9800271 885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60 340002a0
[   28.315035] 2f08  d2800020 910006b5 940a8a4c 17fffff3 d0006ac1 aa1303e0 9116c821 97ffff77
[   28.315770] 2f28  f9800271 885ffe60 11404001 88027e61 35ffffa2 4ac04001 340000c1 d50320bf
[   28.316504] 2f48  d503205f 485ffe62 4a404041 35ffffa1 d5384100 b9401c01 b9000a61 f94013f5
[   28.317237] 2f68  f9400800 f9000a60 a94153f3 a8c37bfd d65f03c0 a9be7bfd 910003fd f9000bf3
[   28.317970] 2f88  aa0003f3 aa1e03e0 d503201f f9800271 885ffe61 4ac14020 35000080 11404021
[   28.318704]
[   28.318704] SP: 0xffffffc0eb4cbaa0:
[   28.319137] baa0  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 0000011d 00000000
[   28.319870] bac0  00000038 00000000 08bc2000 ffffff80 eb4c8000 ffffffc0 eb4cbb20 ffffffc0
[   28.320604] bae0  080e2f28 ffffff80 eb4cbb20 ffffffc0 080e2f4c ffffff80 00000145 00000000
[   28.321337] bb00  ee5b8718 ffffffc0 016e3600 00000000 00000000 00000080 08e3c5b2 ffffff80
[   28.322070] bb20  eb4cbb50 ffffffc0 08baaf98 ffffff80 ee5b8718 ffffffc0 00000000 00000000
[   28.322803] bb40  00000000 00000000 081af0e4 ffffff80 eb4cbb70 ffffffc0 08392990 ffffff80
[   28.323537] bb60  ee5b8718 ffffffc0 081b08e8 ffffff80 eb4cbb90 ffffffc0 081b0914 ffffff80
[   28.324270] bb80  eb4cbd40 ffffffc0 00000000 00000000 eb4cbbd0 ffffffc0 081b1dfc ffffff80
[   28.325005]
[   28.325005] X3: 0xffffffc0eb4cbf60:
[   28.325439] bf60  5b054210 00000055 00000008 00000000 00000001 00000000 5b08c000 00000055
[   28.326171] bf80  5b08b000 00000055 ce10cb50 0000007f ce10cb40 0000007f 88a52470 00000055
[   28.326905] bfa0  88a42c70 00000055 ce10c7c0 0000007f 7bce0b60 0000007f ce10c7c0 0000007f
[   28.327637] bfc0  7bd2fa90 0000007f 80000000 00000000 ffffff9c ffffffff 00000038 00000000
[   28.328372] bfe0  00000000 00000000 00000000 00000000 91011f39 910046e1 927df320 910006e2
[   28.329105] c000  00000000 00000000 00000000 00000080 eb4d0000 ffffffc0 00000000 00000001
[   28.329838] c020  57ac6e9d 00000000 7661652c 72647365 273d706f 65757274 00000027 00000000
[   28.330571] c040  732f2e2e 732f6372 65726168 63612f64 74752d6c 632e6c69 00000000 00000000
[   28.331305]
[   28.331305] X4: 0xffffffc0eb4cbe10:
[   28.331738] be10  eb4cbe80 ffffffc0 081a4340 ffffff80 ffffff9c ffffffff 5b054210 00000055
[   28.332471] be30  ffffffff ffffffff 7bd2fa90 0000007f 80000000 00000000 00000015 00000000
[   28.333204] be50  eb4cbe70 ffffffc0 ce10ca70 0000007f eb4cbe70 ffffffc0 00020000 ffff0000
[   28.333937] be70  00000024 00000100 00000001 ffffff80 00000000 00000000 080826f0 ffffff80
[   28.334670] be90  00000000 00000000 00000007 00000000 00000000 00000000 ce10ca70 0000007f
[   28.335403] beb0  00080000 00000000 00000000 00000000 ffffff9c ffffffff ce10ca70 0000007f
[   28.336136] bed0  00080000 00000000 00000000 00000000 00000008 00000000 00080000 00000000
[   28.336869] bef0  5b054212 00000055 5b054216 00000055 00000038 00000000 7bdb79a0 0000007f
[   28.337603]
[   28.337603] X6: 0xffffffc0f7ee7fe0:
[   28.338035] 7fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.338767] 8000  edccf780 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[   28.339499] 8020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.340230] 8040  00005dc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.340962] 8060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.341693] 8080  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.342424] 80a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.343156] 80c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.343888]
[   28.343888] X8: 0xffffff800925674c:
[   28.344321] 674c  302f3037 38303278 2b101c83 00000002 0029003c 82000000 66663c5b 66666666
[   28.345055] 676c  38303038 33346131 5d3e3034 53795320 65706f5f 2b74616e 63337830 3478302f
[   28.345789] 678c  00000038 2b1027e8 00000002 002c003c 82000000 66663c5b 66666666 38303038
[   28.346523] 67ac  36323830 5d3e3066 306c6520 6376735f 6b616e5f 302b6465 2f343278 38327830
[   28.347256] 67cc  2c70cc6f 00000002 00470058 86000000 3a555043 50203320 203a4449 20343532
[   28.347989] 67ec  6d6d6f43 7973203a 6d657473 64752d64 20647665 6e696154 3a646574 20204720
[   28.348722] 680c  20202020 20202044 20202020 2e342020 35352e34 00312320 2c7af45f 00000002
[   28.349456] 682c  00440054 86000000 64726148 65726177 6d616e20 52203a65 636b636f 20706968
[   28.350192]
[   28.350192] X16: 0xffffff80081a4284:
[   28.350633] 4284  2a0403e5 9400f465 2a1503e0 aa1303e1 94007125 aa1403e0 93407eb4 94003bc6
[   28.351367] 42a4  aa1403e0 a94153f3 a9425bf5 a94363f7 a8c77bfd d65f03c0 a9bd7bfd 910003fd
[   28.352101] 42c4  a90153f3 f90013f5 aa0003f5 aa1e03e0 aa0103f4 aa0203f3 d503201f aa1503e1
[   28.352835] 42e4  320f0282 2a1303e3 12800c60 97ffff71 f94013f5 a94153f3 a8c37bfd d65f03c0
[   28.353568] 4304  a9bc7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 f90017a1 f9001ba2 f9001fa3
[   28.354302] 4324  d503201f f9401ba2 2a1303e0 f94017a1 f9401fa3 320f0042 97ffff5e f9400bf3
[   28.355035] 4344  a8c47bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 aa1e03e0 aa0103f3
[   28.355770] 4364  d503201f 2a1303e2 aa1403e0 52804821 97ffffd2 a94153f3 a8c27bfd d65f03c0
[   28.356505]
[   28.356505] X19: 0xffffffc0ee5b8698:
[   28.356946] 8698  ee5ba408 ffffffc0 ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000
[   28.357678] 86b8  00000000 00000000 00200000 00000002 00000000 00000000 00000000 00000000
[   28.358410] 86d8  ee5b86c0 ffffffc0 00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0
[   28.359143] 86f8  0000002f dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[   28.359877] 8718  64b564ae dead4ead 00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000
[   28.360609] 8738  00000000 00000000 edde2000 ffffffc0 00000000 dead4ead ef0ee000 ffffffc0
[   28.361342] 8758  ee5b8758 ffffffc0 ee5b8758 ffffffc0 ee5b8768 ffffffc0 ee5b8768 ffffffc0
[   28.362076] 8778  ee5e2408 ffffffc0 ee5b8840 ffffffc0 00000000 00000000 ed630148 ffffffc0
[   28.362812]
[   28.362812] X22: 0xffffffc0ee5b8640:
[   28.363252] 8640  00030003 dead4ead ffffffff ffffffc0 ffffffff ffffffff 00000000 ffffffc0
[   28.363986] 8660  00000000 00000000 ede0b800 ffffffc0 00000000 00000000 00000000 00000000
[   28.364719] 8680  ee5ba4d0 ffffffc0 ee5b85a8 ffffffc0 eec0e330 ffffffc0 ee5ba408 ffffffc0
[   28.365453] 86a0  ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000 00000000 00000000
[   28.366186] 86c0  00200000 00000002 00000000 00000000 00000000 00000000 ee5b86c0 ffffffc0
[   28.366919] 86e0  00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0 0000002f dead4ead
[   28.367653] 8700  ffffffff 00000000 ffffffff ffffffff 00000000 00000000 64b564ae dead4ead
[   28.368386] 8720  00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000 00000000 00000000
[   28.369121]
[   28.369121] X27: 0xffffff8008bc1f80:
[   28.369561] 1f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.370293] 1fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.371025] 1fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.371757] 1fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   28.372489] 2000  081e9718 ffffff80 081e9fac ffffff80 081ea550 ffffff80 081ea590 ffffff80
[   28.373223] 2020  081ea6fc ffffff80 081c88f8 ffffff80 081c894c ffffff80 081c89a0 ffffff80
[   28.373956] 2040  081c8a38 ffffff80 081c8a80 ffffff80 081c8ac8 ffffff80 081c8b40 ffffff80
[   28.374689] 2060  081c8b80 ffffff80 081c8bc0 ffffff80 081c8c30 ffffff80 081c8c6c ffffff80
[   28.375423]
[   28.375423] X28: 0xffffffc0eb4c7f80:
[   28.375864] 7f80  eb4aa738 ffffffc0 eda823c8 ffffffc0 00000001 00000000 eb4c7f98 ffffffc0
[   28.376597] 7fa0  eb4c7f98 ffffffc0 00000000 00000000 08be2a98 ffffff80 00000000 00000000
[   28.377330] 7fc0  ed2cb680 ffffffc0 00000000 00000000 97fefb94 35000420 3940f282 b9403a80
[   28.378063] 7fe0  121e7842 f9400e81 3900f282 a900fe9f f900129f 17ffff3f 12800bc0 17ffff4b
[   28.378796] 8000  00000002 00000000 ffffffff ffffffff eb44ee40 ffffffc0 00010000 00000000
[   28.379530] 8020  57ac6e9d 00000000 17ffffd5 00000000 a9ad7bfd 910003fd a90153f3 900001d3
[   28.380262] 8040  f90013f5 a91093a3 a9119ba5 f90097a7 f9440263 3d8023a0 3d8027a1 3d802ba2
[   28.380995] 8060  f9400064 f9003fa4 d2800004 3d802fa3 3d8033a4 3d8037a5 3d803ba6 3d803fa7
[   28.381730]
[   28.381730] X29: 0xffffffc0eb4cbaa0:
[   28.382171] baa0  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 0000011d 00000000
[   28.382903] bac0  00000038 00000000 08bc2000 ffffff80 eb4c8000 ffffffc0 eb4cbb20 ffffffc0
[   28.383636] bae0  080e2f28 ffffff80 eb4cbb20 ffffffc0 080e2f4c ffffff80 00000145 00000000
[   28.384370] bb00  ee5b8718 ffffffc0 016e3600 00000000 00000000 00000080 08e3c5b2 ffffff80
[   28.385102] bb20  eb4cbb50 ffffffc0 08baaf98 ffffff80 ee5b8718 ffffffc0 00000000 00000000
[   28.385835] bb40  00000000 00000000 081af0e4 ffffff80 eb4cbb70 ffffffc0 08392990 ffffff80
[   28.386568] bb60  ee5b8718 ffffffc0 081b08e8 ffffff80 eb4cbb90 ffffffc0 081b0914 ffffff80
[   28.387301] bb80  eb4cbd40 ffffffc0 00000000 00000000 eb4cbbd0 ffffffc0 081b1dfc ffffff80
[   28.388035]
[   29.305496] SMP: failed to stop secondary CPUs
[   29.305887] CRU:
[   29.306058] 00000000: 0000003f 00001101 80000000 00000108 00000007 00007f00 00000000 00000000
[   29.306804] 00000020: 00000053 00001101 80000000 00000108 00000007 00007f00 00000000 00000000
[   29.307551] 00000040: 00000037 00001201 8000031f 00000108 00000007 00007f00 00000000 00000000
[   29.308297] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
[   29.309043] 00000080: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
[   29.309789] 000000a0: 0000004b 00001301 80000000 00000108 00000007 00007f00 00000000 00000000
[   29.310535] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 00000000 00000000
[   29.311281] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.312027] 00000100: 00000100 00000707 00000140 00006909 00000083 00008581 00008320 00000141
[   29.312773] 00000120: 00000181 00008181 00000141 00000141 00004141 00008362 00003185 00000107
[   29.313519] 00000140: 0000041d 00000300 00004a87 00000113 00009381 00008387 00001103 00001087
[   29.314265] 00000160: 00008247 00000187 00001743 0000001f 00000380 00000380 00000380 00000000
[   29.315011] 00000180: 00006380 00009200 00000200 00000200 00000200 00000200 00003f3f 00000081
[   29.315757] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000005 00000381
[   29.316503] 000001c0: 00000381 00000001 00000003 00000087 00000087 00000141 00000141 00008181
[   29.317249] 000001e0: 0000833f 00000007 00008f1f 00008f8f 00008f8f 00008787 00008787 00008787
[   29.317995] 00000200: 000000cf 000000cf 00000000 00000000 00000000 00000000 00000000 00000000
[   29.318740] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.319486] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.320231] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.320978] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
[   29.321724] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
[   29.322469] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.323215] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.323961] 00000300: 00000080 00000080 00000202 0000006b 00000c30 00000000 0000001c 000001c0
[   29.324707] 00000320: 0000fff8 0000f0ff 0000f0ff 0000c1b0 0000004a 0000e233 00000000 00000000
[   29.325453] 00000340: 00000505 00000505 00001000 00000000 00000e04 00000000 0000cfeb 00003f00
[   29.326199] 00000360: 0000ef60 00000020 00000ffe 000001f0 000000cc 00000f86 00000d0a 000001b8
[   29.326945] 00000380: 00002010 00000000 00000028 00000000 00000000 00000000 00000000 00000000
[   29.327691] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.328436] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.329181] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.329927] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.330672] 00000420: 00000000 00004070 00000000 00000014 00000000 00000000 00000000 00000000
[   29.331419] 00000440: 00000000 00000000 00000000 00000000 00001000 00000000 00000000 00000000
[   29.332164] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.332910] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.333656] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.334402] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.335147] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.335893] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 00000000 00000000
[   29.336639] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.337384] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.338130] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.338874] 00000580: 00000004 00000000 00000004 0000098c 00000004
[   29.339411] PMU CRU:
[   29.339611] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
[   29.340359] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.341106] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.341854] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.342602] 00000080: 0000070d 00001986 00000d0d 0000000d 000002dc 00000200 0bb8ea60 0bb8ea60
[   29.343349] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.344097] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.344844] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   29.345591] 00000100: 00000efc 0000fb80 0000000f 00000000 00000024 00000000 00000000 00000000
[   29.346336] 00000120: 00000000 00000180 00000000 00000000 00000000
[   29.346875] Kernel Offset: disabled
[   29.347180] Memory Limit: none
[   29.347456] rockchip-thermal ff260000.tsadc: channal 0: temperature(31 C)
[   29.348047] THERMAL REGS:
[   29.348283] 00000000: 00000200 00030133 00000031 00000002 00000000 00000000 00000000 00000000
[   29.349030] 00000020: 00000213 0000020b 00000000 00000000 0000024e 00000000 00000000 00000000
[   29.349777] 00000040: 00000279 00000279 00000000 00000000 00000000 00000000 00000000 00000000
[   29.350523] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 00000000 00000000
[   29.351265] 00000080: 00000000 00000000
[   29.351603] ---[ end Kernel panic - not syncing: softlockup: hung tasks
I make Lower Format before flashing and Ubuntu loaded, network worked some time and hang. After reboot I got black screen again and permanently lit blue LED. Where can I download worked firware?
please flash these images with the tool “upgrade_tool” in linux
http://wiki.t-firefly.com/index.php/Firefly-RK3399/Flash_image/en#Linux
No effect. Ubuntu stop before loading
Mounting Fuse Control File System…
I think my kernel is too fresh for the other firmware images.
Please, make a new version of firware with network fix or give me yours kernel.img and resource.img for test.
try this:
http://pan.baidu.com/s/1c1UMMJm
isle Posted at 7/19/2017 09:32
try this:
pan.baidu.com
  • A good quest for non-Chinese :smiley:
Downloaded.., flashed… - only get Black Screen.
Please check somebody.
https://drive.google.com/file/d/0B-K02-NuLnVDaFRmT25oR1liVzQ
and kernel i compiled:
https://drive.google.com/file/d/0B-K02-NuLnVDbWp2UnFsR2VHSUk
Dear Firefly developers, I’m waiting for the solution of my problem…
A week passed, but no one answered me. I’m ready to return the board.
Does the firmware from “http://pan.baidu.com/s/1c1UMMJm” work?
Hi Isle,
https://drive.google.com/file/d/0B-K02-NuLnVDNjRJMkxHSl9rb0E
Does not work, you can see system log (i am use serial port) at:
  1. I made full memory clearing (Erase Flash and Lower Format) in Android Tool
  2. I see only Black Screen, with new firware.
  3. I got only one partialy worked solution (Ethernet Ok) , when I used Beta Version Firmware and my compiled kernel.
    But after reboot system also hang.
Black screen? did the firmware from google driver have the same issue?
we (with some customers in china ) do not have that issue.
please put the Xorg log here.
Hi Isle,
All firmwares from Google Drive works OK, but have problems with Ethernet.
I installed Firefly-rk3399_xubuntu1604_201705111112 from Google Drive and upload
Xorg log for you:
current
https://drive.google.com/file/d/ … Dg/view?usp=sharing
old
https://drive.google.com/file/d/ … E0/view?usp=sharing
all logs
https://drive.google.com/file/d/ … Ws/view?usp=sharing
Oh, I havn’t find any error in your Xorg log,
maybe you should try to restart the desktop by “sudo service lighdtm restart”
