Hi, is it possible to install a self build android version for the rk3399 via the default recovery that is already installed on the board ? (eg. creating a flashable zip that can flash in stock rom). Or is it only possible to flash it with rktools / upgrade_tool ?
Best regards,
Yes it is possible.
But we do not suggest you to do this unless you are very familiar with this.
Your article is really impressive, thank you for sharing! Test GDAT prep test questions are now free. Good luck with your exams!
This article has helped me see things from different angles, encouraging deeper reflection. Free E-S4CON-2505 relevant exam dumps to help you enhance your IT expertise. Best of luck on your exams!
The points mentioned in the article are very useful and have helped me a lot. Strengthen your IT expertise with free Exam HPE2-E84 format. Best of luck in your exams!
The depth and breadth of the article left a strong impression on me. Heading into the AP-205 excellect pass rate exam soon. Pray for me!
