Whats a Parameter file?
Im new to embeded linux so this might be an obvious question, but where is the parameter file that is mentioned in the second part of this guide : http://wiki.t-firefly.com/index.php/Firefly-RK3399/Build_kernel/en
it seems to be important to flashing the device in the correct locations but i cant seem to find it anywhere in the kernel source files.
also i believe linux requires uboot to start it, would that mean i would have to flash uboot at 0x00000 for example and the kernel at 0x12345(end of uboot)?
the parameter file did not exist in kernel source .
you can unpack our firmware to get it
http://wiki.t-firefly.com/index.php/Firefly-RK3288/Customize_android_firmware/en
But that page is about RK3288, and the question was about RK3399. Many parameters should be different, and it’s quite tricky to get them all right. It would be appreciated if you could provide a parameter file on page http://wiki.t-firefly.com/index.php/Firefly-RK3399/Build_kernel/en that works with the kernel and the board that is actually described on that page. The instructions are really not complete without it.
You can get your current parameters file using rkflashtool:
rkflashtool p
Should return something like:
FIRMWARE_VER: 6.0.0
MACHINE_MODEL: RK3399
MACHINE_ID: 007
MANUFACTURER: RK3399
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 3399
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x00280000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
#in section; per section 512(0x200) bytes
CMDLINE: mtdparts=rk29xxnand:0x00001f40@0x00000040(loader1),0x00000080@0x00001f80(reserved1),0x00002000@0x00002000(reserved2),0x00002000@0x00004000(loader2),0x00002000@0x00006000(atf),0x00038000@0x00008000(boot:bootable),-@0x0040000(rootfs)
Workday Workday-Pro-Talent-and-Performance 인증시험 최신버전덤프만 마련하시면Workday Workday-Pro-Talent-and-Performance시험패스는 바로 눈앞에 있습니다. 주문하시면 바로 사이트에서 pdf파일을 다운받을수 있습니다. Workday Workday-Pro-Talent-and-Performance 덤프의 pdf버전은 인쇄 가능한 버전이라 공부하기도 편합니다. Workday Workday-Pro-Talent-and-Performance 덤프샘플문제를 다운받은후 굳게 믿고 주문해보세요. 궁금한 점이 있으시면 온라인서비스나 메일로 상담받으시면 됩니다.
The article was incredibly insightful and profound. We are offering C_BCWME_2504 exam test, full of valuable content, for free, hoping it proves helpful.
This is a wonderfully inspiring article, thank you for sharing! Best of luck! Sharing the 200-901 exam collection pdf materials with you all.
