I have a RK3288-plus, I have installed the latest version of Ubuntu 16.04 on it.
I have a Display with HDMI 2.0 input and a resolution of 3840x2160, it have built in speakers. (The HDMI cable is capable of UHD too.)
When I hook up the RK3288 to the display over HDMI it works fine with 1080p, but when I set it to 3840x2160@30 about a fifth of the display on the right side are just random lines.
(I ran “xrandr --output HDMI-1 --mode 3840x2160” in a terminal.)
But, what I really want is 3840x2160@60, the hardware is capable, but how to?
Where’s no option for sound out over HDMI ether, how do I fix this?
Hi
1 did you get the UHD resolution in “start->Setting->Display->Resolution”
2 what did you get in “start->Multimedia->PulsAudio Volume Control->Output Devices”
Graphic:
I can select the option 3840x2160 but the same thing happens as when selected via xrandr still those lines on the right side.
I tried all available options, 30, 25 and 24Hz (60Hz) is not available.
I just saw something strange when I ran “mount”, “/dev/mmcblk2p3 on / type ext4 (ro,relatime,data=ordered)”.
I can’t change any file in the file system due to / being read only.
Hi,
which firmware did you use? could you try a firmware named NO_VGA?
I think, the HDMI display connect to “VOP little” which can only support 2560X1600.
so .disable the VGA display then the HDMI display will connect to “VOP BIG”
I have flashed the Beta with NO VGA, but I have not tried hooking it upp to my monitor yet (I started the flashing just before I went to my job).
I have connected to the machine remotely, I rebooted the machine, the MAC-address for eth0 changes, this is bad because I want a static ip on the device.
What are the changes in the kernel config between the version with and the version without VGA?
I tested plugging in the display, when I set the output to 3840x2160@30 (still don’t get an alternative for 60Hz) the desktop is displayed almost perfectly.
The only thing is that there are som random lines “flying” across the screen making everything beneath the line jump. (Jump down a pixel or two.)
It looks like a problem with the syncing not being perfect.
How ever I will configure my own kernel and try it.
I’m so grateful for your article, it truly grabbed my attention. Enhance your IT expertise—free Sample AP-202 questions pdf available now! Best wishes for success!
Die Cohesity COH-285 Dumps von PrüfungFrage sind die Unterlagen, die von vielen Kadidaten geprüft sind. Und es kann die sehr hohe Durchlaufrate garantieren. Wenn Sie nach der Nutzung der Dumps bei der Cohesity COH-285 Zertifizierung durchgefallen sind, geben wir PrüfungFrage Ihnen voll Geld zurück. Oder können Sie auch die kostlosen aktualisierten Dumps bekommen. Mit der Garantie sorgen Sie sich bitte nicht.
