Have tried setup a multi user environment for the Android 7 image for the rk3399. I want to make sure there is a locked administrator user and a user that is only allowed to run a few apps.
I can add users and set restrictive rights in the settings app but I cannot activate the lock screen for any of the user to become effective nor limit the apps they access.
Also setting a different wallpaper does not seem to work.
Any advice tricks on what to install or configure for a build ?
Also the battery always indicates 50% which prohibits file system encryption to be initiated. Where can this be changed ?
The lock screen is apparently bypassed by default for box configurations as used by the firefly AOSP build. App limiting does work for some apps but not for the pre-installed rk apps.
Locally did the following to get the lock screen (re)enabled.
diff --git a/frameworks/base/services/core/java/com/android/server/am/ActivityRecord.java b/frameworks/base/services/core/java/com/android/server/am/ActivityRecord.java
index bbf7dc8..4c758c7 100644
— a/frameworks/base/services/core/java/com/android/server/am/ActivityRecord.java
+++ b/frameworks/base/services/core/java/com/android/server/am/ActivityRecord.java
@@ -1249,16 +1249,18 @@ final class ActivityRecord {
void windowsDrawnLocked() {
+// revert to stock android to have keyguard
//Launcher is drawn completed,box can exit bootanim, other product wait for keygurad drawn
Itexamdump는 유일하게 여러분이 원하는EXIN인증CITM시험관련자료를 해결해드릴 수 잇는 사이트입니다. 여러분이 다른 사이트에서도 관련덤프자료를 보셨을경우 페이지 아래를 보면 자료출처는 당연히 Itexamdump 일 것입니다. Itexamdump의 자료만의 제일 전면적이고 또 최신 업데이트일 것입니다.
