RK3399 U-Boot and bare metal development
Have anyone succeeded in running bare metal code on RK3399? I have U-boot compiled but the shell is missing many functions. For example, there’s no bootelf and no tftp. I tried enabling them by adding #define in config but it’s not helping, it seems like the support is not there to begin with. Is there a way of running a simple “Hello World” bare metal application on RK3399? Any suggestion would be greatly appreciated. Thanks!
in rockchip’s uboot ,you can add command like “bootk” in ./common/cmd_bootrk.c
isle Posted at 8/16/2017 09:49
How do I do that and what is bootk used for? I do not find it in standard u-boot documentation.
I just want to know how to boot from an elf file, currently it is not even possible to load the elf file into memory. I can’t do TFTP and I can’t load from a file.
which u-boot did you used?
maybe you can try the u-boot from android sdk.https://gitlab.com/TeeFirefly/FireNow-Nougat/tree/firefly-rk3399/u-boot
I had to hack around a bit to boot the .elf from the linux kernel partition but all is working fine now. However I have another request: how can I force the board to boot from the A72 cores instead? The bare-metal application I am using, I’d like to test it on the A72 cores instead of the A53 cores. Thanks!
with cpuset , search more on google.
I don’t have Linux installed or any kind of Linux kernel so I can’t use cpuset. All I have is trustzone, u-boot and a bare metal application. Is there any way to force the board to boot from A72 instead of A53? (basically disable the A53 cluster). Thanks!
Can anyone help me? I really need to boot from the A72 core instead of the A53 core. Thanks!
oh, the rk3399 don’t support boot from A72.
The article is very practical, and I have gained a lot of specific guidance from it. Best of luck with your exam preparations! UiAAAv1 reliable source questions available for free!
This is a stellar article, thank you for sharing it with us. Get free E_S4CON_2025 valid test cram sheet file to improve your IT knowledge. Wishing you all the best!
The article is very rich in content and has introduced me to many new perspectives. The Valid NSE6_FSR-7.3 exam dumps pdf exam is fast approaching. Hope I pass it!
研究により、学習への関心を刺激することが最善の解決策であることがわかっています。したがって、1z0-1066-25準備ガイドの焦点は、1z0-1066-25試験の準備方法を変更することにより、厳格で無駄なメモリモードを改革することです。 1z0-1066-25実践教材のソフトバージョンは、知識と最新テクノロジーを組み合わせて学習力を大幅に刺激します。楽しい学習シーンと鮮明な説明をシミュレートすることにより、ユーザーは資格のある1z0-1066-25試験に合格する自信が大きくなります。
