How can we root RK3399 device?
I think it’s already pretty much at root when you flash the firmware. The only thing that I’ve had trouble with is removing the RKBMC app and a few others, but there are root apps that can manage that for me.
ampstar Posted at 8/18/2017 18:35
I think it’s already pretty much at root when you flash the firmware. The only thing that I’ve had t …
we can access the su from Terminal but apps are not able to access the su. we are getting error operation not permitted.
Firefly-rk3399 root have already set in the developer options, just go to turn it on.
can you use that in Android?
leung先森 Posted at 8/19/2017 09:21
didnt find the root option in developer option. Can you please share the screenshot of your developer option?
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=1895. Its done using this link
I have the same problem and I have tried unsuccessfully to root the device.
If you search the forums people recommend downloading the “adb.exe” tool (Android Bridge Driver).
But when I plug the board into my PC, adb doesn’t recognise it as a device.
I have tried playing around with the usb settings (MTP, PTP, etc.) … but no luck.
Please let me know if you have luck rooting it because I need this solution as well.
Done. Factory Reset my RK3399 board and it worked.
So, follow the instructions here (http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=1895&highlight=root) … and you should be fine.
It was such an inspiring and educational read. Here comes the Vce Analytics-Con-301 torrent exam! Wish me luck and success!
