firefly-rk3399: Boot from SDMMC not working
Hi,
I’ve burned images into eMMC and it’s booting fine. then I have burned on SDMMC card and inserted into TFCARD reader on board.
The bootlog still shows booting from eMMC and hang at bootloader level, here is the log[1] and firefly-rk3388 claims that it support SDMMC boot [2], if So Do I miss anything.
Please let me know how should I boot from SDMMC?
[1] https://paste.ubuntu.com/25423391/
[2] http://wiki.t-firefly.com/index.php/Firefly-RK3399/Boot_mode/en
the loader of the SDMMC is not as same as the one of EMMC
so, please use this one if you want boot on SD .
https://drive.google.com/file/d/0B7HO8lbGgAqAR3FVYzAxbW5EMTg/view?usp=sharing
Thanks.
Can you send the steps how to write this image on SD card?
Here are the steps I tried with upgrade_tool
Rockusb>cd
List of rockusb connected
DevNo=1 Vid=0x2207,Pid=0x330c,LocationID=101 Loader
Found 1 rockusb,Select input DevNo,Rescan press ,Quit press :1
Rockusb>sd
The Device did not support this operation!
Rockusb>td
Test Device OK.
Rockusb>rid
Flash ID:45 4D 4D 43 20
Rockusb>rfi
Flash Info:
Manufacturer: SAMSUNG,value=00
Flash Size: 14910MB
Block Size: 512KB
Page Size: 2KB
ECC Bits: 0
Access Time: 40
Flash CS: Flash<0>
Rockusb>rci
Chip Info: 43 30 33 33 0 0 0 0 0 0 0 0 30 30 31 56
Rockusb>uf Firefly-rk3399_xubuntu1604_SD_201705151725.img
Loading firmware…
Loading firmware failed!
Rockusb>ul Firefly-rk3399_xubuntu1604_SD_201705151725.img
Loading loader…
Loading loader failed!
Rockusb>db Firefly-rk3399_xubuntu1604_SD_201705151725.img
Rockusb>ef firmware Firefly-rk3399_xubuntu1604_SD_201705151725.img
Loading loader…
Rockusb>ef loader Firefly-rk3399_xubuntu1604_SD_201705151725.img
Loading loader…
Rockusb>
http://wiki.t-firefly.com/index.php/Firefly-RK3288/Boot_Android_from_sd/en
or with “dd” command in linux.
Yes, it’s working.
Can you send steps for u-boot, I’ve build SPL(with ATF+Cortex-m0) and U-boot as two binaries, please send how to write it on SD and boot.
step: http://wiki.t-firefly.com/index.php/Firefly-RK3399/Uboot/en
code: https://github.com/rockchip-linux/u-boot
Broadcom인증 250-589덤프로Broadcom시험을 패스,하지 못하셨다구요? 최선을 다했는데도 실패하였다는 말은 영원히 하지마세요. Broadcom인증 250-589시험을 패스하는 방법은 많고도 많습니다. KoreaDumps의Broadcom인증 250-589덤프로 시험에 다시 도전해보세요. KoreaDumps의Broadcom인증 250-589덤프는 착한 가격에 100%에 달하는 적중율과 패스율을 보장해드립니다. 시험에서 불합격성적표를 받으시면 덤프구매시 지불한 덤프비용을 환불처리해드립니다. KoreaDumps의Broadcom인증 250-589덤프로 시험패스를 꿈꿔보세요.
What an encouraging read, thank you for sharing this article! Thanks to the Valid JN0-650 test collection sheet, I achieved a promotion and salary boost. Now it’s free for all. Best wishes in reaching your career goals!
Your article is truly inspiring, thank you for sharing such brilliance! Sharing CDPSE latest test guide materials questions for free—boost your career and salary with this key resource!
I’m all about this content—definitely liking it. Ready for the Valid exam CPB practice exam – hope I pass with flying colors!
No second thoughts, just hitting the like button for this great content. The C-THR95-2505 new test materials content is truly useful, and it’s all yours at no cost.
PassTIP에서 발췌한 Salesforce인증 MuleSoft-Integration-Architect-I덤프는 전문적인 IT인사들이 연구정리한 최신버전 Salesforce인증 MuleSoft-Integration-Architect-I시험에 대비한 공부자료입니다. Salesforce인증 MuleSoft-Integration-Architect-I 덤프에 있는 문제만 이해하고 공부하신다면Salesforce인증 MuleSoft-Integration-Architect-I시험을 한방에 패스하여 자격증을 쉽게 취득할수 있을것입니다.
This article is exceptional in every way, I’m so thankful for your share. Using this F3 reliable exam prep, I earned a promotion and raise. Now, it’s free for everyone. Best of luck in your career growth!
