Mark Posted at 12/5/2017 14:23
Hello, I too have been experimenting with the TopFoison 2K display panel (with its HDMI board, so no …
Mark it seems to me that it may be an audio issue Since my pc correctly idrntifies the panel as 2560x1440. reversing the orientation on firefly did not fix this.
I dont remember but I recall trying to force 1440x2560 through ADB to no success.
I believe the uboot or some config needs to be edited in order to bring the display online, but I am not sute where to look. Support has not been helpful.
according to the specification of the TopFoison 2k display panel, it has 2560 lines and each line has 1440 pixels. My PC nicely recognizes this as a “portrait” display (1440x2560). Of course, rotation function in Windows makes it possible to use it as a landscape oriented display.
If I look in the TRM document of the RK3399, there are two Video Output Processors (VOP_BIG, VOP_LITTLE). The VOP_BIG supports maximum output resolution of 4096x2160, VOP_LITTLE supports maximum resolution of 2560x1600. Consequently, the display requires more lines than the VOPs can deliver. For this reason, I can believe it will never work. I like to have this verified
However, would it be possible to have everything drawn 90 degrees rotated into the buffers? So internal buffers would require 2560x1440 buffers and just before going to the display (on the transmitter side, after the VOPs), rotate back. I don’t know, I don’t see any reference in the TRM that can do that.
I don’t believe so. I found documents that allow custom resolutions. It is just a matter of compiling the correct system image out of that. I also don’t see why VOP cannot be modified in a custom rims to allow more lines.
So far I only found clues that indicate it will not work. I also can’t find rotator-blocks that might circumvent the problem. And indeed, the documentation is very little. Custom resolutions are supported and modifications can be done, but you have to keep the maximum resolutions in mind that each HW-block has (in the chain to the display panel). As the image has to go thru the VOP and the HDMI transmitter, the VOP has a maximum on supported image size, which is smaller than required for the display (considering vertical direction then). I haven’t found the maximum supported frame timings of the HDMI transmitter though.
Thank you for your article, it left an unforgettable impression on me. Latest test cram Platform-App-Builder sheet file was the catalyst for my career and salary increase—now I’m giving it to you for free!
Thank you for this article, it’s left a lasting impression on me. I used the ZDTE valid exam simulator fee to earn a promotion and salary boost. Now, it’s free for everyone. Best of luck on your career journey!
DumpTOP에서는 BICSI인증 INSTC_V8시험을 도전해보시려는 분들을 위해 퍼펙트한 BICSI인증 INSTC_V8덤프를 가벼운 가격으로 제공해드립니다.덤프는BICSI인증 INSTC_V8시험의 기출문제와 예상문제로 제작된것으로서 시험문제를 거의 100%커버하고 있습니다. DumpTOP제품을 한번 믿어주시면 기적을 가져다 드릴것입니다.
This article is so powerful, thank you for the inspiration! Wishing you success! Here are the free Reliable 3V0-22.25 exam dumps materials resources for you!
