求助——rk3288 Ubuntu如何旋转屏幕
板子是firefly rk3288,烧的官方最新的Ubuntu固件,现在想把屏幕旋转90度,变成竖屏,有做过的吗?需要重新编译固件吗?请大神指点一下
i am also studying this problem. i am on RK3288 now so i cannot type chinese.
i also used another board named HummingBird (with A20 & MaliT400). on that board, just install the drivers (kernal & user space) provided on the official site, and then edit /usr/share/X11/xorg.conf.d/99-sunxifb.conf, and it can rotate the display.
but the system gets slower after i do that.
i am searching the similar way to get the portrait display on RK3288, but not successful yet.
I have successfully done it!
But there are other problems such as touchscreen problem after the rotation.
I will go on studying this.
But there are other problems such as touchscreen problem after the rot …
Can you solve it?
hei bigboss, how do you fix this problem? show your method pls!!!
可以参考这个维基。
http://wiki.t-firefly.com/zh_CN/Firefly-RK3288/ubuntu_support.html#ping-mu-xuan-zhuan
