Ubuntu Linux failed to boot!
Hello everyone,
I tried to install Ubuntu onto RK3399 board.
Exact image file is " Firefly-rk3399_xubuntu1604_201705111112.img " .
When I flashed the image , system can’t boot - it stops during kernel load - see UART debug below.
What is wrong ? Has anyone seen this as well?
DDR Version 1.07 20161103
Channel 0: LPDDR3, 666MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB
Channel 1: LPDDR3, 666MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1848
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 63984
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 79548
LoaderFlag2: 0x0
WARNING: plat_rockchip_comm_sram_init:code:ff8d9000, 67000, ef0
NOTICE: BL31: v1.2(debug):b995f80
NOTICE: BL31: Built : 16:53:56, Nov 7 2016
INFO: boot cpu mask: 0
INFO: Vesion: 2016.0.01
INFO: plat_rockchip_pmu_init(1211): pd status 3e
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3399-06-ga7c7ca8 (Apr 25 2017 - 15:10:21)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
no key node
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2017-04-25#1.05
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x01192e40)
ramdisk @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005613a89 … OK
Add bank:0000000000200000, 00000000f7e00000
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.52 (whh@esky14) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #19 SMP Tue May 2 11:36:30 HKT 2017 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7eea000 s46144 r8192 d31680 u86016 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432 [ 0.000000] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-04-25_15:10:21 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB [mem 0xef600000-0xf3600000] (64MB) mapped at [ffffffc0ef600000-ffffffc0f35fffff] [ 0.000000] Memory: 3903556K/4061184K available (11454K kernel code, 1355K rwdata, 4016K rodata, 1152K init, 764K bss, 157628K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) [ 0.000000] .init : 0xffffff8008fa0000 - 0xffffff80090c0000 ( 1152 KB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bb0000 ( 11456 KB) [ 0.000000] .rodata : 0xffffff8008bb0000 - 0xffffff8008fa0000 ( 4032 KB) [ 0.000000] .data : 0xffffff80090c0000 - 0xffffff8009212e40 ( 1356 KB) [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual) [ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB) [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB) [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @ef000000 (psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000000ef080000 [ 0.000000] ITS: Allocated 1792 chunks for LPIs [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] CPU0: using LPI pending table @0x00000000ef090000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001180] Console: colour dummy device 80x25 [ 0.001206] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [ 0.001220] pid_max: default: 32768 minimum: 301 [ 0.001312] Security Framework initialized [ 0.001322] Yama: becoming mindful. [ 0.001402] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.001413] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.002235] Initializing cgroup subsys devices [ 0.002258] Initializing cgroup subsys freezer [ 0.002286] ftrace: allocating 42895 entries in 168 pages [ 0.118883] sched-energy: Sched-energy-costs installed from DT [ 0.118902] CPU0: update cpu_capacity 401 [ 0.118965] ASID allocator initialised with 65536 entries [ 0.119807] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.120232] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.121380] Detected VIPT I-cache on CPU1 [ 0.121414] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.121451] CPU1: using LPI pending table @0x00000000ef2a0000 [ 0.121498] CPU1: update cpu_capacity 401 [ 0.121503] CPU1: Booted secondary processor [410fd034] [ 0.122043] Detected VIPT I-cache on CPU2 [ 0.122064] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.122097] CPU2: using LPI pending table @0x00000000ef2d0000 [ 0.122126] CPU2: update cpu_capacity 401 [ 0.122129] CPU2: Booted secondary processor [410fd034] [ 0.122612] Detected VIPT I-cache on CPU3 [ 0.122633] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.122667] CPU3: using LPI pending table @0x00000000ef300000 [ 0.122695] CPU3: update cpu_capacity 401 [ 0.122698] CPU3: Booted secondary processor [410fd034] [ 0.123218] Detected PIPT I-cache on CPU4 [ 0.123249] CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.123285] CPU4: using LPI pending table @0x00000000ef350000 [ 0.123328] CPU4: update cpu_capacity 1024 [ 0.123331] CPU4: Booted secondary processor [410fd082] [ 0.123853] Detected PIPT I-cache on CPU5 [ 0.123872] CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.123906] CPU5: using LPI pending table @0x00000000ef380000 [ 0.123934] CPU5: update cpu_capacity 1024 [ 0.123938] CPU5: Booted secondary processor [410fd082] [ 0.124025] Brought up 6 CPUs [ 0.124107] SMP: Total of 6 processors activated. [ 0.124116] CPU features: detected feature: GIC system register CPU interface [ 0.124129] CPU: All CPU(s) started at EL2 [ 0.124176] alternatives: patching kernel code [ 0.125553] devtmpfs: initialized [ 0.145530] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.145566] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 0.146113] pinctrl core: initialized pinctrl subsystem [ 0.147200] NET: Registered protocol family 16 [ 0.151182] cpuidle: using governor ladder [ 0.155204] cpuidle: using governor menu [ 0.155231] Registered FIQ tty driver [ 0.155632] vdso: 2 pages (1 code @ ffffff8008bb6000, 1 data @ ffffff80090c4000) [ 0.155666] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.155861] DMA: preallocated 256 KiB pool for atomic allocations [ 0.245808] console [ttyFIQ0] enabled [ 0.246340] Registered fiq debugger ttyFIQ0 [ 0.269899] ACPI: Interpreter disabled.
works well in android?
Tried Android (7.1) and got the same problem. Board hangs during boot. When push RSET it starts reboots in series , one after another. But with Android I can see a logo on HDMI monitor :slight_smile:
Look like the board is faulty , I 'll look for another one .
Long UART output with Android is below - just in case …
DDR Version 1.08 20170320
Channel 0: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Channel 1: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
Boot1: 2017-03-07, version: 1.06
CPUId = 0x0
ChipType = 0x10, 1836
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
SdmmcInit=0 20
StorageInit ok = 68012
LoadTrustBL
No find bl30.bin
No find bl32.bin
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):55aa0b4
NOTICE: BL31: Built : 16:55:03, Mar 31 2017
INFO: plat_rockchip_pmu_init(1089): pd status 3e
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3399-06 (May 16 2017 - 19:22:40)
CPU: rk3399
cpu version = 0
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 792000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
power key: bank-0 pin-5
pmic:rk808
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 792000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2017-05-16#1.06
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
can’t find power_ctr node for panel
enable[0] disable[0]
no fuel gauge found
can’t find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 1478502959x706760016@1634231072-1953696303
failed to display kernel logo
checkKey
vbus = 0
got recovery cmd from misc.
kernel @ 0x00280000 (0x011f7420)
ramdisk @ 0x05bf0000 (0x00778ae8)
Loading Device Tree to 0000000005600000, end 0000000005614937 … OK
[ 0.000000] Linux version 4.4.55 (firefly@tchip-server) (gcc version 4.9 20150123 (prerelease) (GCC) ) #2 SMP PREEMPT Mon May 15 11:04:11 CST 2017
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef6000 s45248 r8192 d32576 u86016
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-05-16_19:22:41 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0xf6eae000-0xf6eee000] (0MB) mapped at [ffffffc0f6eae000-ffffffc0f6eedfff]
[ 0.000000] Memory: 3944008K/4061184K available (11198K kernel code, 1372K rwdata, 4948K rodata, 832K init, 1079K bss, 100792K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009050000 - 0xffffff8009120000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b70000 ( 11200 KB)
[ 0.000000] .rodata : 0xffffff8008b70000 - 0xffffff8009050000 ( 4992 KB)
[ 0.000000] .data : 0xffffff8009120000 - 0xffffff80092772e0 ( 1373 KB)
[ 0.000000] ITS: allocated 65536 Devices @f2000000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000f2080000
[ 0.000000] CPU0: using LPI pending table @0x00000000f2090000
[ 0.001803] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002767] pid_max: default: 32768 minimum: 301
[ 0.003263] Security Framework initialized
[ 0.003652] SELinux: Initializing.
[ 0.004085] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004715] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006208] Initializing cgroup subsys freezer
[ 0.006637] Initializing cgroup subsys debug
[ 0.007904] sched-energy: Sched-energy-costs installed from DT
[ 0.008452] CPU0: update cpu_capacity 401
[ 0.008911] ASID allocator initialised with 65536 entries
[ 0.025729] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.026963] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039115] Detected VIPT I-cache on CPU1
[ 0.039146] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039182] CPU1: using LPI pending table @0x00000000f2200000
[ 0.039225] CPU1: update cpu_capacity 401
[ 0.039228] CPU1: Booted secondary processor [410fd034]
[ 0.049114] Detected VIPT I-cache on CPU2
[ 0.049132] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049165] CPU2: using LPI pending table @0x00000000f2230000
[ 0.049193] CPU2: update cpu_capacity 401
[ 0.049196] CPU2: Booted secondary processor [410fd034]
[ 0.059152] Detected VIPT I-cache on CPU3
[ 0.059171] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059203] CPU3: using LPI pending table @0x00000000f2270000
[ 0.059230] CPU3: update cpu_capacity 401
[ 0.059233] CPU3: Booted secondary processor [410fd034]
[ 0.069190] Detected PIPT I-cache on CPU4
[ 0.069217] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069252] CPU4: using LPI pending table @0x00000000f22b0000
[ 0.069293] CPU4: update cpu_capacity 1024
[ 0.069296] CPU4: Booted secondary processor [410fd082]
[ 0.079219] Detected PIPT I-cache on CPU5
[ 0.079237] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079270] CPU5: using LPI pending table @0x00000000f22f0000
[ 0.079297] CPU5: update cpu_capacity 1024
[ 0.079300] CPU5: Booted secondary processor [410fd082]
[ 0.079384] Brought up 6 CPUs
[ 0.091481] SMP: Total of 6 processors activated.
[ 0.091923] CPU features: detected feature: GIC system register CPU interface
[ 0.092593] CPU: All CPU(s) started at EL2
[ 0.093016] alternatives: patching kernel code
[ 0.094671] devtmpfs: initialized
[ 0.114251] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.115185] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.116804] pinctrl core: initialized pinctrl subsystem
[ 0.119830] Failed to find legacy iommu devices
[ 0.120814] NET: Registered protocol family 16
[ 0.121948] schedtune: init normalization constants…
[ 0.122435] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.123046] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.123656] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.124281] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124893] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.125505] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.126116] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126727] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.127338] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127959] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.128672] schedtune: verify normalization constants…
[ 0.129170] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129691] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.130212] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130734] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.131256] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131786] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.132307] schedtune: configured to support 4 boost groups
[ 0.141827] cpuidle: using governor ladder
[ 0.155186] cpuidle: using governor menu
[ 0.155572] Registered FIQ tty driver
[ 0.156558] vdso: 2 pages (1 code @ ffffff8008b76000, 1 data @ ffffff8009124000)
[ 0.157275] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.158729] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.183307] console [pstore0] enabled
[ 0.183857] pstore: Registered ramoops as persistent store backend
[ 0.184440] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.188217] console [ttyFIQ0] enabled
[[ 0.188217] console [ttyFIQ0] enabled
[ 0.188778] bootconsole [uart0] disabled
[ 0.189993] Registered fiq debugger ttyFIQ0
[ 0.237178] Rockchip hdmi driver version 2.0
[ 0.239249] iommu: Adding device ff650000.vpu_service to group 0
[ 0.239332] iommu: Adding device ff660000.rkvdec to group 1
[ 0.239397] iommu: Adding device ff670000.iep to group 2
[ 0.239529] iommu: Adding device ff8f0000.vop to group 3
[ 0.239604] iommu: Adding device ff900000.vop to group 4
[ 0.239696] iommu: Adding device ff910000.isp to group 5
[ 0.239770] iommu: Adding device ff920000.isp to group 6
[ 0.240413] rk_iommu ff670800.iommu: can’t get aclk
[ 0.240435] rk_iommu ff670800.iommu: can’t get hclk
[ 0.241240] SCSI subsystem initialized
[ 0.241589] usbcore: registered new interface driver usbfs
[ 0.241634] usbcore: registered new interface driver hub
[ 0.241710] usbcore: registered new device driver usb
[ 0.242040] media: Linux media interface: v0.10
[ 0.242080] Linux video capture interface: v2.00
[ 0.242201] pps_core: LinuxPPS API ver. 1 registered
[ 0.242212] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.242236] PTP clock support registered
[ 0.243516] Advanced Linux Sound Architecture Driver Initialized.
[ 0.243994] Bluetooth: Core ver 2.21
[ 0.244024] NET: Registered protocol family 31
[ 0.244035] Bluetooth: HCI device and connection manager initialized
[ 0.244051] Bluetooth: HCI socket layer initialized
[ 0.244064] Bluetooth: L2CAP socket layer initialized
[ 0.244092] Bluetooth: SCO socket layer initialized
[ 0.245351] clocksource: Switched to clocksource arch_sys_counter
[ 0.283862] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.284078] NET: Registered protocol family 2
[ 0.284503] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.284689] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.284930] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.285006] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.285060] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.285237] NET: Registered protocol family 1
[ 0.285736] Trying to unpack rootfs image as initramfs…
[ 0.609067] Freeing initrd memory: 7648K (ffffffc005bf0000 - ffffffc006368000)
[ 0.609615] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.609701] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.612198] audit: initializing netlink subsys (disabled)
[ 0.612261] audit: type=2000 audit(0.606:1): initialized
[ 0.620548] VFS: Disk quotas dquot_6.6.0
[ 0.620674] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.622044] fuse init (API version 7.23)
[ 0.626594] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.626623] io scheduler noop registered
[ 0.626783] io scheduler cfq registered (default)
[ 0.628007] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.632069] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.632098] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.632116] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.635355] pll lock timeout!
[ 1.635376] phy phy-phy@e220.5: phy poweron failed → -22
[ 1.635390] rockchip-pcie f8000000.pcie: fail to power on phy, err -22
[ 1.635448] rockchip-pcie: probe of f8000000.pcie failed with error -22
[ 1.636079] rockchip ion idev is NULL
[ 1.636093] rga2 ff680000.rga: rga ion client create success!
[ 1.636266] rga: Driver loaded successfully ver:3.02
[ 1.636932] iep: failed to find iep power down clock source.
[ 1.637273] IEP Power ON
[ 1.637429] IEP Power OFF
[ 1.637459] IEP Driver loaded succesfully
[ 1.637545] Module initialized.
[ 1.641272] rk-vcodec ff650000.vpu_service: No core reset resource define
[ 1.641328] rk-vcodec ff650000.vpu_service: do not have pd_video
[ 1.641351] rk-vcodec ff650000.vpu_service: probe device
[ 1.641392] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f231e810
[ 1.641531] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.641589] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.641993] rk-vcodec ff650000.vpu_service: init success
[ 1.645673] rk-vcodec ff660000.rkvdec: No core reset resource define
[ 1.645782] rk-vcodec ff660000.rkvdec: do not have pd_video
[ 1.645802] rk-vcodec ff660000.rkvdec: probe device
[ 1.645843] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f231f010
[ 1.645976] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.646034] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.646328] rk-vcodec ff660000.rkvdec: init success
[ 1.647708] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.647729] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.649075] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.649093] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
k6▒▒Ks3{6▒▒Ks3{▒6▒▒Kz
cK : eff542b019a556dd
[ 1.650499] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.651785] console [ttyS0] disabled
[ 1.651828] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 1.652391] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.652775] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.656489] mali ff9a0000.gpu: Failed to get regulator
[ 1.656513] mali ff9a0000.gpu: Power control initialization failed
[ 1.656805] Unable to detect cache hierarchy from DT for CPU 0
[ 1.667722] brd: module loaded
[ 1.672345] loop: module loaded
[ 1.672840] zram: Added device: zram0
[ 1.673363] SCSI Media Changer driver v0.25
[ 1.674305] tun: Universal TUN/TAP device driver, 1.6
[ 1.674322] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.675396] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.675424] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.675439] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.675628] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.675641] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.680716] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.680733] Ring mode enabled
[ 1.680742] DMA HW capability register supported
[ 1.680751] Normal descriptors
[ 1.680763] RX Checksum Offload Engine supported (type 2)
[ 1.680772] TX Checksum insertion supported
[ 1.680781] Wake-Up On Lan supported
[ 1.680824] Enable RX Mitigation via HW Watchdog Timer
[ 1.746263] libphy: stmmac: probed
[ 1.746283] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.746295] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.747011] PPP generic driver version 2.4.2
[ 1.747180] PPP BSD Compression module registered
[ 1.747194] PPP Deflate Compression module registered
[ 1.747222] PPP MPPE Compression module registered
[ 1.747240] NET: Registered protocol family 24
[ 1.747280] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.747292] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.747315] Rockchip WiFi SYS interface (V1.00) …
[ 1.747397] usbcore: registered new interface driver catc
[ 1.747439] usbcore: registered new interface driver kaweth
[ 1.747454] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.747491] usbcore: registered new interface driver pegasus
[ 1.747532] usbcore: registered new interface driver rtl8150
[ 1.747572] usbcore: registered new interface driver r8152
[ 1.747587] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.747643] usbcore: registered new interface driver hso
[ 1.747691] usbcore: registered new interface driver asix
[ 1.747732] usbcore: registered new interface driver ax88179_178a
[ 1.747772] usbcore: registered new interface driver cdc_ether
[ 1.747816] usbcore: registered new interface driver cdc_eem
[ 1.747862] usbcore: registered new interface driver dm9601
[ 1.747913] usbcore: registered new interface driver smsc75xx
[ 1.747962] usbcore: registered new interface driver smsc95xx
[ 1.748002] usbcore: registered new interface driver gl620a
[ 1.748045] usbcore: registered new interface driver net1080
[ 1.748085] usbcore: registered new interface driver plusb
[ 1.748126] usbcore: registered new interface driver rndis_host
[ 1.748168] usbcore: registered new interface driver cdc_subset
[ 1.748208] usbcore: registered new interface driver zaurus
[ 1.748249] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.748309] usbcore: registered new interface driver int51x1
[ 1.748349] usbcore: registered new interface driver kalmia
[ 1.748390] usbcore: registered new interface driver ipheth
[ 1.748435] usbcore: registered new interface driver sierra_net
[ 1.748476] usbcore: registered new interface driver cx82310_eth
[ 1.748528] usbcore: registered new interface driver cdc_ncm
[ 1.748569] usbcore: registered new interface driver qmi_wwan
[ 1.748612] usbcore: registered new interface driver cdc_mbim
[ 1.749758] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.752909] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.753479] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.753498] ehci-pci: EHCI PCI platform driver
[ 1.753553] ehci-platform: EHCI generic platform driver
[ 1.755327] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.755374] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.755517] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.765378] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.765504] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.765520] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.765534] usb usb1: Product: EHCI Host Controller
[ 1.765545] usb usb1: Manufacturer: Linux 4.4.55 ehci_hcd
[ 1.765556] usb usb1: SerialNumber: fe3c0000.usb
[ 1.766013] hub 1-0:1.0: USB hub found
[ 1.766045] hub 1-0:1.0: 1 port detected
[ 1.766513] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.766542] ohci-platform: OHCI generic platform driver
[ 1.766991] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.767018] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.767141] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.822823] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.822843] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.822858] usb usb2: Product: Generic Platform OHCI controller
[ 1.822870] usb usb2: Manufacturer: Linux 4.4.55 ohci_hcd
[ 1.822882] usb usb2: SerialNumber: fe3e0000.usb
[ 1.823291] hub 2-0:1.0: USB hub found
[ 1.823323] hub 2-0:1.0: 1 port detected
[ 1.824066] usbcore: registered new interface driver cdc_acm
[ 1.824079] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.824138] usbcore: registered new interface driver usblp
[ 1.824184] usbcore: registered new interface driver cdc_wdm
[ 1.824230] usbcore: registered new interface driver uas
[ 1.824306] usbcore: registered new interface driver usb-storage
[ 1.824348] usbcore: registered new interface driver ums-alauda
[ 1.824389] usbcore: registered new interface driver ums-cypress
[ 1.824430] usbcore: registered new interface driver ums-datafab
[ 1.824472] usbcore: registered new interface driver ums_eneub6250
[ 1.824513] usbcore: registered new interface driver ums-freecom
[ 1.824557] usbcore: registered new interface driver ums-isd200
[ 1.824598] usbcore: registered new interface driver ums-jumpshot
[ 1.824641] usbcore: registered new interface driver ums-karma
[ 1.824683] usbcore: registered new interface driver ums-onetouch
[ 1.824724] usbcore: registered new interface driver ums-sddr09
[ 1.824765] usbcore: registered new interface driver ums-sddr55
[ 1.824807] usbcore: registered new interface driver ums-usbat
[ 1.824882] usbcore: registered new interface driver usbserial
[ 1.824918] usbcore: registered new interface driver usbserial_generic
[ 1.824952] usbserial: USB Serial support registered for generic
[ 1.824994] usbcore: registered new interface driver option
[ 1.825023] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.825123] usbcore: registered new interface driver trancevibrator
[ 1.825140] usb20_otg: version 3.10a 21-DEC-2012
[ 1.825294] usb20_host: version 3.10a 21-DEC-2012
[ 1.829098] usbcore: registered new interface driver xpad
[ 1.829151] usbcore: registered new interface driver usb_acecad
[ 1.829197] usbcore: registered new interface driver aiptek
[ 1.829244] usbcore: registered new interface driver gtco
[ 1.829292] usbcore: registered new interface driver hanwang
[ 1.829337] usbcore: registered new interface driver kbtab
[ 1.829353] ==gsl_ts_init==
[ 1.829381] ret=0
[ 1.833104] .. rk pwm remotectl v1.1 init
[ 1.833329] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.833728] sensor_register_slave:mma8452,id=17
[ 1.833746] sensor_register_slave:lis3dh,id=7
[ 1.833761] sensor_register_slave:mma7660,id=18
[ 1.833776] sensor_register_slave:lsm303d,id=22
[ 1.833791] sensor_register_slave:mpu6880_acc,id=24
[ 1.833805] sensor_register_slave:mpu6500_acc,id=25
[ 1.833820] sensor_register_slave:lsm330_acc,id=26
[ 1.833836] sensor_register_slave:akm8975,id=28
[ 1.833851] sensor_register_slave:akm8963,id=29
[ 1.833865] sensor_register_slave:l3g4200d,id=43
[ 1.833880] sensor_register_slave:l3g20d,id=44
[ 1.833895] sensor_register_slave:ewtsa,id=45
[ 1.833910] sensor_register_slave:lsm330_gyro,id=48
[ 1.833925] sensor_register_slave:cm3217,id=50
[ 1.833939] sensor_register_slave:cm3218,id=51
[ 1.834553] i2c /dev entries driver
[ 1.835690] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.835755] fan53555-reg: supplied by vcc5v0_sys
[ 1.837967] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.838014] fan53555-reg: supplied by vcc5v0_sys
[ 1.840076] rk808 0-001b: Pmic Chip id: 0x0
[ 1.843159] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.843212] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.843303] DCDC_REG1: supplied by vcc3v3_sys
[ 1.843941] DCDC_REG2: supplied by vcc3v3_sys
[ 1.844432] DCDC_REG3: supplied by vcc3v3_sys
[ 1.844630] DCDC_REG4: supplied by vcc3v3_sys
[ 1.844991] LDO_REG1: supplied by vcc3v3_sys
[ 1.846024] LDO_REG2: supplied by vcc3v3_sys
[ 1.846902] LDO_REG3: supplied by vcc3v3_sys
[ 1.847775] LDO_REG4: supplied by vcc3v3_sys
[ 1.848669] LDO_REG5: supplied by vcc3v3_sys
[ 1.849569] LDO_REG6: supplied by vcc3v3_sys
[ 1.850444] LDO_REG7: supplied by vcc3v3_sys
[ 1.851339] LDO_REG8: supplied by vcc3v3_sys
[ 1.852229] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.852436] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.855716] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.856224] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80095fe000
[ 1.856765] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009682000
[ 1.869939] fusb302 4-0022: port 0 probe success
[ 1.869976] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009684000
[ 1.870790] IR NEC protocol handler initialized
[ 1.870804] IR RC5(x/sz) protocol handler initialized
[ 1.870818] IR RC6 protocol handler initialized
[ 1.870831] IR JVC protocol handler initialized
[ 1.870844] IR Sony protocol handler initialized
[ 1.870857] IR SANYO protocol handler initialized
[ 1.870870] IR Sharp protocol handler initialized
[ 1.870883] IR MCE Keyboard/mouse protocol handler initialized
[ 1.870896] IR XMP protocol handler initialized
[ 1.870985] usbcore: registered new interface driver uvcvideo
[ 1.870995] USB Video Class driver (1.1.1)
[ 1.871024] CamSys driver version: v0.33.11, CamSys head file version: v0.13.0
[ 1.872075] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[ 1.872075]
[ 1.872159] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy0 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.872159]
[ 1.872183] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy1 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.872183]
[ 1.872998] D1:camsys_platform_probe(1527): ff910000.isp memory:
[ 1.873013] D1:camsys_platform_probe(1543): Register memory (phy: 0xff910000 vir: 0xffffff8009688000 size: 0x4000)
[ 1.873029] D1:camsys_platform_probe(1535): I2c memory (phy: 0x5cc3000 vir: 0xffffffc005cc3000 size: 0x1000)
[ 1.873043] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.873054] D1:camsys_platform_probe(1557): Probe ff910000.isp device success
[ 1.874190] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[ 1.874190]
[ 1.874256] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy0 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.874256]
[ 1.874281] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy1 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.874281]
[ 1.875018] D1:camsys_platform_probe(1527): ff920000.isp memory:
[ 1.875032] D1:camsys_platform_probe(1543): Register memory (phy: 0xff920000 vir: 0xffffff80096b8000 size: 0x4000)
[ 1.875047] D1:camsys_platform_probe(1535): I2c memory (phy: 0x5cdd000 vir: 0xffffffc005cdd000 size: 0x1000)
[ 1.875061] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.875072] D1:camsys_platform_probe(1557): Probe ff920000.isp device success
[ 1.875412] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.875539] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.875777] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.875880] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.877086] rockchip_cpu_avs: cluster0 leakage=18 adjust_volt=0
[ 1.877125] rockchip_cpu_avs: cluster1 leakage=32 adjust_volt=0
[ 1.878198] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.878812] device-mapper: uevent: version 1.0.3
[ 1.879097] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.882588] Bluetooth: HCI UART driver ver 2.3
[ 1.882602] Bluetooth: HCI UART protocol H4 registered
[ 1.882613] Bluetooth: HCI UART protocol LL registered
[ 1.882627] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.882638] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.882648] rtk_btusb: Register usb char device interface for BT driver
[ 1.882844] usbcore: registered new interface driver rtk_btusb
[ 1.
dmitry Posted at 9/3/2017 02:36
Tried Android (7.1) and got the same problem. Board hangs during boot. When push RSET it starts rebo …
why do not try the newest android7.1 firmware
The board came with preinstalled Andriod 7.1.2 and it was running ok
But we need Ubuntu for our project. When I flashed a second board with Firefly-rk3399_xubuntu1604_201705111112.img , I got the similar issue , nothing on HDMI monitor . What could be a reason for this? The only difference with flashing guide is that I used Windows 10 on host machine (don’t have anything else at the moment) ? Could it be a reason ?
Hi
the second board. with the same UART log?
Please use pastebin when pasting walls of text
https://pastebin.com/
Hi dmitry,
did you meanwhile fix this problem ? I have exactly the same issue. My hardware revision is VS-RK3399-V2.0, 20170729.
Your article has made a lasting impression, thank you! The IFC new study guide questions are available for free. Wishing you the best of luck in your exams!
I’m deeply moved by your article, thank you for sharing it. Upgrade your IT knowledge with free AZ-800 valid test labs. Wishing you all the best!
I found the article to be incredibly beneficial to my understanding. Here’s the Real CPOA testing environment exam that boosted my career with a promotion and salary increase. It’s free today for all! Wishing you success in your career journey.
Die Schulungsunterlagen zur Pure Storage FAAA_005 Zertifizierungsprüfung von ZertFragen sind die besten Schulungsunterlagen zur Pure Storage FAAA_005 Zertifizierungsprüfung. Sie sind die besten Schulungsunterlagen unter allen Schulungsunterlagen. Sie können Ihnen nicht nur helfen, die Pure Storage FAAA_005 Prüfung erfolgreich zu bestehen, Ihre Fachkenntnisse und Fertigkeiten zu verbessern und auch eine Karriere zu machen. Sie werden von allen Ländern gleich behandelt.
