SD card boot fail
I am trying to boot a firefly rk3288 from sd card. I downloaded the sd card image 201503021436 from your link and wrote it to an sd card using the sd firmware tool 1.45. However, when booting, I got a lot of error messages which seemed the parameter file was incorrect and the kernel/image was bad.
GetParam
W: Invalid Parameter’s tag (0x7BD32A6C)!
Invalid parameter
W: Invalid Parameter’s tag (0xF07F8F7D)!
Invalid parameter
W: Invalid Parameter’s tag (0xAE8ED94E)!
Invalid parameter
W: Invalid Parameter’s tag (0x5EFFD968)!
Invalid parameter
W: Invalid Parameter’s tag (0xEDDF0B28)!
Invalid parameter
W: Invalid Parameter’s tag (0xE89DA830)!
Invalid parameter
W: Invalid Parameter’s tag (0x00000802)!
Invalid parameter
W: Invalid Parameter’s tag (0x00000000)!
Invalid parameter
failed to find part:boot
failed to find part:resource
failed to prepare fdt from resource!
I found another thread saying which had the similar issue (http://bbs.t-firefly.com /forum.php?mod=viewthread&tid=1777&extra=&page=1) and tried that solution of cleaning the emmc of spl and uboot. However, I still could not boot the board:
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Oct 13 2016 - 10:04:48)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
Adding bank:0000000000000000(0000000100000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 0
SDCard Boot.
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 0000-00-00#0.00
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
boot or recovery image sha mismatch!
Unable to boot:boot
try to start recovery
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
ERROR: [rk_load_image_from_storage]: bootrk: bad boot or kernel image
Unable to boot:backup
try to start rockusb
I have successfully boot from sd card last year with previous boards. But it seems to have stopped working with the new boards.
Also, for my application, I want to be able to boot from sd card without having to modify the emmc for each board. Is it possible to provide a new sd card boot.
Yes ,the old firmware did not support our new device.
在現在這個人才濟濟的社會裏,還是有很多行業是缺乏人才的,比如IT行業就相當缺乏技術性的人才。而CIPS L4M4 認證考試就是個檢驗IT技術的認證考試之一。Fast2test是一個給你培訓CIPS L4M4 認證考試相關技術知識的網站。
ISACA인증AAIA시험을 위하여 최고의 선택이 필요합니다. ExamPassdump 선택으로 좋은 성적도 얻고 하면서 저희 선택을 후회하지 않을것니다.돈은 적게 들고 효과는 아주 좋습니다.우리ExamPassdump여러분의 응시분비에 많은 도움이 될뿐만아니라ISACA인증AAIA시험은 또 일년무료 업데이트서비스를 제공합니다.작은 돈을 투자하고 이렇게 좋은 성과는 아주 바람직하다고 봅니다.
I’m grateful to have come across such a fantastic article. The content in C-BCSPM-2502 real question on the exam is available for free, created to help you succeed.
That article was nothing short of a masterpiece in terms of knowledge. D-UN-OE-23 dumps free provides quality resources, and they’re free for you to use.
