Hello,
I bought the B-Key SSD Adapter board from the Firefly store and mounted it into my RK3399 board. I have a 120 GB SSD from SanDIsk connected via the supplied cables. Alas, I did not find my drive under /dev after booting Xubuntu 16.04 (I am using official T-Firefly release Firefly-rk3399_xubuntu1604_201705111112). When I checked dmesg, I noticed a lot of errors related to PCIe. If there is anyone on the forum who had a similar problem and solved it, please share the solution. For any interested developers, I am attaching the dmesg capture to this thread.
Any help will be greatly appreciated!
ffly_rk3399_4.4.52.log.zip (21.5 KB)
So - not sure if you got anywhere with this but the errors in the log say that the pcie bus isn’t configured to be powered up in the device tree - have you grabbed a newer ubuntu image & tried again?
As far as I know the device tree is configured in the dts files at compile time
I’ll be honest I’m investigating a similar problem with m.2 - different card though - I would be interested to hear if you have had any luck
OK, a closer look at your logs show that the PCIE bus is actually coming up, and attempting to enable a device
you should be able to see the sata adapter with lspci - if you can’t then try a newer image - there is a quite recent one
Thank you for your article; it truly shocked me! Best of luck! Here are the free XSIAM-Analyst valid exam objectives materials to help you!
I was really impressed by the depth and breadth of the article. SOL-C01 latest practice test online provides quality content, and it’s completely free.
Thank you for sharing such a motivational and uplifting article! The L5M8 reliable exam dumps demo study materials are available for free—good luck!
This article is incredibly motivating, thank you for sharing it! This is the 220-1202 vce exam exam I took to get my promotion and pay raise, now available to you for free today. I hope you reach your professional goals soon!
This article is so uplifting, thank you for sharing it! Sharing the EX-Con-101 reliable real test answer exam that got me my promotion and salary raise—it’s free for all today. Hope you all achieve your professional dreams!
Your article really stuck with me, I’m sincerely grateful. I hope the C1000-182 Pass4sure exam prep materials are helpful to you, and they’re offered free of charge.
