I have two question:
- Where is the source code so that I can build ARM Trusted Frimware (bl31.bin) from source? I need to modify ATF in order to run some code at EL3.
I have tried using https://github.com/ARM-software/arm-trusted-firmware but there is no instruction on how to build it for this particular board. Are there any specific build options?
- How do I use JTAG on RK3399? There seems to be no guide on this. Thanks.
Hi Tuan, did you ever figure this out in the end?
Rockchip seems to be maintaining a repo and it is quite active. Link is given below.
https://github.com/rockchip-linux/arm-trusted-firmware
I’m not fully aware between the differences between this and the one maintained by ARM. Just FYI, you can explore further.
Thanks,
San
Thank you for this amazing article, it left a profound impression on me. Free Latest Salesforce-Data-Cloud test voucher exam papers shared here. Best of luck in your exam!
Thank you for sharing this inspiring piece of writing! The DEA-C02 Study Test exam questions are free—take the first step towards career advancement and salary growth!
利用KaoGuTi BICSI的INST1-V8考試認證培訓資料來考試從來沒有過那麼容易,那麼快。這是某位獲得了認證的考生向我們說的心聲。有了KaoGuTi BICSI的INST1-V8考試認證培訓資料你可以理清你淩亂的思緒,讓你為考試而煩躁不安。這不僅僅可以減輕你的心裏壓力,也可以讓你輕鬆通過考試。我們KaoGuTi有免費提供部分試題及答案作為試用,如果只是我單方面的說,你可以不相信,只要你用一下試用版本,我相信絕對適合你,你也就相信我所說的了,有沒有效果,你自己知道。
This article is truly one worth keeping and referring to. Sharing the free Reliable study questions PostgreSQL-Essentials sheet resources with everyone. Good luck!
The content of this article is thought-provoking, thank you for sharing! Wishing you all success—free New Marketing-Cloud-Email-Specialist practice questions exam questions available now!
弊社は君のFCSS_NST_SE-7.4試験に合格させるとともにまた一年の無料の更新のサービスも提供し、もしFCSS_NST_SE-7.4試験に失敗したら全額で返金いたします。しかしその可能性はほとんどありません。弊社は100%合格率を保証し、購入前にネットでダウンロードしてください。
I’m all in on this content, hitting like right away. This Interactive NGFW-Engineer course helped me get a promotion and salary hike. I’m now making it available for free. Wishing you all career success!
