if using /dev/i2c -0/1/2 in application like below, how can create the node of i2c device (/dev/i2c) ?
need to add something in dts file (pinctrl.dtsi) or if dtsi file already defined the control of each pins,
only need to define the node in ueventd.rc located in device folder of android code, is it right ?
thankful for your kindness in advance,
ex)
// Net name I2C_1 Physical address : 0x12C70000
int fd = open(“/dev/i2c-4”, O_RDWR);
if (fd < 0) {
printf(“ERROR: open failed\n”);
return -1;
status = ioctl(fd, I2C_SLAVE, SI702X_ADDRESS);
if (status < 0) {
printf("ERROR: ioctl error\n");
close(fd);
return -1;
I can’t open the link, Could you please kindly check the link again ?
and if possible, please help to let me know the reason with detailed information or explanation,
I’m amazed by this article, thank you for sharing it. Free access to the Valid 1z0-1065-25 test topics questions—your path to promotion and salary increase!
