Is Dual MIPI-CSI Camera working on Ubuntu?
Hi,
Does anyone knows if dual MIPI-CSI camera works on Ubuntu? Has this been tested on Ubuntu?
Thanks,
San
Dual UVC is okay, but cannot Dual MIPI-CSI
How to test this?
Hi,
Could you please give us an update. I purchased RK3399 board only to test the dual MIPI-CSI input. I’ve also purchased two OV13850 camera modules for this puspose.
Could you please let me know what is missing? What is the effort required to get it working?
Thanks,
San
Aravinthkumar Posted at 10/27/2017 12:09
How to test this?
UVC stands for USB Video Class. Just connect two USB cameras and test it. This is straight forward. MIPI-CSI is comething critical.
The ubuntu doesn’t have MIPI-CSI and ISP driver. So MIPI RAW camera cannot work on it
清风莞尔 Posted at 11/4/2017 14:59
Hi 清风莞尔,
Thanks for the update.
Do you have any plans to port the MIPI-CSI and ISP drivers for Ubuntu?
I was able to use OV13850 camera module with Android. Does this mean that these drivers are integrated for Android and it is pending for Ubuntu?
Thanks,
San
santo4ul Posted at 11/5/2017 01:34
Hi 清风莞尔,
Yes, drivers in android are okay. But ubuntu is not yet. I’m trying to contact rockchip for mipi and isp driver support on ubuntu. If any news arrived, I will post it here.
Thanks 清风莞尔.
May be you are already aware, there is some development happening https://github.com/rockchip-linux/kernel/tree/isp-early-access on the ISP side.
Did you get a chance to try it out?
Thanks,
San
santo4ul Posted at 11/6/2017 14:42
Thanks 清风莞尔.
Hi,santo4ul.
I haven’t try it yet. There is no document about ISP driver. I don’t know how to get hand on it.
@Firefly Team
Could someone from the Firefly team provide some inputs on this?
Is there any plan for Firefly team to get dual mipi-csi camera working on the RK3399 Opensource board (with Ubuntu)?
I understand that Rockchip is working on it. It would be great if Firefly team works along with Rockchip team to get it working.
Thank you and looking forward.
Thanks,
San
Hello,
I am having the same problem. I wanted to use my OV13850 Camera on firefly rk3399 mipi interface in Ubuntu. But I could not find the support for it. The documentation and SDK driver is available only for Android.
Is the mipi and isp driver support for Ubuntu released yet? Or is there any plan to release it soon?
Thanks!
Hello,
Thanks!
Hi,
Thanks!
Half year passed, time flies quickly.
And another 2 months, and still nothing.
Not everyone is gearing towards using Android as the primary O/S for these devices. And this should be a simple driver to integrate.
A simple HOWTO to get the proper ARM drivers should really not be that difficult.
People actually want to use these devices, but if there is no support, and worse yet, a vary incomplete image. This makes it extremely hard to want to purchase products.
I got CSI module (http://en.t-firefly.com/doc/product/info/267.html) working on firefly-rk3399 using this kernel: https://github.com/FireflyTeam/kernel.git (branch firefly, rev 986a277676d350d020866ab9295a40003afb0fd3) and adding following snippet to rk3399-firefly-linux.dts:
&cif_isp0 {
    rockchip,camera-modules-attached = <&camera0>;
    status = "okay";
&isp0_mmu {
    status = "okay";
&i2c1 {
    status = "okay";
    camera0: camera-module@10 {
        status = "okay";
        compatible = "omnivision,ov13850-v4l2-i2c-subdev";
        reg = < 0x10 >;
        device_type = "v4l2-i2c-subdev";
        clocks = <&cru SCLK_CIF_OUT>;
        clock-names = "clk_cif_out";
        pinctrl-names = "rockchip,camera_default", "rockchip,camera_sleep";
        pinctrl-0 = <&cam0_default_pins>;
        pinctrl-1 = <&cam0_sleep_pins>;
        rockchip,pd-gpio = <&gpio2 12 GPIO_ACTIVE_LOW>;
        rockchip,pwr-gpio = <&gpio1 23 GPIO_ACTIVE_HIGH>;
        rockchip,pwr-snd-gpio = <&gpio1 22 GPIO_ACTIVE_HIGH>;
        rockchip,rst-gpio = <&gpio0 8 GPIO_ACTIVE_LOW>;
        rockchip,camera-module-mclk-name = "clk_cif_out";
        rockchip,camera-module-facing = "back";
        rockchip,camera-module-name = "cmk-cb0695-fv1";
        rockchip,camera-module-len-name = "lg9569a2";
        rockchip,camera-module-fov-h = "66.0";
        rockchip,camera-module-fov-v = "50.1";
        rockchip,camera-module-orientation = <0>;
        rockchip,camera-module-iq-flip = <0>;
        rockchip,camera-module-iq-mirror = <0>;
        rockchip,camera-module-flip = <1>;
        rockchip,camera-module-mirror = <0>;
        rockchip,camera-module-defrect0 = <2112 1568 0 0 2112 1568>;
        rockchip,camera-module-defrect1 = <4224 3136 0 0 4224 3136>;
        rockchip,camera-module-defrect3 = <3264 2448 0 0 3264 2448>;
        rockchip,camera-module-flash-support = <0>;
        rockchip,camera-module-mipi-dphy-index = <0>;
Captured video stream has a green tint (probably due to sensor not properly calibrated) but at least it works in general.
I got CSI module working on firefly-rk3399
it’s a good news!
See the news update at:
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=2490&extra=
Wenn Sie Ihre Position in der konkurrenzfähigen Gesellschaft durch die SAP C-OCM-2503 Zertifizierungsprüfung festigen und Ihre fachliche Fähigkeiten verbessern wollen, müssen Sie gute Fachkenntnisse besitzen und sich viel Mühe für die Prüfung geben. Aber es ist nicht so einfach, die SAP C-OCM-2503 Zertifizierungsprüfung zu bestehen. Vielleicht durch die SAP C-OCM-2503 Zertifizierungsprüfung können Sie Ihnen der IT-Branche vorstellen. Aber man braucht nicht unbedingt viel Zeit und Energie, die Fachkenntnisse kennenzulernen. Sie können die Schulungsunterlagen zur SAP C-OCM-2503 Zertifizierungsprüfung von DeutschPrüfung wählen. Sie werden zielgerichtet nach den IT-Zertifizierungsprüfungen entwickelt. Mit ihr können Sie mühelos die schwierige SAP C-OCM-2503 Zertifizierungsprüfung bestehen.
