Flash image download link is broken
Hi,
The below given link which is referred from the “Flash_image” page is broken. Could someone help?
http://en.t-firefly.com/en/firenow/Firefly_RK3399/download/
Thanks,
San
I got the link of the google drive https://drive.google.com/drive/folders/0B7HO8lbGgAqASHJLWW1xbkhyWms
Thanks,
San
http://en.t-firefly.com/doc/product/info/id/263.html
After wasting 3 hours am still in the same place.
The update tool does not work. :frowning: .. Really this is waste of time.
  1. Link - https://drive.google.com/drive/folders/0B7HO8lbGgAqAc0dPSWdGSnZIejA
    On ubuntu it .. here is exact command line.
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ ls
config.ini Linux┐к╖в╣д╛▀╩╣╙├╩╓▓с_v1.0.pdf upgrade_tool
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ chmod 755 upgrade_tool
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ sudo ./upgrade_tool
sudo: unable to execute ./upgrade_tool: No such file or directory
Hangup
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ ./upgrade_tool
bash: ./upgrade_tool: No such file or directory
Even i try to put in /usr/local/bin - still similar issue
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ sudo cp upgrade_tool /usr/local/bin
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ sudo chown root:root /usr/local/bin/upgrade_tool
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ sudo upgrade_tool
sudo: unable to execute /usr/local/bin/upgrade_tool: No such file or directory
Hangup
When i looked online - this happens when an application is not working well… Linux is also a bad os, that it does not give right messages.. :frowning:
Anyways, do you have ideas.. or am i going to waste more time.??
Hej there,
Is it possible to share the new xubuntu.img from baidu to googledrive?
https://pan.baidu.com/s/1hsOCOJU#list/path=%2FPublic%2FDevBoard%2FFirefly-RK3399%2FFirmware%2FUbuntu%2FUbuntu16.04%2FFirefly-rk3399_xubuntu1604_201711021305&parentPath=%2FPublic%2FDevBoard%2FFirefly-RK3399%2FFirmware%2FUbuntu
i can′t understood this and direkt download isn′t supported
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=2050&highlight=upgrade%2Btool
Tholo Posted at 11/19/2017 22:14
Hej there,
uploading google driver.
Hej there,
https://drive.google.com/open?id=1XvYHIQAK6GAGl9x9_9Owzy15thfvOfSu Firefly-RK3399-xubuntu
Thx! That will work better like the last version!
By reading this article, I’ve developed a new understanding of both my work and life. Free access to Online C_FIORD_2502 Tests materials—your key to climbing the career ladder and boosting your salary!
ISTQB-CTFL証明書を所有して、自分が有能であることを証明し、特定の分野で優れた実用的な能力を高めることができます。したがって、CertJukenあなたは有能な人々とみなされ、尊敬されます。テストISTQB-CTFL認定に合格すると、目標を実現するのに役立ちます。また、ISTQB-CTFLガイドトレントを購入すると、ISTQB-CTFL試験に簡単に合格できます。 ISTQB-CTFL試験問題は最も専門的な専門家によって書かれているため、ISTQB-CTFL学習教材の品質は素晴らしいです。そして、試験に合格するために、ISTQB Certified Tester Foundation Level (CTFL v4.0)学習ガイドを常に最新の状態に保ちます。
CertShikenのサイトは長い歴史を持っていて、HPのHPE2-E84認定試験の学習教材を提供するサイトです。長年の努力を通じて、CertShikenのHPのHPE2-E84認定試験の合格率が100パーセントになっていました。HPのHPE2-E84試験トレーニング資料の高い正確率を保証するために、うちはHPのHPE2-E84問題集を絶えずに更新しています。それに、うちの学習教材を購入したら、私たちは一年間で無料更新サービスを提供することができます。
Thank you for sharing such an impactful article, it deeply impressed me. Improve your IT skills—free Latest CMMC-CCA test camp free is shared! Best of luck with everything!
This is so good, I’m liking it without a doubt. Here’s the GH-300 certification exam infor test I passed to earn my promotion and salary increase. It’s free for you today—best of luck in your career goals!
