Hi,
I followed instructions from http://wiki.t-firefly.com/index. … 399/Serial_debug/en to setup my USB to UART module. I can see the board booting (with all kernel logs) on my minicom. However, my keyboard input is not being accepted. I’m not able to login using keyboard from minicom.
I’ve made sure that Hardware Flow Control is ‘NO’.
What am I missing? Could someone help.
Thanks,
San
It started working after I swapped the GNG and RXD Pins.
Looks like the connection shown in
http://wiki.t-firefly.com/index. … 399/Serial_debug/en is wrong.
On the USB-to-UART board, the left most pin is GND, Middle is TXD and the right most is RXD. The diagram in the above link has GND and RXD swapped, which is wrong.
Thanks,
San
The article was a real source of inspiration. This Dumps AZ-801 PDF helped me achieve a promotion and salary increase. Now it’s free for everyone. Wishing you all a smooth path to promotion!
Your article was a true eye-opener, thank you for sharing it. Sharpen your IT expertise with free Analytics-Con-201 test simulator fee. Wishing you success!
