So it’s been a while since I worked on my rk3288 (it got crushed accidentally). I compiled the kernel from source like I always use to on 4.4 when I made my overclocking kernel that I posted a how to on my old forum account I can’t access anymore.
Anyway the issue is when I flash the kernel.img the kernel doesn’t change, tried every combo of kernel+boot+parameter+etc. That I could think of to get it to work but nothing. No matter what I do I can’t flash the kernel even though it says successful nothing changes. It’s always the same default kernel regardless of what IMG i flash
I’d like to add that I’m using the flashtool from the mini rk3288 board as the links in the original rk3288 wiki are broken and don’t go anywhere. Is this a flash tool issue? What is going on with the Android 5.1 source? Did the location for the kernel change?
Any help is appreciated as I’m out of the loop on things and following how I use to do it and how the wiki says to don’t work (and wiki isn’t up to date it seems)
My kernel and boot.img are separate, so you’re saying I need to pack the kernel into the boot.img now? Didn’t have to do that before but if that’s the case easy enough
It use to be just flash resource+kernel.img
In my spare time, I like to play the thrilling and captivating online snowboarding game snow rider. Players embark on an exhilarating journey down snow-capped slopes that is full of surprises, leaps, and obstacles.
It sounds like the flash tool might not be writing the new kernel to the correct location or partition. A few things to check:
Make sure your parameter file matches the current partition layout and points to the correct kernel partition.
Try unpacking the boot.img using tools like rk-unpack or Android Image Kitchen to verify what’s inside.
Are you flashing in MASKROM mode or Loader mode? Some tools behave differently depending on mode.
If you built your kernel correctly but it’s not changing, maybe the bootloader is ignoring the new kernel due to signature checks or config mismatch.
Let me know what your parameter file looks like - happy to take a look, steal a brainrot
Wünschen Sie nicht großen Erfolg in Ihrem Arbeitsleben machen? Wenn ja, sollen Sie jetzt sich verbessern. Und wie kann Ihre selbe Fähigkeit in IT-Industrie sich verbessern? Es ist eine gute Weise, die TPCB PTOE Zertifizierungsprüfung abzulegen. Die TPCB Zeritizierungsprüfung ist eine sehr wichtige Zertifizierung, deshalb gibt es immer mehr TPCB Prüfungskandidaten.
I feel like I’ve gained a whole new perspective. The Sample Workday-Pro-HCM-Reporting Questions exam questions are free for everyone—unlock career growth and salary increases!
I was amazed by the insights in that article. The MB-500 latest test cram sheet file helped me secure a promotion and raise. Now, I’m giving it away for free. May your career paths be filled with success!
I’m in awe of this article, thank you for sharing it. I’m offering the Latest CPHQ test online test that played a key role in my promotion and salary increase. It’s available for free today—good luck with your career journey!
