AIO-3399J latest Android 7.1 ROM with LVDS ?
I need to use the LVDS connection on the AIO-3399J with Android 7.1
I cannot find the ROM pre-built. The “download” tab for this specific board is empty : http://en.t-firefly.com/doc/download/index/id/31.html
This page http://en.t-firefly.com/doc/product/info/id/437.html mentions “You can download firmwares on compiled update.img” but the link goes nowhere.
Where can I find AIO-3399J Android 7.1 ROM with LVDS support ?
Regards
Tim
they have no lvds modules to sell temporary, but you can take a sample rk3399-firefly-aio-lvds.dts for debug
  1. I am looking for pre-built Android 7.1 ROM with LVDS support enabled. I cannot find this ROM / img file(s).
  2. As I cannot find a pre-built ROM I have just custom built a ROM and tried to enable LVDS using:
    $ make -j72 -d KERNEL_DTS=rk3399-firefly-aio-lvds
    and flashed the AIO-3399J board with the new system.img
I have connected my LVDS display controller to the LVDS connector on the board. I have also connected the LVDS power. I have set the LCD_VCC to 12v using jumper pin.
I disconnect HDMI display, reboot the board with only LVDS connected but the display is off.
How do I get LVDS to work on the board in terms of ROM/software and hardware connection ?
I think you are referring me to the file kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-aio-lvds.dts but I don’t know what to do next !
Regards
Tim
ducksoft Posted at 1/11/2018 10:01
  1. I am looking for pre-built Android 7.1 ROM with LVDS support enabled. I cannot find this ROM / i …
  1. make sure your LVDS connector data io is suitable for the board connector .
  2. LVDS need backlight power, which voltage your LVDS needed , just short the power silk-screen ‘LCD_VCC’ on the board . These are 3.3v/5v/12v.
  1. Yes I have confirmed the LVDS pin connector between the AOI-3399J board and the display controller using the documentation.
  2. Yes I have set theLCD_VCC pins (see above “I have set the LCD_VCC to 12v using jumper pin.”) and also tried 3.3V and 5V just incase :slight_smile:
I think I need to set the display panel characteristics in some .dts file but I’m not sure if I need to just update the rk3399-firefly-aio-lvds.dts file directly or if I need to copy this file to a new file and update the new file?
ducksoft Posted at 1/11/2018 18:11
  1. Yes I have confirmed the LVDS pin connector between the AOI-3399J board and the display controlle …
1."make ARCH=arm64 rk3399-firefly-aio-lvds.img -j8 " for making kernel.img and resource.img
flash them just fine .
2. After that, backlight is the first stuff to make sure.
3. Follow your LVDS datasheet to comfirm the timing .
Hi,
I try to get LVDS work on AIO-3399J board (Ubuntu) , but i cant find rk3399-firefly-aio-lvds.dts file anywhere? Is the LVDS support some other dts file?
BR,
Pekka
I’m so grateful I read that article. Boost your IT knowledge with free D-MSS-DS-23 reliable exam bootcamp. Wishing you all the best!
I appreciate your article, it was truly enlightening. Good luck! Here are the Practice 212-82 exams free materials shared for free.
G’day, I was determined to save enough for a new watch and told myself every bit counts. Still, after a long workday, I decided to try something a colleague mentioned. The session started badly with a string of losses, but I stayed calm, took one bigger chance, and finally hit a strong win. That moment happened on chicken road game and felt incredibly satisfying. With the extra perks available for Pakistan users, it’s something I now casually recommend when friends ask.
Your article truly stood out to me, thank you for sharing it. I’m sharing the Latest AP-215 material test that helped me achieve a promotion and raise. It’s free for you today—best of luck in reaching your career goals!
