Firefly-RK3399 won't boot without Type-C cable connected
Hello:
I have loaded two different Linux releases to the Emmc and the unit works fine IF the usb Type-C cable is connected.
If I remove the Type C cable from the Firefly the unit will not boot. The hdmi monitor does not display anything and the serial monitor is flooded with invalid characters mixed in with some readable info.
This seems to have something to do with receiving power over the type-c usb port. If I plug the type-c cable in to the PC while the PC is Off the firefly still boots so I assume it needs to sense power at the port in order to boot correctly.
Is there some setting I am missing? Or is there a jumper on the board?
Thanks in advance!
Nevermind — looks like it needs the Type-c cable connected if the debug serial monitor is connected.
If both are disconnected it works fine…
Your article is truly inspiring, I’m so grateful for your sharing! Good luck on your exams! Free C_FIORD_2502 vce torrent exam papers are now available.
The content of the article is very insightful, and I’ve benefited a lot. The Latest GCIH associate level exam helped me achieve a promotion and salary increase. Now, it’s free for everyone. Best wishes for your professional success!
購買最新的C-BCSPM-2502考古題,您將擁有100%成功通過C-BCSPM-2502考試的機會,我們產品的品質是非常好的,而且更新的速度也是最快的。題庫所有的問題和答案都與真實的考試相關,我們的SAP C-BCSPM-2502軟件版本的題庫可以讓您體驗真實的考試環境,支持多臺電腦安裝使用。C-BCSPM-2502題庫學習資料將會是您通過此次考試的最好保證,還在猶豫什么,請盡早擁有SAP C-BCSPM-2502考古題吧!
I’m deeply thankful for your article, it really stood out to me. The Practice test C_THR86_2505 pdf questions helped me secure a raise and promotion, and today, I’m sharing them for free!
Your article is breathtakingly good, thank you for sharing it! Get free Exam AZ-305 outline to level up your IT knowledge. Wishing you success!
Thank you for sharing such a powerful article! Examcode materials are free for everyone—good luck! New CISSP test fee
