Issues with HDMI display resolution
Hello,
I have an RK-3288 and I’m running into issues getting the correct display resolution over HDMI. It looks like i’m maybe getting 720 or lower, which is then upscaled in my monitor and looks horrible.
If I instead plug in VGA cable it looks good though.
I’ve tried forcing the HDMI to 1080p but I’m having issues. It looks like xrandr does not properly detect the HDMI port:
sudo xrandr --newmode “1920x1080_60.00” 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
xrandr: Failed to get size of gamma for output default
sudo xrandr --addmode HDMI-0 1920x1080_60.60
xrandr: cannot find output “HDMI-0”
sudo xrandr --query
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
1920x1080 60.0*
1920x1080_60.00 (0x6c) 173.0MHz
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.2KHz
v: height 1080 start 1083 end 1088 total 1120 clock 60.0Hz
I’m using the built in Ubuntu version which was delivered with the device. I’ve run “apt-get update/upgrade” to download patches.
Additional commands that I’ve tried:
firefly@firefly:~$ sudo lspci
pcilib: Cannot open /proc/bus/pci
lspci: Cannot find any working access method.
firefly@firefly:~$ sudo lshw -C display
firefly@firefly:~$ cat /etc/X11/xorg.conf.d/*
Section “InputClass”
Identifier “gslX680 evdev touchscreen”
MatchProduct “gslX680”
MatchDevicePath “/dev/input/event*”
Option “EmulateThirdButton” “true”
Option “EmulateThirdButtonTimeout” “500”
Option “EmulateThirdButtonMoveThreshold” “50”
Driver “evdev”
EndSection
Identifier “evdev gsl680”
#MatchIsTouchscreen “on”
MatchProduct “gsl680”
Driver “evdev”
EndSection
Thanks for your help
Boost your financial management expertise with comprehensive study resources designed for real exam success. Each question is paired with a clear, detailed answer to enhance your understanding of financial planning and analysis. Practicing CMA-Financial-Planning-Performance-and-Analytics Questions and Answers ensures you grasp every concept and perform confidently in the actual test. For accurate, expert-verified materials and guaranteed success, trust CertsDone — your reliable partner for CMA certification preparation.
You may improve your knowledge of financial management by using comprehensive study tools that are designed to help you succeed on real exams. The purpose of this exercise is to improve retro bowl 26 your grasp of financial planning and analysis by providing you with a clear and complete solution to each question.
Huawei인증 H11-861_V4.0시험을 어떻게 공부하면 패스할수 있을지 고민중이시면 근심걱정 버리시고ITDumpsKR 의 Huawei인증 H11-861_V4.0덤프로 가보세요. 문항수가 적고 적중율이 높은 세련된Huawei인증 H11-861_V4.0시험준비 공부자료는ITDumpsKR제품이 최고입니다.
D-PWF-OE-00試験に問題なく迅速に合格する方法 答えは、有効で優れたD-PWF-OE-00トレーニングガイドにあります。 既にD-PWF-OE-00トレーニング資料を用意しています。 これらは、保証対象のプロのD-PWF-OE-00実践資料です。 参考のために許容できる価格に加えて、3つのバージョンのすべてのD-PWF-OE-00試験資料は、10年以上にわたってこの分野の専門家によって編集されています。
