UART drivers for rk3399
Does nougat source code provide UART drivers?
Because I have tried to search in nougat source code(See link: https://gitlab.com/TeeFirefly/FireNow-Nougat/tree/firefly-rk3399) but I did not find anything related UART.
And how we can fetch data from uart4 port without using any USB-serial converter?
it depend on what device u want to connect,
because uart conversation need the same voltage or property transfer module.
serial driver dir “kernel/drivers/serial”
leung先森 Posted at 2/10/2018 10:44
because uart conversation need the same voltage or pro …
Right, But I am not able to find the ‘serial’ folder under drivers.(I am looking into this source code: https://gitlab.com/TeeFirefly/FireNow-Nougat/tree/firefly-rk3399/kernel/drivers)
I am trying to interface GPS module with rk3399 via UART but I am not using any USB-UART adaptor in between. So, I am connecting usart4(Rx,Tx) pins directly to the GPS module.But, I don’t know how to see the data transmitted by the GPS module in firefly rk3399.Is there any way to see the data in firefly rk3399?And if we need to make any changes in kernel file than what they should be?
In short How we can interface this GPS module(LInk: ) with firefly rk3399?
Saylor인증 BUS105시험이 너무 어려워 보여서 오르지못할 산처럼 보이시나요? 그건DumpTOP의 Saylor인증 BUS105시험문제에 대비하여 제작한Saylor인증 BUS105덤프가 있다는 것을 모르고 있기때문입니다. Saylor인증 BUS105시험에 도전하고 싶으시다면 최강 시험패스율로 유명한DumpTOP의 Saylor인증 BUS105덤프로 시험공부를 해보세요.시간절약은 물론이고 가격도 착해서 간단한 시험패스에 딱 좋은 선택입니다.
This article really made an impact, thank you for sharing! Enhance your IT knowledge—free Test 1z0-1054-25 passing score shared! Wishing you success!
I’m stunned by your article, thank you for this incredible share! Cost-effective C1000-196 certification offers rich material, available for free to support your learning goals.
I really appreciate this inspiring article, thank you for sharing! Here’s the free C_C4H56_2411 exam online material! Wishing everyone good luck on their exams!
