[RK3288-Reload] How to handle interrupt using GPIO?
Hi, I’m using RK3288-reload with linux.
Using RK3288 as master board, I connected SPI pins(MOSI, MISO, CLK, CS) to slave board.
Slave board has nIRQ pin and the pin goes low (normal high) every 1second.
I wanted to use this pin as a interrupt, so I connected GPIO5_C2 pin at the RK3288-reload.
I set “/sys/class/gpio/gpio178/direction” to “in” and checked value.
The value works fine (LOW signal → value is 0 / HIGH signal → value is 1).
But I don’t know how to control with this GPIO pin as a interrupt.
Can you give me some information how to handle interrupt in RK3288-reload?
http://en.t-firefly.com/doc/product/info/id/242.html
wiki may can help you
The article was full of valuable insights. I used the DOP-C02 Exam Simulations to get promoted and earn more. Now, it’s available for free. Best of luck with your career!
Clicking like instantly—this is fantastic. Heading into the New QSSA2021 braindumps free exam soon. Pray for me!
The perspectives presented in the article are unique, and I’ve gained a lot from them. Wish me all the best as I face the Valid test PSE-Cortex-Pro-24 tips exam soon!
