1080p@60Hz video on android 5.1
Hi,
I want to play different types of video files on my Fireprime. To do so, I use Android 5.1 compiled from the sources (I have followed the instructions here => http://en.t-firefly.com/doc/product/info/id/301.html) and a custom apk written with Android Studio.
Using MediaPlayer object, I am able to play 1080p@30Hz videos encoded with h264 or h265 but when I want to play a 60fps file, the video stream does not play at full rate resulting in a loss of sync between audio and video. However, the MediaPlayer does not raise the flag “MEDIA_INFO_VIDEO_TRACK_LAGGING” or any other warning message.
So my questions are : Can I play FullHD files@60fps on this board ? And if so, how ?
have you the video app of the system? the same ?
Yes, the behavior with the pre-installed video player app is exactly the same.
I don’t know if there is a link with my issue discribed above, but I noticed that no matter the screen connected to the HDMI, the resolution of the output video stream is always 720p.
$ adb shell wm size
returns
Physical size: 1280x720
Also, on a 1080p screen, when I set /sys/class/display/HDMI/mode to “auto” it results in a small window in the upper left corner and a green background.
Is there a reason why the video is downscaled ? How can I have it to fit the display with correct resolution (based on EDID) ?
kiwor Posted at 3/21/2018 22:44
I don’t know if there is a link with my issue discribed above, but I noticed that no matter the scre …
Now cannot good support it .
they will update the sdk later and test it, just wait patiently.
I appreciate your article, it was truly enlightening. The Reliable 1z0-1073-25 test topics content is impressive, and it’s available to you at no cost.
I appreciate your article; it was truly eye-catching and unique. Here’s the New PSE-Strata-Pro-24 exam passing score test I took to earn my promotion and raise, now free for you today. Best of luck in your professional journey!
I’m thankful for this inspiring article, it’s truly motivational! New C1000-182 study plan exam materials are the secret to promotion and salary increases—available for free!
What an extraordinary article, I’m so appreciative of your sharing. This New CDFOM test guide files helped me advance in my career and get a raise. Now it’s available for free. Wishing you all the best in your professional journeys!
This is a wonderfully inspiring article, thank you for sharing! The content in KCSA Training online is detailed and free, designed to aid in your studies.
