Hi,
the RK3399 has an USB-C/DP port.
Android reports max. resolution of 1920 x 1200 @ 60 Hz.
How to enable UHD/4K 3849 x 2160 @ 60Hz via DisplayPort on RK3399?
Thanks
fl0wtec
Hi,
Thanks
fl0wtec
Have you try Android7.1.2 ?
Hi,
can you please post a link where I can get Androi 7.1.2 Firmware image for RK3399?
Google drive only lists 7.1.1:
Thanks
fl0wtec
fl0wtec Posted at 3/24/2018 02:17
Hi,
leung先森 Posted at 3/24/2018 09:09
http://en.t-firefly.com/doc/download/index/id/3.html
Hi,
with Firefly-RK3399_Android7.1.2_MP_180126 image it gets even worse.
Nothing to choose from anymore:
Auto defaults to 1920 x 1080 @60Hz:
Can you please enable DP output with 3840 x 2160@60Hz?
Thanks
BR
fl0wtec
fl0wtec Posted at 3/24/2018 16:40
Hi,with Firefly-RK3399_Android7.1.2_MP_180126 image it gets even worse.
need to modify dts file and complie your kernel and resource.
make the DP connector support vopb.
patch below
&hdmi_in_vopb {
status = “okay”;
&hdmi_in_vopl {
status = “disabled”;
&dp_in_vopb {
status = “okay”;
&dp_in_vopl {
status = “okay”;
leung先森 Posted at 3/26/2018 09:18
make the DP connector support vopb …
not work
Dear leung先森,
can you please be more specific and tell us which .dts file exactly needs to be modified?
Can you please provide an image where DP output is enabled with 3840 x 2160@60Hz?
Thanks!
BR
fl0wtec
fl0wtec Posted at 3/31/2018 00:56
Dear leung先森,can you please be more specific and tell us which .dts file exactly needs to be m …
kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly.dts
complie it and flash resource.img and kernel.img
Dear all,
additional info below (edit 2018-04-04)
I too try to get a DisplayPort 4K monitor (AOC U2879VF) working, however no success yet.
I have modified the DTS-file accordingly, and I see a couple of things:
‘dumpsys SurfaceFlinger’ shows 2 displays: “Built-in screen” and “HDMI screen”. The latter is the the DisplayPort 4K monitor. The naming is hardcoded in the Android source, and reading the EDID shows it is the correct monitor (and I have no display connected via HDMI). Only one monitor via HDMI shows only “Built-in screen”. I don’t think this is an issue, as Android tries to clone to each video output.
I guess the VOP_LITTLE seems to be selected for DisplayPort output (and not the VOP_BIG), as the current mode is 2560x1440@60p and the modes list does not contain above this (also not 3840x2160p60), while the monitor is capable.
$cat /sys/devices/platform/display-subsystem/drm/card0/card0-DP-1/modes
2560x1440p60
1920x1080p60
1920x1080p60
1920x1080p60
[ 13.220928] fusb302 4-0022: attention, dp_status a
[ 13.227559] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected without sink. Assert hpd
[ 13.287002] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected, not enabled. Enabling cdn
[ 14.239036] fusb302 4-0022: attention, dp_status 8a
[ 14.241816] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link
[ 57.438951] fusb302 4-0022: attention, dp_status 18a
[ 57.444952] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link
[ 69.396299] fusb302 4-0022: attention, dp_status 18a
[ 69.402256] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link
[ 71.460755] fusb302 4-0022: attention, dp_status 18a
[ 71.467507] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link
[ 72.984966] fusb302 4-0022: attention, dp_status 18a
[ 72.992195] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link
[ 96.583813] fusb302 4-0022: attention, dp_status a
[ 96.591843] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link
[ 97.572369] fusb302 4-0022: attention, dp_status 8a
[ 97.579922] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link
[ 138.177425] fusb302 4-0022: attention, dp_status 18a
[ 138.185544] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link
Resulting in some questions:
additional info: I see a difference between boards, as I have boards with different production dates/stickers
Thanks in advance,
With kind regards, Mark
Dear Team-Firefly,
we still need the 4k@60Hz DP output.
Can you please provide a firmware image which makes the board work as advertised?
Thanks!
BR
fl0wtec
iltis-wiesel Posted at 4/27/2018 15:09
Dear Team-Firefly,
modif code like #6 said .
If cannot up to the 4K but better than 1080p, it might be speed limited by cable.
Hi fl0wtec,
Did you ever manage to resolve the USBC(DP) VGA screen resolution list issue?
Alle wünschen sich Erfolg. Die im IT-Bereich arbeitende Leute wissen sicherlich die Wichtigkeit der Zertifizierung der Palo Alto Networks XSIAM-Analyst für die Karriere. Immer mehr Leute nehmen an der Palo Alto Networks XSIAM-Analyst Prüfung teil. Wie kann man beim immer schweren Wettbewerb noch siegen? Den richtigen Hilfspartner auszuwählen ist am wichtigsten. PrüfungFrage hat die Palo Alto Networks XSIAM-Analyst Prüfung schon mehrere Jahre geforscht. Wir haben gute Kenntnisse in dieser Prüfung. Mit Hilfe der Palo Alto Networks XSIAM-Analyst Prüfungssoftware von uns wird Ihr Sieg bei der Prüfung gesichert.
What a powerful piece, thank you for sharing this inspiring article! Here are the Valid CIS-PA exam question materials, free of charge—best of luck!
Cyber ABのCMMC-CCP認定試験に合格することはきっと君の職業生涯の輝い将来に大変役に立ちます。Xhs1991を選ぶなら、君がCyber ABのCMMC-CCP認定試験に合格するということできっと喜んでいます。Xhs1991のCyber ABのCMMC-CCP問題集を購入するなら、君がCyber ABのCMMC-CCP認定試験に合格する率は100パーセントです。あなたはXhs1991の学習教材を購入した後、私たちは一年間で無料更新サービスを提供することができます。
Thank you for your article, it really opened my eyes! The Reliable MS-900 source exam questions are now available for free. Good luck to everyone!
This article gave me a new perspective, thank you for sharing! Level up your IT skills with free 72201T latest test study guide. Best of luck with everything!
