Hi
I install android in rk3399
But it is failed to boot and displayed only “Erasing” on screen.(Image file is “.Firefly-RK3399_Android7.1.2_MP_180126.img”.)
What is wrong? How can I fix it?
Thanks.
LOG-----------------------------------------------------------------------------------
DDR Version 1.08 20170320
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1835
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 65848
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x77d6c
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):9f93abc
NOTICE: BL31: Built : 10:18:20, Jul 27 2017
INFO: plat_rockchip_pmu_init(1089): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-96-g3fbe315-dev #4 Fri Jun 30 00:35:17 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.1
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Jan 26 2018 - 10:04:18)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2018-01-26#1.09
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can’t find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=5
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 4 color_output 3 color_output_depth 8
pixel clk is 74250000 tmds clk is 74250000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
rockchip_panel_enable: failed to find panel prepare funcs
failed to display kernel logo
checkKey
vbus = 0
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x01325008)
ramdisk @ 0x05bf0000 (0x007b1abc)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005615f13 … OK
Add bank:0000000009400000, 0000000076c00000
[ 0.000000] Linux version 4.4.83 (omy@tchipserver2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #47 SMP PREEMPT Fri Jan 26 09:22:49 CST 2018
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eefc000 s45696 r8192 d32128 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 511496
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-01-26_10:04:18 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7eeb3000-0x7eef3000] (0MB) mapped at [ffffffc07eeb3000-ffffffc07eef2fff]
[ 0.000000] Memory: 1995920K/2078720K available (11838K kernel code, 1428K rwdata, 5440K rodata, 832K init, 1116K bss, 66416K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009170000 - 0xffffff8009240000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c10000 ( 11840 KB)
[ 0.000000] .rodata : 0xffffff8008c10000 - 0xffffff8009170000 ( 5504 KB)
[ 0.000000] .data : 0xffffff8009240000 - 0xffffff80093a5008 ( 1429 KB)
[ 0.000000] ITS: allocated 65536 Devices @7c400000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007c480000
[ 0.000000] CPU0: using LPI pending table @0x000000007c490000
[ 0.001848] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002813] pid_max: default: 32768 minimum: 301
[ 0.003310] Security Framework initialized
[ 0.003698] SELinux: Initializing.
[ 0.004131] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004759] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006199] Initializing cgroup subsys freezer
[ 0.006627] Initializing cgroup subsys debug
[ 0.007905] sched-energy: Sched-energy-costs installed from DT
[ 0.008454] CPU0: update cpu_capacity 401
[ 0.008906] ASID allocator initialised with 65536 entries
[ 0.025731] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.026963] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039126] Detected VIPT I-cache on CPU1
[ 0.039156] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039191] CPU1: using LPI pending table @0x000000007c5f0000
[ 0.039234] CPU1: update cpu_capacity 401
[ 0.039237] CPU1: Booted secondary processor [410fd034]
[ 0.049116] Detected VIPT I-cache on CPU2
[ 0.049135] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049167] CPU2: using LPI pending table @0x000000007c620000
[ 0.049195] CPU2: update cpu_capacity 401
[ 0.049198] CPU2: Booted secondary processor [410fd034]
[ 0.059154] Detected VIPT I-cache on CPU3
[ 0.059172] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059205] CPU3: using LPI pending table @0x000000007c660000
[ 0.059231] CPU3: update cpu_capacity 401
[ 0.059235] CPU3: Booted secondary processor [410fd034]
[ 0.069194] Detected PIPT I-cache on CPU4
[ 0.069223] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069263] CPU4: using LPI pending table @0x000000007c6a0000
[ 0.069304] CPU4: update cpu_capacity 1024
[ 0.069307] CPU4: Booted secondary processor [410fd082]
[ 0.079221] Detected PIPT I-cache on CPU5
[ 0.079239] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079275] CPU5: using LPI pending table @0x000000007c6d0000
[ 0.079302] CPU5: update cpu_capacity 1024
[ 0.079305] CPU5: Booted secondary processor [410fd082]
[ 0.079387] Brought up 6 CPUs
[ 0.091486] SMP: Total of 6 processors activated.
[ 0.091928] CPU features: detected feature: GIC system register CPU interface
[ 0.092598] CPU: All CPU(s) started at EL2
[ 0.093019] alternatives: patching kernel code
[ 0.095120] devtmpfs: initialized
[ 0.115312] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116286] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117963] pinctrl core: initialized pinctrl subsystem
[ 0.121100] Failed to find legacy iommu devices
[ 0.122037] NET: Registered protocol family 16
[ 0.123162] schedtune: init normalization constants…
[ 0.123648] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.124260] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.124884] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.125494] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.126105] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.126715] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.127326] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.127937] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.128555] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.129165] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.129879] schedtune: verify normalization constants…
[ 0.130376] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.130897] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.131417] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.131944] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.132465] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.133038] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.133579] schedtune: configured to support 5 boost groups
[ 0.143000] cpuidle: using governor ladder
[ 0.155349] cpuidle: using governor menu
[ 0.155737] Registered FIQ tty driver
[ 0.156742] vdso: 2 pages (1 code @ ffffff8008c16000, 1 data @ ffffff8009244000)
[ 0.157457] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.158927] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.183950] console [pstore0] enabled
[ 0.184562] pstore: Registered ramoops as persistent store backend
[ 0.185145] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.188117] sip_fiq_debugger_uart_irq_tf_init error: -2
[ 0.188631] fiq debugger bind fiq to trustzone failed: -2
[ 0.189595] console [ttyFIQ0] enabled
[[ 0.189595] console [ttyFIQ0] enabled
[ 0.190097] bootconsole [uart0] disabled
[ 0.191350] Registered fiq debugger ttyFIQ0
[ 0.230545] Rockchip hdmi driver version 2.0
[ 0.232672] iommu: Adding device ff650000.vpu_service to group 0
[ 0.232750] iommu: Adding device ff660000.rkvdec to group 1
[ 0.232815] iommu: Adding device ff670000.iep to group 2
[ 0.232909] iommu: Adding device ff8f0000.vop to group 3
[ 0.232989] iommu: Adding device ff900000.vop to group 4
[ 0.233108] iommu: Adding device ff910000.isp to group 5
[ 0.233187] iommu: Adding device ff920000.isp to group 6
[ 0.233856] rk_iommu ff670800.iommu: can’t get aclk
[ 0.233875] rk_iommu ff670800.iommu: can’t get hclk
[ 0.234717] SCSI subsystem initialized
[ 0.235061] usbcore: registered new interface driver usbfs
[ 0.235107] usbcore: registered new interface driver hub
[ 0.235184] usbcore: registered new device driver usb
[ 0.235520] media: Linux media interface: v0.10
[ 0.235563] Linux video capture interface: v2.00
[ 0.235696] pps_core: LinuxPPS API ver. 1 registered
[ 0.235707] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.235735] PTP clock support registered
[ 0.237101] Advanced Linux Sound Architecture Driver Initialized.
[ 0.237552] Bluetooth: Core ver 2.21
[ 0.237583] NET: Registered protocol family 31
[ 0.237594] Bluetooth: HCI device and connection manager initialized
[ 0.237610] Bluetooth: HCI socket layer initialized
[ 0.237625] Bluetooth: L2CAP socket layer initialized
[ 0.237653] Bluetooth: SCO socket layer initialized
[ 0.238615] rockchip-cpuinfo cpuinfo: Serial : 09bc1d33fe6eaafe
[ 0.239131] clocksource: Switched to clocksource arch_sys_counter
[ 0.278487] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.278722] NET: Registered protocol family 2
[ 0.279168] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.279269] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.279391] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.279473] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.279502] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.279660] NET: Registered protocol family 1
[ 0.280128] Trying to unpack rootfs image as initramfs…
[ 0.615655] Freeing initrd memory: 7876K
[ 0.616259] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.616351] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.618836] audit: initializing netlink subsys (disabled)
[ 0.618899] audit: type=2000 audit(0.613:1): initialized
[ 0.624022] VFS: Disk quotas dquot_6.6.0
[ 0.624145] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.625492] fuse init (API version 7.23)
[ 0.626546]
[ 0.626546] TEE Core Framework initialization (ver 1:0.1)
[ 0.626577] TEE armv7 Driver initialization
[ 0.626914] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.626930] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.627106] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.631856] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.631886] io scheduler noop registered
[ 0.632054] io scheduler cfq registered (default)
[ 0.633354] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.637783] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.637816] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.637835] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.159178] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.159346] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.160855] iep: failed to find iep power down clock source.
[ 1.162573] IEP Power ON
[ 1.162813] IEP Power OFF
[ 1.162917] IEP Driver loaded succesfully
[ 1.163161] Module initialized.
[ 1.163744] rk-vcodec ff650000.vpu_service: probe device
[ 1.163800] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07bc5dc10
[ 1.163976] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.164032] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.164466] rk-vcodec ff650000.vpu_service: init success
[ 1.165002] rk-vcodec ff660000.rkvdec: probe device
[ 1.165044] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07bc5e410
[ 1.165182] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.165236] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.165538] rk-vcodec ff660000.rkvdec: init success
[ 1.166972] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.166992] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.168368] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.168385] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
6▒▒K▒▒f▒
c▒▒&V▒fVVF▒K▒+▒cV{▒▒▒c▒▒▒6C
▒Ks;FK▒
c+#k
[ 1.171342] console [ttyS0] disabled
[ 1.171388] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.171923] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.172502] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 40, base_baud = 1500000) is a 16550A
[ 1.172861] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.177200] mali ff9a0000.gpu: Failed to get regulator
[ 1.177222] mali ff9a0000.gpu: Power control initialization failed
[ 1.177512] Unable to detect cache hierarchy from DT for CPU 0
[ 1.194463] brd: module loaded
[ 1.200440] loop: module loaded
[ 1.201093] zram: Added device: zram0
[ 1.202009] SCSI Media Changer driver v0.25
[ 1.203445] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[ 1.203475] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 1.203495] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx on device rockchip-pinctrl
[ 1.203511] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[ 1.203683] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.203699] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.204531] register spi return v = :0
[ 1.204608] tun: Universal TUN/TAP device driver, 1.6
[ 1.204619] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.206008] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.206029] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.206043] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.206081] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.206306] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.211327] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.211491] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.211501] Ring mode enabled
[ 1.211510] DMA HW capability register supported
[ 1.211519] Normal descriptors
[ 1.211530] RX Checksum Offload Engine supported (type 2)
[ 1.211538] TX Checksum insertion supported
[ 1.211547] Wake-Up On Lan supported
[ 1.211599] Enable RX Mitigation via HW Watchdog Timer
[ 1.278519] libphy: stmmac: probed
[ 1.278552] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.278568] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.279355] PPP generic driver version 2.4.2
[ 1.279663] PPP BSD Compression module registered
[ 1.279686] PPP Deflate Compression module registered
[ 1.279728] PPP MPPE Compression module registered
[ 1.279755] NET: Registered protocol family 24
[ 1.279832] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.279845] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.279871] Rockchip WiFi SYS interface (V1.00) …
[ 1.280007] usbcore: registered new interface driver catc
[ 1.280065] usbcore: registered new interface driver kaweth
[ 1.280085] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.280134] usbcore: registered new interface driver pegasus
[ 1.280192] usbcore: registered new interface driver rtl8150
[ 1.280252] usbcore: registered new interface driver r8152
[ 1.280272] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.280345] usbcore: registered new interface driver hso
[ 1.280408] usbcore: registered new interface driver asix
[ 1.280464] usbcore: registered new interface driver ax88179_178a
[ 1.280518] usbcore: registered new interface driver cdc_ether
[ 1.280576] usbcore: registered new interface driver cdc_eem
[ 1.280631] usbcore: registered new interface driver dm9601
[ 1.280699] usbcore: registered new interface driver smsc75xx
[ 1.280766] usbcore: registered new interface driver smsc95xx
[ 1.280821] usbcore: registered new interface driver gl620a
[ 1.280880] usbcore: registered new interface driver net1080
[ 1.280936] usbcore: registered new interface driver plusb
[ 1.280991] usbcore: registered new interface driver rndis_host
[ 1.281046] usbcore: registered new interface driver cdc_subset
[ 1.281104] usbcore: registered new interface driver zaurus
[ 1.281165] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.281250] usbcore: registered new interface driver int51x1
[ 1.281306] usbcore: registered new interface driver kalmia
[ 1.281361] usbcore: registered new interface driver ipheth
[ 1.281417] usbcore: registered new interface driver sierra_net
[ 1.281468] usbcore: registered new interface driver cx82310_eth
[ 1.281535] usbcore: registered new interface driver cdc_ncm
[ 1.281588] usbcore: registered new interface driver qmi_wwan
[ 1.281641] usbcore: registered new interface driver cdc_mbim
[ 1.283402] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.289138] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.289749] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.289766] ehci-pci: EHCI PCI platform driver
[ 1.289825] ehci-platform: EHCI generic platform driver
[ 1.293676] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.293720] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.293942] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.302492] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.302631] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.302648] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.302663] usb usb1: Product: EHCI Host Controller
[ 1.302676] usb usb1: Manufacturer: Linux 4.4.83 ehci_hcd
[ 1.302688] usb usb1: SerialNumber: fe3c0000.usb
[ 1.303347] hub 1-0:1.0: USB hub found
[ 1.303392] hub 1-0:1.0: 1 port detected
[ 1.304267] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.304307] ohci-platform: OHCI generic platform driver
[ 1.304947] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.304979] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.305145] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.359961] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.359982] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.359995] usb usb2: Product: Generic Platform OHCI controller
[ 1.360012] usb usb2: Manufacturer: Linux 4.4.83 ohci_hcd
[ 1.360028] usb usb2: SerialNumber: fe3e0000.usb
[ 1.360509] hub 2-0:1.0: USB hub found
[ 1.360543] hub 2-0:1.0: 1 port detected
[ 1.361324] usbcore: registered new interface driver cdc_acm
[ 1.361337] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.361396] usbcore: registered new interface driver usblp
[ 1.361446] usbcore: registered new interface driver cdc_wdm
[ 1.361494] usbcore: registered new interface driver uas
[ 1.361565] usbcore: registered new interface driver usb-storage
[ 1.361607] usbcore: registered new interface driver ums-alauda
[ 1.361648] usbcore: registered new interface driver ums-cypress
[ 1.361690] usbcore: registered new interface driver ums-datafab
[ 1.361730] usbcore: registered new interface driver ums_eneub6250
[ 1.361774] usbcore: registered new interface driver ums-freecom
[ 1.361815] usbcore: registered new interface driver ums-isd200
[ 1.361856] usbcore: registered new interface driver ums-jumpshot
[ 1.361899] usbcore: registered new interface driver ums-karma
[ 1.361940] usbcore: registered new interface driver ums-onetouch
[ 1.361981] usbcore: registered new interface driver ums-sddr09
[ 1.362022] usbcore: registered new interface driver ums-sddr55
[ 1.362063] usbcore: registered new interface driver ums-usbat
[ 1.362145] usbcore: registered new interface driver usbserial
[ 1.362183] usbcore: registered new interface driver usbserial_generic
[ 1.362215] usbserial: USB Serial support registered for generic
[ 1.362259] usbcore: registered new interface driver ch341
[ 1.362289] usbserial: USB Serial support registered for ch341-uart
[ 1.362334] usbcore: registered new interface driver cp210x
[ 1.362363] usbserial: USB Serial support registered for cp210x
[ 1.362417] usbcore: registered new interface driver option
[ 1.362448] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.362587] usbcore: registered new interface driver pl2303
[ 1.362618] usbserial: USB Serial support registered for pl2303
[ 1.362668] usbcore: registered new interface driver trancevibrator
[ 1.362684] usb20_otg: version 3.10a 21-DEC-2012
[ 1.362851] usb20_host: version 3.10a 21-DEC-2012
[ 1.366746] usbcore: registered new interface driver xpad
[ 1.366799] usbcore: registered new interface driver usb_acecad
[ 1.366847] usbcore: registered new interface driver aiptek
[ 1.366905] usbcore: registered new interface driver gtco
[ 1.366953] usbcore: registered new interface driver hanwang
[ 1.366999] usbcore: registered new interface driver kbtab
[ 1.367014] ==gsl_ts_init==
[ 1.367045] ret=0
[ 1.370893] .. rk pwm remotectl v1.1 init
[ 1.371116] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.371503] remotectl-pwm ff420030.pwm: set irq err, set support_psci to 0 !!
[ 1.371706] sensor_register_slave:mma8452,id=17
[ 1.371725] sensor_register_slave:lis3dh,id=7
[ 1.371741] sensor_register_slave:mma7660,id=18
[ 1.371757] sensor_register_slave:lsm303d,id=22
[ 1.371774] sensor_register_slave:mpu6880_acc,id=24
[ 1.371790] sensor_register_slave:mpu6500_acc,id=25
[ 1.371806] sensor_register_slave:lsm330_acc,id=26
[ 1.371823] sensor_register_slave:akm8975,id=28
[ 1.371840] sensor_register_slave:akm8963,id=29
[ 1.371855] sensor_register_slave:l3g4200d,id=43
[ 1.371871] sensor_register_slave:l3g20d,id=44
[ 1.371887] sensor_register_slave:ewtsa,id=45
[ 1.371902] sensor_register_slave:lsm330_gyro,id=48
[ 1.371919] sensor_register_slave:cm3217,id=50
[ 1.371934] sensor_register_slave:cm3218,id=51
[ 1.372880] i2c /dev entries driver
[ 1.373994] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.374062] fan53555-reg: supplied by vcc5v0_sys
[ 1.375737] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.375819] fan53555-reg: supplied by vcc5v0_sys
[ 1.377684] rk808 0-001b: Pmic Chip id: 0x0
[ 1.380841] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.380894] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.380982] DCDC_REG1: supplied by vcc3v3_sys
[ 1.381646] DCDC_REG2: supplied by vcc3v3_sys
[ 1.382135] DCDC_REG3: supplied by vcc3v3_sys
[ 1.382347] DCDC_REG4: supplied by vcc3v3_sys
[ 1.383032] LDO_REG1: supplied by vcc3v3_sys
[ 1.384115] LDO_REG2: supplied by vcc3v3_sys
[ 1.385019] LDO_REG3: supplied by vcc3v3_sys
[ 1.385931] LDO_REG4: supplied by vcc3v3_sys
[ 1.386916] LDO_REG5: supplied by vcc3v3_sys
[ 1.387820] LDO_REG6: supplied by vcc3v3_sys
[ 1.388724] LDO_REG7: supplied by vcc3v3_sys
[ 1.389781] LDO_REG8: supplied by vcc3v3_sys
[ 1.390720] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.390937] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.394277] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.394784] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80096fc000
[ 1.395341] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80096fe000
[ 1.395423] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.395440] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.395456] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.395472] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.395821] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80097d2000
[ 1.406374] fusb302 4-0022: port 0 probe success
[ 1.406426] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097d4000
[ 1.407322] IR NEC protocol handler initialized
[ 1.407340] IR RC5(x/sz) protocol handler initialized
[ 1.407356] IR RC6 protocol handler initialized
[ 1.407372] IR JVC protocol handler initialized
[ 1.407388] IR Sony protocol handler initialized
[ 1.407403] IR SANYO protocol handler initialized
[ 1.407419] IR Sharp protocol handler initialized
[ 1.407435] IR MCE Keyboard/mouse protocol handler initialized
[ 1.407451] IR XMP protocol handler initialized
[ 1.407539] usbcore: registered new interface driver uvcvideo
[ 1.407566] USB Video Class driver (1.1.1)
[ 1.407587] CamSys driver version: v0.34.3, CamSys head file version: v0.13.0
[ 1.411627] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.411760] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.412000] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.412109] _power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.414301] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.415029] device-mapper: uevent: version 1.0.3
[ 1.415330] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.418831] Bluetooth: HCI UART driver ver 2.3
[ 1.418850] Bluetooth: HCI UART protocol H4 registered
[ 1.418863] Bluetooth: HCI UART protocol LL registered
[ 1.418880] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.418895] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.418913] rtk_btusb: Register usb char device interface for BT driver
[ 1.419159] usbcore: registered new interface driver rtk_btusb
[ 1.419523] cpu cpu0: leakage=20
[ 1.436021] cpu cpu0: temp=28750, pvtm=145697 (147192 + -1495)
[ 1.436540] cpu cpu0: pvtm-sel=1
[ 1.436937] cpu cpu4: leakage=35
[ 1.449322] cpu cpu4: temp=28750, pvtm=154454 (155377 + -923)
[ 1.449479] cpu cpu4: pvtm-sel=1
[ 1.453971] sdhci: Secure Digital Host Controller Interface driver
[ 1.453990] sdhci: Copyright(c) Pierre Ossman
[ 1.454004] Synopsys Designware Multimedia Card Interface Driver
[ 1.454785] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.454916] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.454937] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.454993] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.455031] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.455076] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.455089] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.455830] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.455881] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.455901] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.455943] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.455967] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.456066] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.456295] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.456469] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.469324] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.482716] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.483179] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.485215] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.485247] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.512622] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.516127] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.518845] usbcore: registered new interface driver usbhid
[ 1.518862] usbhid: USB HID core driver
[ 1.518992] inv_mpu_iio: inv_mpu_init:746
[ 1.519741] ashmem: initialized
[ 1.521389] ff100000.saradc supply vref not found, using dummy regulator
[ 1.526491] rknandbase v1.1 2016-11-08
[ 1.526992] usbcore: registered new interface driver snd-usb-audio
[ 1.528097] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.544688] u32 classifier
[ 1.544709] Actions configured
[ 1.544759] Netfilter messages via NETLINK v0.30.
[ 1.544827] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.545211] ctnetlink v0.93: registering with nfnetlink.
[ 1.548839] xt_time: kernel timezone is -0000
[ 1.549774] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.549928] arp_tables: (C) 2002 David S. Miller
[ 1.550444] Initializing XFRM netlink socket
[ 1.550899] NET: Registered protocol family 10
[ 1.553397] mmc1: MAN_BKOPS_EN bit is not set
[ 1.553846] mip6: Mobile IPv6
[ 1.553880] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.555063] sit: IPv6 over IPv4 tunneling driver
[ 1.555540] NET: Registered protocol family 17
[ 1.555573] NET: Registered protocol family 15
[ 1.555611] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.556660] Bridge firewalling registered
[ 1.556678] Ebtables v2.0 registered
[ 1.560778] Bluetooth: RFCOMM TTY layer initialized
[ 1.560802] Bluetooth: RFCOMM socket layer initialized
[ 1.560847] Bluetooth: RFCOMM ver 1.11
[ 1.560869] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.560879] Bluetooth: BNEP filters: protocol multicast
[ 1.560895] Bluetooth: BNEP socket layer initialized
[ 1.560910] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.560925] Bluetooth: HIDP socket layer initialized
[ 1.560959] l2tp_core: L2TP core driver, V2.0
[ 1.560980] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.560996] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.561235] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.561287] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.561298] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.561310] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.561368] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.561380] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.561393] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.561444] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.561761] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.561805] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.561837] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.561869] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.565883] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.565922] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 1.565987] [BT_RFKILL]: ** disable irq
[ 1.566135] [BT_RFKILL]: bt_default device registered.
[ 1.566361] sensor_register_slave:mpu6880_gyro,id=47
[ 1.566949] Registered cp15_barrier emulation handler
[ 1.567068] Registered setend emulation handler
[ 1.568384] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.568997] mmcblk1: mmc1:0001 AJNB4R 14.6 GiB
[ 1.569083] registered taskstats version 1
[ 1.569403] mmcblk1boot0: mmc1:0001 AJNB4R partition 1 4.00 MiB
[ 1.569819] mmcblk1boot1: mmc1:0001 AJNB4R partition 2 4.00 MiB
[ 1.569993] rockchip ion idev is NULL
[ 1.570010] rga2 ff680000.rga: rga ion client create success!
[ 1.570184] rga: Driver loaded successfully ver:3.02
[ 1.570289] mmcblk1rpmb: mmc1:0001 AJNB4R partition 3 4.00 MiB
[ 1.570873] rkpart: partition size too small (4)
[ 1.570892] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.570905] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.570918] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.570930] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.570944] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.570956] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 1.570969] boot: 0x003800000 – 0x005800000 (32 MB)
[ 1.570981] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 1.570993] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 1.571006] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 1.571019] system: 0x016800000 – 0x076800000 (1536 MB)
[ 1.571032] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 1.571044] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 1.571057] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 1.571129] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.574656] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.583774] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.583960] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.584362] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.584385] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.584446] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.585418] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.585878] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.585895] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.585906] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 1.586145] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.586162] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.586176] rockchip-drm display-subsystem: failed to show loader logo
[ 1.586191] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.586205] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768
[ 1.589362] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.590175] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.609434] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.614368] mali ff9a0000.gpu: leakage=23
[ 1.639528] mali ff9a0000.gpu: temp=29375, pvtm=120111 (120663 + -552)
[ 1.642793] mali ff9a0000.gpu: pvtm-sel=0
[ 1.647119] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.648484] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.648932] mali ff9a0000.gpu: Probed as mali0
[ 1.656251] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.656316] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 1.656670] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.656763] xhci-hcd xhci-hcd.10.auto: irq 233, io mem 0xfe800000
[ 1.657022] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.657053] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.657081] usb usb3: Product: xHCI Host Controller
[ 1.657104] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 1.657127] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 1.657980] hub 3-0:1.0: USB hub found
[ 1.658053] hub 3-0:1.0: 1 port detected
[ 1.658542] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.658580] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 1.658703] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.658884] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.658913] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.658937] usb usb4: Product: xHCI Host Controller
[ 1.658959] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 1.658981] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 1.659852] hub 4-0:1.0: USB hub found
[ 1.659921] hub 4-0:1.0: 1 port detected
[ 1.662283] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.662333] usb usb4: USB disconnect, device number 1
[ 1.691219] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 1.691277] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 1.692810] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[ 1.693374] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.693882] usb usb3: USB disconnect, device number 1
[ 1.694837] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[ 1.701415] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.701610] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 1.702107] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.702320] xhci-hcd xhci-hcd.11.auto: irq 234, io mem 0xfe900000
[ 1.702724] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.702758] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.702786] usb usb3: Product: xHCI Host Controller
[ 1.702811] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 1.702836] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 1.707576] hub 3-0:1.0: USB hub found
[ 1.707776] hub 3-0:1.0: 1 port detected
[ 1.708434] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.708569] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 1.708750] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.709004] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.709037] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.709064] usb usb4: Product: xHCI Host Controller
[ 1.709090] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 1.709116] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 1.710324] hub 4-0:1.0: USB hub found
[ 1.710399] hub 4-0:1.0: 1 port detected
[ 1.715921] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.716076] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.716672] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.726160] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.726653] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.726686] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.726714] usb usb5: Product: EHCI Host Controller
[ 1.726739] usb usb5: Manufacturer: Linux 4.4.83 ehci_hcd
[ 1.726764] usb usb5: SerialNumber: fe380000.usb
[ 1.728335] hub 5-0:1.0: USB hub found
[ 1.728538] hub 5-0:1.0: 1 port detected
[ 1.730363] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.730425] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.730776] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.734723] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.734869] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.734897] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.736232] hub 1-1:1.0: USB hub found
[ 1.736572] hub 1-1:1.0: 7 ports detected
[ 1.786929] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.787043] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.787073] usb usb6: Product: Generic Platform OHCI controller
[ 1.787099] usb usb6: Manufacturer: Linux 4.4.83 ohci_hcd
[ 1.787122] usb usb6: SerialNumber: fe3a0000.usb
[ 1.790816] hub 6-0:1.0: USB hub found
[ 1.790911] hub 6-0:1.0: 1 port detected
[ 1.793662] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.793954] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.793993] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.794057] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.794108] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.794204] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.794229] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.794856] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.806099] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.819553] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.839096] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 1.846087] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input1
[ 1.850066] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 1.853849] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 1.853965] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to add ELD: -16
[ 1.855176] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 1.855353] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 1.860497]
[ 1.860534] =======================================================
[ 1.860556] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.860577] dhd_module_init: in Dongle Host Driver, version 1.363.59.144.10 (r)
[ 1.860586] ======== dhd_wlan_init_plat_data ========
[ 1.860592] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 1.860601] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 1.860607] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.860615] dhd_wlan_init_gpio: host_oob_irq: 73
[ 1.860619] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 1.860626] dhd_wifi_platform_load: Enter
[ 1.860662] Power-up adapter ‘DHD generic adapter’
[ 1.860732] =======================================================
[ 1.860736] wifi_platform_set_power = 1
[ 1.860744] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.860749] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.860755] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.860808] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[ 1.860833] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.860854] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.860871] RTL871X: module init start
[ 1.860889] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 1.861098] usbcore: registered new interface driver rtl8188eu
[ 1.861119] RTL871X: module init ret=0
[ 1.861150] otg_wakelock_init: No USB transceiver found
[ 1.861305] sensor_init: Probe name sensors
[ 1.861331] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.862950] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 09:35:57 UTC (1358501757)
[ 1.863958] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.864257] It doesn’t contain Rogue gpu
[ 1.865647] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.867332] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.870335] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.892293] ret 1024
[ 1.893486] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-Firefly-RK3399_Android7.1.1_170516_internal-186-g37b5feb’, rk_ko_ver is ‘5’, built at ‘09:41:01’, on ‘Jan 25 2018’.
[ 1.894437] Mali: Mali device driver loaded
[ 1.895497] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 1.897274] ALSA device list:
[ 1.897367] #0: rockchip,rt5640-codec
[ 1.897385] #1: ROCKCHIP,SPDIF
[ 1.897403] #2: rk-hdmi-dp-sound
[ 1.898301] Freeing unused kernel memory: 832K
[ 1.903613] init: init first stage started!
[ 1.928746] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[ 1.988157] audit: type=1403 audit(1358501757.620:2): policy loaded auid=4294967295 ses=4294967295
[ 1.988993] init: (Initializing SELinux non-enforcing took 0.09s.)
[ 1.993495] init: init second stage started!
[ 1.999946] init: Setting ro.rk.soc=rk3399
[ 2.000152] init: OK,EMMC DRIVERS INIT OK
[ 2.000200] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 2.000302] init: property_set(“ro.hardware”, “rk30board”) failed
[ 2.003343] init: Running restorecon…
[ 2.032761] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 235
[ 2.036036] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.036100] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.062846] wifi_platform_bus_enumerate device present 1
[ 2.062906] ======== Card detection to detect SDIO card! ========
[ 2.062915] mmc2:mmc host rescan start!
[ 2.079060] bcmsdh_register: register client driver
[ 2.079275] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.079395] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.079403] bus num (host idx)=2, slot num (rca)=1
[ 2.079410] found adapter info ‘DHD generic adapter’
[ 2.079484] sdioh_attach: set sd_f2_blocksize 256
[ 2.080020] F1 signature read @0x18000000=0x17224356
[ 2.084757] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 2.085382] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.085471] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 2.086623] wl_create_event_handler(): thread:wl_event_handler:b4 started
[ 2.086799] tsk Enter, tsk = 0xffffffc07aee1a90
[ 2.087045] dhd_attach(): thread:dhd_watchdog_thread:b5 started
[ 2.087208] dhd_attach(): thread:dhd_dpc:b6 started
[ 2.087508] dhd_attach(): thread:dhd_rxf:b7 started
[ 2.087541] dhd_deferred_work_init: work queue initialized
[ 2.090762] init: waitpid failed: No child processes
[ 2.091372] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 2.091793] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[ 2.091965] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 2.092071] init: (Loading properties from /default.prop took 0.00s.)
[ 2.093333] init: could not import file ‘/init.bootmode.emmc.rc’ from ‘/init.rc’: No such file or directory
[ 2.093416] init: could not import file ‘/init.recovery.rk30board.rc’ from ‘/init.rc’: No such file or directory
[ 2.093448] init: (Parsing /init.rc took 0.00s.)
[ 2.093602] init: Starting service ‘ueventd’…
[ 2.094014] init: Starting service ‘healthd’…
[ 2.094305] init: Waiting for /dev/.coldboot_done…
[ 2.098209] ueventd: ueventd started!
[ 2.099833] ueventd: invalid gid ‘trace’
[ 2.111996] Dongle Host Driver, version 1.363.59.144.10 (r)
[ 2.112061] audit: type=1400 audit(1358501757.743:3): avc: denied { mknod } for pid=185 comm=“healthd” capability=27 scontext=u:r:healthd:s0 tcontext=u:r:healthd:s0 tclass=capability permissive=1
[ 2.112247] audit: type=1400 audit(1358501757.743:4): avc: denied { write } for pid=185 comm=“healthd” name=“kmsg” dev=“tmpfs” ino=13456 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 2.112332] audit: type=1400 audit(1358501757.743:5): avc: denied { open } for pid=185 comm=“healthd” path=“/dev/kmsg” dev=“tmpfs” ino=13456 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 2.112440] audit: type=1400 audit(1358501757.743:6): avc: denied { unlink } for pid=185 comm=“healthd” name=“kmsg” dev=“tmpfs” ino=13456 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 2.112581] healthd: BatteryCurrentNowPath not found
[ 2.112614] Register interface [wlan0] MAC: ac:83:f3:9e:a6:48
[ 2.112614]
[ 2.112623] healthd: BatteryCycleCountPath not found
[ 2.112790] wl_event_handler: was terminated
[ 2.121776] wl_destroy_event_handler(): thread:wl_event_handler:b4 terminated OK
[ 2.121794] dhd_wl_ioctl: returning as busstate=0
[ 2.121839] bcmsdh_oob_intr_unregister: Enter
[ 2.121846] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.121859] dhd_txglom_enable: enable 0
[ 2.121866] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0, txglom_bucket_size=0
[ 2.121873] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 2.121880] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=128, dhd_txminmax=-1
[ 2.121887] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=0
[ 2.121894] sdioh_set_mode: set txglom_mode to copy
[ 2.121899] dhd_bus_devreset: WLAN OFF DONE
[ 2.121941] wifi_platform_set_power = 0
[ 2.121948] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.121955] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.121973] [WLAN_RFKILL]: wifi shut off power.
[ 2.122056] dhd_module_init: Exit err=0
[ 2.330991] ueventd: Coldboot took 0.23s.
[ 2.337631] init: Waiting for /dev/.coldboot_done took 0.24s.
[ 2.337699] init: /dev/hw_random not found
[ 2.338845] init: /dev/hw_random not found
[ 2.339660] file system registered
[ 2.343373] init: write_file: Unable to open ‘/sys/class/android_usb/android0/enable’: Permission denied
[ 2.343576] init: write_file: Unable to open ‘/sys/class/android_usb/android0/idVendor’: Permission denied
[ 2.343726] init: write_file: Unable to open ‘/sys/class/android_usb/android0/idProduct’: Permission denied
[ 2.343874] init: write_file: Unable to open ‘/sys/class/android_usb/android0/f_ffs/aliases’: No such file or directory
[ 2.344018] init: write_file: Unable to open ‘/sys/class/android_usb/android0/functions’: Permission denied
[ 2.344186] init: write_file: Unable to open ‘/sys/class/android_usb/android0/iManufacturer’: Permission denied
[ 2.344340] init: write_file: Unable to open ‘/sys/class/android_usb/android0/iProduct’: Permission denied
[ 2.344427] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.344477] init: write: cannot expand ‘${ro.serialno}’
[ 2.345136] init: finit_module for “/drmboot.ko” failed: Exec format errorinit: (Loading properties from /system/build.prop took 0.00s.)
[ 2.345420] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 2.345514] init: (Loading pr_o_biotice_o pern_mtz/faacat: rcoyulfdnc’ot rfinng f or G.MT4!7oak 0whe.00sn. l)ook
8] fs_mgrta tiag neicogve rnykn(piwd 18l7)a ogn Frri eJsani 1e8
09 :3 5 : 27.3246112
e init: /recbootmoodee y= nemtmcs
ified in fstab
ing 2.reco3v47r7 2fi3le syisittm: t abtlert
==[ ==r==i==e==‘==e==o==e==y=’==.==
/ 0 /mn2t/3in8te1rn]ailni_td: Stfartti/nge s/erlviocce k’apdbad’f..r.
laroi d02/e/nyabslee’: Pxer4mi ss/ioen/ bdloncke/pbloiodck/mumcsblbk0/p1a 0
xle '3 ./c.ac.he e00]00i.sidh:cSita/rbti-nga seersvsitem 'c0ons
4 /dev/block/platform/fe330000.sdhci/by-name/cache 0
4 /metadata ext4 /dev/block/platform/fe330000.sdhci/by-name/metadata 0
5 /data f2fs /dev/block/platform/fe330000.sdhci/by-name/userdata 0
6 /cust ext4 /dev/block/platform/fe330000.sdhci/by-name/cust 0
# 7 /custom ext4 /dev/block/platform/fe330000.sdhci/by-name/custom 0
8 /misc emmc /dev/block/platform/fe330000.sdhci/by-name/misc 0
9 /uboot emmc /dev/block/platform/fe330000.sdhci/by-name/uboot 0
10 /charge emmc /dev/block/platform/fe330000.sdhci/by-name/charge 0
11 /resource emmc /dev/block/platform/fe330000.sdhci/by-name/resource 0
12 /parameter emmc /dev/block/platform/fe330000.sdhci/by-name/parameter 0
13 /boot emmc /dev/block/platform/fe330000.sdhci/by-name/boot 0
14 /recovery emmc /dev/block/platform/fe330000.sdhci/by-name/recovery 0
15 /backup emmc /dev/block/platform/fe330000.sdhci/by-name/backup 0
16 /trust emmc /dev/block/platform/fe330000.sdhci/by-name/trust 0
17 /baseparamer emmc /dev/block/platform/fe330000.sdhci/by-name/baseparamer 0
18 /frp emmc /dev/block/platform/fe330000.sdhci/by-name/frp 0
19 /tmp ramdisk ramdisk 0
emmc_point is /dev/block/mmcblk1
sd_point is (null)
sd_point_2 is (null)
I:InternalSD_ROOT: /mnt/internal_sd
I:ExternalSD_ROOT: /mnt/external_sd
read cmdline
I:Boot command: boot-recovery
I:Got arguments from boot message
[ 2.367285] fs_mgr: Warning: unknown flag resize
[ 2.368356] fs_mgr: Warning: unknown flag resize
[ 2.374585] mmcblk1: error -84 transferring data, sector 32800, nr 8, cmd responE:fsei 0ex9 00o, wcaird statduesv/0bldoc0k/
pl at f2.3o74m64f1]3 b0lk0_u.pddactei_re/buy-sna:meI/mOisec:r rI /O vermrocrl
, se=== cstatrtr v3oid 0d
[ u pCmdA4rg6s(]inBt,f cerh I/aO er*r:or 29o6 ==e=
ll. vas1]n = pa ge- wirieelovck 4, .lo
2.l37o47c85a] lVFeS: Diirsty [ieno_UeSw]ri
dr eafsoon ris blocuk lde]ic
e mmcblk1p4 (err=-5).
cannot find/open a drm device: No such file or directory
fb0 reports (possibly inaccurate):
vi.bits_per_pixel = 32
vi.red.offset = 16 .length = 8
vi.green.offset = 8 .length = 8
vi.blue.offset = 0 .length = 8
fi.line_length = 4096
framebuffer: 0 (1024 x 768)
erasing_text: en_US (88 x 38 @ 1170)
no_command_text: en_US (166 x 38 @ 1170)
error_text: en_US (63 x 38 @ 1170)
installing_text: en_US (300 x 38 @ 1368)
[ 2.6E6:2f8a0i6l]e dE XtTo4 -mfosu n(mtm c/bclakc1hpe1 0()I:n vValFid: Cargnutm fnt)nd
ext4 filesystem
mount cache fail,so formate…
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8192
Inode size: 256
Journal blocks: 1024
Label:
Blocks: 32768
Block groups: 1
Reserved block group size: 7
Created filesystem with 11/8192 inodes and 1550/32768 blocks
[ 5.172766] iep dpi mode inactivity
[ 5.599227] mmcblk1: error -84 transferring data, sector 483328, nr 1024, cmd response 0x900, card status 0xd00
[ 5.599410] blk_update_request: I/O error, dev mmcblk1, sector 483328
[ 5.599442] Buffer I/O error on dev mmcblk1p10, logical block 0, lost async page write
[ 5.599578] blk_update_request: I/O error, dev mmcblk1, sector 483336
[ 5.599606] Buffer I/O error on dev mmcblk1p10, logical block 1, lost async page write
[ 5.599660] blk_update_request: I/O error, dev mmcblk1, sector 483344
[ 5.599688] Buffer I/O error on dev mmcblk1p10, logical block 2, lost async page write
[ 5.599741] blk_update_request: I/O error, dev mmcblk1, sector 483352
[ 5.599767] Buffer I/O error on dev mmcblk1p10, logical block 3, lost async page write
[ 5.599821] blk_update_request: I/O error, dev mmcblk1, sector 483360
[ 5.599845] Buffer I/O error on dev mmcblk1p10, logical block 4, lost async page write
[ 5.599897] blk_update_request: I/O error, dev mmcblk1, sector 483368
[ 5.599924] Buffer I/O error on dev mmcblk1p10, logical block 5, lost async page write
[ 5.599976] blk_update_request: I/O error, dev mmcblk1, sector 483376
[ 5.600002] Buffer I/O error on dev mmcblk1p10, logical block 6, lost async page write
[ 5.600055] blk_update_request: I/O error, dev mmcblk1, sector 483384
[ 5.600081] Buffer I/O error on dev mmcblk1p10, logical block 7, lost async page write
[ 5.600132] blk_update_request: I/O error, dev mmcblk1, sector 483392
[ 5.600158] Buffer I/O error on dev mmcblk1p10, logical block 8, lost async page write
[ 5.634460] mmcblk1: error -84 transferring data, sector 487424, nr 1024, cmd response 0x900, card status 0xd00
[ 5.713559] mmcblk1: error -84 transferring data, sector 495736, nr 8, cmd response 0x900, card status 0xd00
[ 5.722681] VFS: Dirty inode writeback failed for block device mmcblk1p10 (err=-5).
[ 5.725896] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.728007] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[ 5.728039] mmcblk1: error -84 transferring data, sector 483330, nr 2, cmd response 0x900, card status 0x0
[ 5.728068] mmcblk1: retrying using single block read
[ 5.730384] mmcblk1: error -84 transferring data, sector 483330, nr 2, cmd response 0x900, card status 0x0
E:failed to mount /cache (Invalid argument)
[ 5.734734] EXT4-fs (mmcblk1p10): unable to read superblock
[ 5.740837] mmc1: Got data interrupt 0x00000002 even though no data operatioE:failed to mount /metadata (Invalid argument)
n was in progress.
[ 5.742989] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[ 5.743004] mmcblk1: error -84 transferring data, sector 3891202, nr 2, cmd response 0x900, card status 0x0
[ 5.743018] mmcblk1: retrying using single block read
[ 5.745211] mmcblk1: error -84 transferring data, sector 3891202, nr 2, cmd response 0x900, card status 0x0
[ 5.745461] EXT4-fs (mmcblk1p12): unable to read superblock
mount metadata fail,so formate…
Block size: 4096
Inodes per group: 1024
Inode size: 256
Label:
Blocks: 4096
Block groups: 1
Created filesystem with 11/1024 inodes and 1102/4096 blocks
[ 6.079413] vendor storage:20160801 ret = -1
[ 7.190992] mmcblk1: error -84 transferring data, sector 3900024, nr 8, cmd response 0x900, card status 0xd00
[ 7.276026] mmcblk1: error -84 transferring data, sector 3891200, nr 1024, cmd response 0x900, card status 0xd00
[ 7.282195] VFS: Dirty inode writeback failed for block device mmcblk1p12 (err=-5).
[ 7.286113] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 7.289217] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[ 7.289268] mmcblk1: error -84 transferring data, sector 3891202, nr 2, cmd response 0x900, card status 0x0
[ 7.289298] mmcblk1: retrying using single block read
[ 7.291487] mmcblk1: error -84 transferring data, sector 3891202, nr 2, cmd response 0x900, card status 0x0
[ 7.293980] EXT4-fs (mmcblk1p12): unable to read superblock
bootmode = emmc
Command: “recovery” “–wipe_all”
[ 7.299362] audit: type=1400 audit(1358501762.933:7): avc: denied { open } for pid=187 comm=“recovery” path=“/dev/properties/u:object_r:secureboot_prop:s0” dev=“tmpfs” ino=2145 scontext=u:r:recovery:s0 tcontext=u:object_r:secureboot_prop:s0 tclass=file permissive=1
[ 7.301641] audit: type=1400 audit(1358501762.933:8): avc: denied { getattr } for pid=187 comm=“recovery” path=“/dev/properties/u:object_r:secureboot_prop:s0” dev=“tmpfs” ino=2145 scontext=u:r:recovery:s0 tcontext=u:object_r:secureboot_prop:s0 tclass=file permissive=1
[ 7.303896] audit: type=1400 audit(1358501762.936:9): avc: denied { open } for pid=187 comm=“recovery” path=“/dev/properties/u:object_r:pppoe_prop:s0” dev=“tmpfs” ino=2146 scontext=u:r:recovery:s0 tcontext=u:object_r:pppoe_prop:s0 tclass=file permissive=1
ro.dalvik.vm.native.bridge=0
dalvik.vm.isa.arm.variant=cortex-a15
dalvik.vm.isa.arm.features=default
dalvik.vm.isa.arm64.variant=cortex-a53
dalvik.vm.isa.arm64.features=default
dalvik.vm.usejit=true
dalvik.vm.heapsize=512m
dalvik.vm.lockprof.threshold=500
dalvik.vm.dex2oat-Xms=64m
dalvik.vm.dex2oat-Xmx=512m
dalvik.vm.heapmaxfree=8m
dalvik.vm.heapminfree=512k
dalvik.vm.heapstartsize=16m
dalvik.vm.appimageformat=lz4
dalvik.vm.usejitprofiles=true
dalvik.vm.dex2oat-threads=2
dalvik.vm.heapgrowthlimit=192m
dalvik.vm.stack-trace-file=/data/anr/traces.txt
dalvik.vm.image-dex2oat-Xms=64m
dalvik.vm.image-dex2oat-Xmx=64m
dalvik.vm.boot-dex2oat-threads=2
dalvik.vm.heaptargetutilization=0.75
dalvik.vm.image-dex2oat-threads=2
ro.config.enable.remotecontrol=false
ro.build.fingerprint=rockchip/rk3399_firefly_box/rk3399_firefly_box:7.1.2/NHG47K/omy01261011:userdebug/test-keys
pm.dexopt.boot=verify-profile
pm.dexopt.ab-ota=speed-profile
pm.dexopt.install=interpret-only
pm.dexopt.core-app=speed
pm.dexopt.bg-dexopt=speed-profile
pm.dexopt.first-boot=interpret-only
pm.dexopt.shared-apk=speed
pm.dexopt.nsys-library=speed
pm.dexopt.forced-dexopt=speed
ro.rk.soc=rk3399
ro.rk.displayd.enable=false
ro.rk.bt_enable=true
ro.rk.statusbar=0
ro.rk.systembar.tabletUI=false
ro.rk.systembar.voiceicon=true[ 7.305966] audit: type=1400 audit(1358501762.940:10): avc: denied { getattr } for pid=187 comm=“recovery” path=“/dev/properties/u:object_r:pppoe_prop:s0” dev=“tmpfs” ino=2146 scontext=u:r:recovery:s0 tcontext=u:object_r:pppoe_prop:s0 tclass=file permissive=1
[ 7.306064] audit: type=1400 audit(1358501762.940:11): avc: denied { open } for pid=187 comm=“recovery” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=2147 scontext=u:r:recovery:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=file permissive=1
[ 7.306107] audit: type=1400 audit(1358501762.940:12): avc: denied { getattr } for pid=187 comm=“recovery” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=2147 scontext=u:r:recovery:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=file permissive=1
ro.rk.MassStorage=false
ro.rk.hdmi_enable=true
ro.rk.flash_enable=true
ro.rk.homepage_base=Firefly | 让科技更简单,让生活更智能
ro.rk.def_brightness=200
ro.rk.screenoff_time=2147483647
ro.rk.screenshot_enable=true
ro.rk.LowBatteryBrightness=true
ro.rk.install_non_market_apps=true
ro.sf.hwrotation=0
ro.sf.lcd_density=213
ro.sf.fakerotation=false
ro.adb.secure=0
ro.com.android.dataroaming=true
ro.com.widevine.cachesize=16777216
ro.usb.default_mtp=true
ro.boot.mode=emmc
ro.boot.noril=false
ro.boot.console=ttyFIQ0
ro.boot.selinux=permissive
ro.boot.baseband=N/A
ro.boot.hardware=rk30board
ro.hdmi.device_type=4
ro.hwui.path_cache_size=32
ro.hwui.layer_cache_size=48
ro.hwui.texture_cache_size=72
ro.hwui.disable_scissor_opt=true
ro.hwui.gradient_cache_size=1
ro.hwui.r_buffer_cache_size=8
ro.hwui.drop_shadow_cache_size=6
ro.hwui.text_large_cache_width=2048
ro.hwui.text_small_cache_width=1024
ro.hwui.text_large_cache_height=1024
ro.hwui.text_small_cache_height=1024
ro.hwui.texture_cache_flushrate=0.4
ro.wifi.channels=
ro.allow.mock.location=0
ro.audio.monitorOrientation=true
ro.board.platform=rk3399
ro.build.id=NHG47K
ro.build.date=Fri Jan 26 10:11:46 CST 2018
ro.build.date.utc=1516932706
ro.build.host=tchipserver2
ro.build.tags=test-keys
ro.build.type=userdebug
ro.build.user=omy
ro.build.flavor=rk3399_firefly_box-userdebug
ro.build.display.id=rk3399_firefly_box-userdebug 7.1.2 NHG47K eng.omy.20180126.101146 test-keys
ro.build.product=rk3399_firefly_box
ro.build.version.sdk=25
ro.build.version.base_os=
ro.build.version.release=7.1.2
ro.build.version.codename=REL
ro.build.version.incremental=eng.omy.20180126.101146
ro.build.version.preview_sdk=0
ro.build.version.all_codenames=REL
ro.build.version.security_patch=2017-04-05
ro.build.description=rk3399_firefly_box-userdebug 7.1.2 NHG47K eng.omy.20180126.101146 test-keys
ro.build.characteristics=box
ro.intel.logger=/system/vendor/bin/logcatext
ro.rksdk.version=RK30_ANDROID7.1.2-SDK-v1.00.00
ro.udisk.visible=true
ro.secure=1
ro.target.product=box
ro.tether.denied=false
ro.zygote=zygote64_32
ro.default.size=100
ro.factory.tool=0
ro.factory.hasGPS=false
ro.factory.hasUMS=false
ro.factory.without_battery=false
ro.factory.storage_suppntfs=true
ro.product.cpu.abi=arm64-v8a
ro.product.cpu.abilist=arm64-v8a,armeabi-v7a,armeabi
ro.product.cpu.abilist32=armeabi-v7a,armeabi
ro.product.cpu.abilist64=arm64-v8a
ro.product.name=rk3399_firefly_box
ro.product.board=rk30sdk
ro.product.brand=rockchip
ro.product.model=firefly-rk3399
ro.product.device=rk3399_firefly_box
ro.product.usbfactory=rockchip_usb
ro.product.manufacturer=rockchip
ro.product.first_api_level=25
ro.service.default_logfs=apklogfs
ro.support.lossless.bitstream=true
ro.baseband=N/A
ro.bootmode=emmc
ro.hardware=rk30board
ro.opengles.version=196610
ro.revision=0
ro.safemode.disabled=true
ro.bootimage.build.date=Fri Jan 26 10:11:46 CST 2018
ro.bootimage.build.date.utc=1516932706
ro.bootimage.build.fingerprint=rockchip/rk3399_firefly_box/rk3399_firefly_box:7.1.2/NHG47K/omy01261011:userdebug/test-keys
ro.bootloader=unknown
ro.debuggable=1
ro.enable_boot_charger_mode=0
sf.power.control=8847360
init.svc.adbd=running
init.svc.console=running
init.svc.healthd=running
init.svc.ueventd=running
init.svc.recovery=running
rild.libpath=/system/lib/libreference-ril.so
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
camera2.portability.force_api=1
persist.core.enabled=0
persist.intel.logger.rot_cnt=20
persist.intel.logger.rot_size=5000
persist.tegra.nvmmlite=1
persist.enable.3g.dongle=true
testing.mediascanner.skiplist=/mnt/shell/emulated/Android/
keyguard.no_require_sim=true
ExternalSD_ROOT=/mnt/external_sd
InternalSD_ROOT=/mnt/internal_sd
UserVolumeLabel=RockChip
security.perf_harden=1
debug.nfc.se=false
debug.nfc.fw_download=false
debug.atrace.tags.enableflags=0
net.bt.name=Android
net.change=net.bt.name
sys.hwc.device.primary=HDMI-A
sys.hwc.compose_policy=6
sys.usb.controller=fe800000.dwc3
sys.dump.binder_stats.anr=1
sys.dump.binder_stats.uiwdt=1
sys.rkadb.root=0
sys.status.hidebar_enable=false
sys.dropbox.max_size_kb=4096
sys.wallpaper.rgb565=0
sys.resolution.changed=false
persist.sys.ui.hw=true
persist.sys.usb.config=mtp,adb
persist.sys.boot.check=false
persist.sys.media.avsync=true
persist.sys.dalvik.vm.lib.2=libart.so
persist.sys.timezone=
persist.sys.strictmode.visual=false
persist.sys.framebuffer.main=1920x1080
ro.ril.ecclist=112,911
ril.function.dataonly=1
sys.usb.config=adb
sys.usb.configfs=1
Supported API: 3
[ 7.363584] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 7.366506] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[ 7.366541] mmcblk1: error -84 transferring data, sector 483330, nr 2, cmd response 0x900, card status 0x0
[ 7.366553] mmcblk1: retrying using single block read
[ 7.370739] EXT4-fs (mmcblk1p10): no journal found
E:Can’t mount /cache/deleteApkFile.dat
open /cache/deleteApkFile.dat failed 2(No such file or directory)
copyFileToMem failed
– Wiping data…
Formatting /data…
F2FS-tools: mkfs.f2fs Ver: 1.7.0 (2016-07-28)
Info: Debug level = 0
Info: Label =
Info: Trim is disabled
Info: Segments per section = 1
Info: Sections per zone = 1
Info: sector size = 512
Info: total sectors = 26603520 (12990 MB)
Info: zone aligned segment0 blkaddr: 512
Info: format version with
"Linux version 4.4.83 (omy@tchi[serve 2 ) 7(g.cc3 v9er5si9on3 2]4 r.a 2n1d01o3 :(p erelfeasse.) f(G2CCf) s) :#4 7 uSMnP iPnitREEaMlPT Fri Jan d6 09u:2r:n49d CoSTm 2 01r8"e
ad (16 bytes read, 92 bits of entropy available)
Info: Overprovision ratio = 1.760%
Info: Overprovision segments = 232 (GC reserved = 121)
[ 7.479564] mmcblk1: error -84 transferring data, sector 3932160, nr 16, cmd response 0x900, card status 0xd00
[ 7.479616] blk_update_request: 380 callbacks suppressed
[ 7.479623] blk_update_request: I/O error, dev mmcblk1, sector 3932160
[ 7.479631] buffer_io_error: 377 callbacks suppressed
[ 7.479640] Buffer I/O error on dev mmcblk1p14, logical block 0, lost async page write
[ 7.479658] blk_update_request: I/O error, dev mmcblk1, sector 3932168
[ 7.479667] Buffer I/O error on dev mmcblk1p14, logical block 1, lost async page write
[ 7.481776] mmcblk1: error -84 transferring data, sector 3936256, nr 48, cmd response 0x900, card status 0xd00
[ 7.481787] blk_update_request: I/O error, dev mmcblk1, sector 3936256
[ 7.481795] Buffer I/O error on dev mmcblk1p14, logical block 512, lost async page write
[ 7.481805] blk_update_request: I/O error, dev mmcblk1, sector 3936264
[ 7.481813] Buffer I/O error on dev mmcblk1p14, logical block 513, lost async page write
[ 7.481823] blk_update_request: I/O error, dev mmcblk1, sector 3936272
[ 7.481831] Buffer I/O error on dev mmcblk1p14, logical block 514, lost async page write
[ 7.481839] blk_update_request: I/O error, dev mmcblk1, sector 3936280
[ 7.481847] Buffer I/O error on dev mmcblk1p14, logical block 515, lost async page write
[ 7.481856] blk_update_request: I/O error, dev mmcblk1, sector 3936288
[ 7.481864] Buffer I/O error on dev mmcblk1p14, logical block 516, lost async page write
[ 7.481873] blk_update_request: I/O error, dev mmcblk1, sector 3936296
[ 7.481880] Buffer I/O error on dev mmcblk1p14, logical block 517, lost async page write
[ 7.484190] mmcblk1: error -84 transferring data, sector 3940392, nr 8, cmd response 0x900, card status 0xd00
[ 7.484204] blk_update_request: I/O error, dev mmcblk1, sector 3940392
[ 7.484213] Buffer I/O error on dev mmcblk1p14, logical block 1029, lost async page write
[ 7.530551] mmcblk1: error -84 transferring data, sector 3952640, nr 1024, cmd response 0x900, card status 0xd00
[ 7.530674] blk_update_request: I/O error, dev mmcblk1, sector 3952640
[ 7.530691] Buffer I/O error on dev mmcblk1p14, logical block 2560, lost async page write
