Audio input on AIO-3399J does not work
Hi
We have aio-3399j (http://en.t-firefly.com/product/industry/aio_3399.html) with ubuntu from official webside (AIO-3399J_xubuntu16.04_20170119.7z). Our problem is that we are not able to make microphone working. We used analog audio (Combo Audio Jack / Phone) but we also tried Line-in. Speaker is working and audio card is detected (we can see it in alsamixer as well as in pulseaudio).
We spent some time to investigate it but we did not figure it out.
Thanks for any ideas.
Hi,
Same problem here. Did You find solution for this?
Pekka
peksuj Posted at 10/17/2018 16:46
Hi,
Update your ubuntu Firmware from wiki.
VCESoft不僅為你提供優秀的資料,而且還為你提供優質的服務。如果你購買了VCESoft的考古題,VCESoft將為你提供一年的免費更新。這樣你就可以一直擁有最新的C_S4CPR_2508試題資料。而且,萬一你用了C_S4CPR_2508考古題以後,考試還是失敗的話,VCESoft保證全額退款。這樣一來,你還擔心什麼呢?VCESoft對自己的資料有足夠的信心,你也要對VCESoft有足夠的信心。為了你的考試能夠成功,千萬不要錯過VCESoft這個網站。因為如果錯過了它,你就等於錯失了一次成功的機會。
Your article is brilliant beyond measure, thank you for sharing! Thanks to C-BCSSS-2502 reliable exam braindumps, I climbed the career ladder and earned more—today, I’m giving it away for free!
I am so grateful for your share, the article is amazing! Free Dumps C-BCWME-2504 questions exam materials—good luck to everyone!
想要通過ISO-14001-Lead-Auditor認證考試?擔心考試會變體,來嘗試最新版本的題庫學習資料。我們提供的PECB ISO-14001-Lead-Auditor考古題準確性高,品質好,是你想通過考試最好的選擇,也是你成功的保障。你可以免費下載100%準確的ISO-14001-Lead-Auditor考古題資料,我們所有的PECB產品都是最新的,這是經過認證的網站。它覆蓋接近95%的真實問題和答案,快來訪問Testpdf網站,獲取免費的ISO-14001-Lead-Auditor題庫試用版本吧!
This article is incredibly motivating, thank you for sharing it! Free access to the Valid OGBA-101 exam cram questions now. Wishing you all the best of luck!
Thank you for the article, it was an absolute revelation. SecOps-Generalist visual cert test test questions—your key to advancing in your career and boosting your salary!
