Network PCIe Card not detected in rk3399
Dear,
I am using the firefly RK-3399 board which has Mini PCIe connector on it.
A PCIe Network card is inserted into Mini PCIe slot using a “Mini PCI-E to PCI-E Express 1X Extension Cord Adapter Card with USB Riser Card”
For some reason the PCIe card is not detected in the firefly board when checked using “lspci” command. lspci command shows nothing.
Could you please throw some points which can help us to identify why the card is not detected?
Setup Details:
Extension Cord Adapter purchased from AMAZON: http://a.co/b5k9Oju
If you have ever came across issue with the Riser cards, please suggest us the suitable Mini PCIe to PCIe extension cord.
Waiting for your technical suggestion.
this from RK suggest. the below they had tried.
Marvell wifi 8897
ASmedia PCIEtoSAS ASM1061
Realtek Ethernet 8996
thanks for reply, But this above mentioned HW doesnt have Mini PCIe slot.
I want to know is there any extension cord that is used to connect PCIe card to Mini PCIe slot on Rk3399 board other than “Mini PCI-E to PCI-E Express 1X Extension Cord Adapter Card with USB Riser Card”
WajahathMM Posted at 4/17/2018 15:31
I want to know is there …
i have no try that device yet , so i cannot figure out if it work.
some developer have tried the D720201 , a PCIe to 2 usb3.0.
it work fine under the newest ubuntu firmware AIO-3399J_xubuntu1604_20170119.7z
Dear,
Which M2 connector cord was used along with the D720201 to connect to firefly rk3399?
WajahathMM Posted at 4/18/2018 20:05
Dear,
He used the M.2 m-key interface of D720201 on the AIO-3399J . export to 2 usb3.0 port.
Ok. Thanks.
IT業界で働いているあなたにとってのWGUのSecure-Software-Design試験の重要性を知っていますから、我々はあなたを助けられるWGUのSecure-Software-Designソフトを開発しました。我々はあなたにすべての資料を探して科学的に分析しました。これらをするのはあなたのWGUのSecure-Software-Design試験を準備する圧力を減少するためです。
The article is outstanding, thank you for sharing! Good luck on your exams! Here are the free 2V0-11.25 reliable test topics pdf questions for you.
Thank you for sharing such a powerful article, it really left an impression. Best wishes to everyone! Latest C_BW4H_2505 test registration test questions are now available for free.
Your article has truly stayed with me, thank you for sharing. Certification H12-841_V1.5 torrent has great content, and it’s provided to you without any fees.
Your article is absolutely awe-inspiring, thank you for sharing! The Valid EAPA_2025 exam bootcamp materials questions are free—use them to elevate your career and salary!
Thank you for sharing; it was truly incredible! We’ve made Latest C1000-197 test format available, packed with useful content, to help you, free of charge.
This article really made an impact, thank you for sharing! Getting ready for the Exam C-TS462-2023 fees exam – wish me luck!
Your article is truly stunning, thank you for sharing! Free PostgreSQL-Essentials new learning materials to improve your IT knowledge. Wishing you all the best!
