[AIO-3288J][Ubuntu]: USB port not working when i flash the development board.
Hello,
After receiving the AIO-3288, it was flashed with Android 5.0 and all the USB ports were working.
As soon as i flashed Ubuntu 14.04 on it, then the USB ports are not working.
On re-flashing android once again, the USB ports are still disabled.
Please Help!!!
Thanks,
Rohit.
Any updates on the above mentioned issue.
Rohit Posted at 5/1/2018 12:07
which firmware got this problem ?
Ubuntu 14.04 is the firmware.
I have downloaded the Ubuntu image from the below link
http://en.t-firefly.com/doc/download/index/id/4.html
What are the steps to boot Firefly AIO-3288J on Linux Operating System?
I just had a similar problem - trying to use the update program to write to /dev/sda via the rockchip update program and specifying the CONTROL root=/dev/sda1.
No error messages during the upload or the data check - but I noticed the power light on the SSD I had plugged into the USB 3.0 port wasn’t on. I tried the USB 2.0 ports too.
Basically, I had to scp the linuxrootfs-normal.img to the device when it was booted from eMMC. Then I used ‘gnome_disks’ to install that img to the usb device. Then resizefs2 to gain the whole partition size (after running something that resizefs suggested).
Then I took a parameter.txt file and commented out everything except the CONTROL line and specified root=/dev/sda1.
I flashed the param file via the update program, I believe the command I used was ‘di -p parameter.txt’ and rebooted.
I’m using a mixed environment of Macs, so the ‘scp’ was no issue - but I seem to recall the default /etc/sshd_config in 16.04 doesn’t allow Authentication by password, so if you try to copy via another Ubuntu machine you will need to modify the directives and restart sshd on the FireFly.
Hope this helps.
Um die Microsoft MD-102 Zertifizierungsprüfung zu bestehen, ist es notwendig, geeignete Prüfungsmaterialien zu wählen. Unser Zertpruefung bietet Ihnen die effiziente Materialien zur Microsoft MD-102 Zertifizierungsprüfung. Die IT-Experten von Zertpruefung sind alle erfahrungsreich. Die von ihnen erforschten Materialien sind den realen Prüfungsthemen fast gleich. Zertpruefung ist eine Website, die den Kandidaten Bequemlichkeiten zur Zertifizierungsprüfung bietet und Ihnen helfen, die Microsoft MD-102 Prüfung zu bestehen.
I’m so impressed with this article, thank you for your generosity in sharing. This is the Reliable exam N16599GC10 dumps free exam I passed for my promotion and salary raise. It’s free for you today—hope you reach your career milestones!
弊社はCTAL-TAE_V2問題集の英語版と日本語版をリリースしています。英語版と日本語版の内容は同じですけど、言語だけ違いがあります。それなので、CTAL-TAE_V2に関する英語試験や日本語試験に参加する予定があるご客様は安心に問題集を購入できます。CTAL-TAE_V2試験のために、気楽に準備したり、参加したりしています。その他、我々のCTAL-TAE_V2日本語問題集を購入すると、英語版を送ります。
