USB 3.0 camera support with gstreamer
Hi all,
I have been evaluating the FireFly ROC-RK3328-CC and AIO-3399J and I got mixed results on it.
Our goal is to use USB 3.0 cameras and be able to render them over USB 3.0 and HDMI out at the same time.
When using Firefly Ubuntu images using gstreamer when using the following pipeline, which essentially capture USB video and render them to fakesink. This way, I can monitor the real USB bandwidth.
gst-launch-1.0 v4l2src ! video/x-raw,width=1920,height=1080,framerate=60/1 ! fpsdisplaysink video-sink=”fakesink sync=false” sync=false text-overlay=false –v
Using the fpsdisplaysink plugin, I am able to get the frame rate of the data rendered to null.
With the RK3328, we are able to get 37 fps.
With the RK3399, we are able to get 20 fps. I am a bit concerned about this result since I hoped to have a better frame rate with this chip.
I have made also some code in order to capture video at different layers. Here is the architecture in order to capture video from UVC camera under Linux.
USB Camera → xHCI (USB 3.0) → uvcvideo (UVC) → V4L2 → gstreamer
I probed the dataflow with some applications and here is our results at 1080p60.
Dataflow between xHCI to uvcvideo is 1080p60
Dataflow between uvcvideo to V4L2 is 1080p60
Dataflow between V4L2 to gstreamer is 1080p37 for RK3328 and 1080p20 for RK3399
This also proves that gstreamer is not in cause.
It seems there are some issues in V4L2 when you capture uncompressed video using USB.
There is no problem with the following setup if you are on another platform, like x86_64.
I am also concerned about CPU utilization when doing these tests, is it almost 80-100% only for capturing from USB 3.0. Are there some DMA functions we can enable in order to unload the CPU?
Are you already familiar with this type of issue.
I will also try to post this problem in the community in order to get a feed back on it.
Thanks for your time.
Jérôme
I was blown away by how much I learned from it. Training Construction-Manager materials questions shared for free! Best of luck in your exam preparations!
Your article was incredibly refreshing and inspiring, thank you! Wish me all the success I can get for the Reliable NCP-EUC test labs exam!
PassTIP의 SAP인증 C-TS462-2023시험덤프는 고객님의 IT자격증을 취득하는 꿈을 실현시켜 드리는 시험패스의 지름길입니다. SAP인증 C-TS462-2023덤프에는 실제시험문제의 거의 모든 문제를 적중하고 습니다. PassTIP의 SAP인증 C-TS462-2023덤프가 있으면 시험패스가 한결 간편해집니다.
Many viewpoints in the article have been very inspiring, and I’ve benefited greatly. The New-Jersey-Real-Estate-Salesperson valid exam pattern questions were key in securing my promotion and raise—now it’s your turn! Get them for free!
It really broadened my horizons. Enhance your IT abilities and access Clearer CTS-D explanation for free. Wishing you the best!
This is such a motivational piece, thank you for sharing! The Latest study guide HPE0-G04 sheet questions are free—unlock career success and salary raises today!
Thank you for sharing this truly remarkable article! I achieved career success with the Latest exam FCSS_CDS_AR-7.6 questions answers, earning both a promotion and raise. It’s free for everyone now. Best of luck!
