AIO-3399J LVDS
My problem is that I install Ubuntu firmware from Your download page and try connect first HDMI display and it’s works greate. But then I try connect LVDS display, check pinouts many time and look linux setting, but nothing came to display, only backround LED brightness. LVDS display works in HDMI to LVDS converter and pinouts is same than AIO-3399J board. Then I look linux setting (using “xrandr”) and I dont find any other than HDMI screen. I look internet that there must be all available screens?
I try find answer from Your forum, but no success. Some information that I need add some *.dts file and recompile kernel, but I think there must be easier option?
Also speaker output not work correctly. Connector right channel doesn’t work at all and left output is set right in Ubuntu. Maeby some kernel bug?
Thanks, Pekka
I download kernel tar from gitlab and edit kernel/arch/arm64/configs/firefly_defconfig file parameters:
CONFIG_LCD_MIPI is not set → CONFIG_LCD_MIPI=y
and add these lines:
CONFIG_MIPI_DSI=y
CONFIG_RK32_MIPI_DSI=y
used it to compile kernel and install that then. Cant still find LVDS display xrandr or settings editor.
Hi,
Hard kernel learning and now I can compile kernel and flash it to Firefly. But cant still get LVDS singnals. I try rk3399-firefly-linux-edp.dts and get EDP support in Ubuntu. I try rk3399-firefly-linux-mipi.dts and get DSI support. I cant find file rk3399-firefly-aio-linux-lvds.dts. Every information what i found tell to use that file…
Manufactures resource pages I find LVDS configuration details and they use file rk3399-firefly-aio-linux-lvds.dts. I think some information is now wrong…
Sorry my english :wink:
Pekka
Hi,
Now there is instructions to compile kernel in AIO-3399J resources. Thanks. I use earlier RK3399 instructions to compile kernel.
Still waiting updates to LVDS instructions…
Learning is funny, but frustraiting when cant find any help.
Pekka
refer to this patch:
https://github.com/FireflyTeam/kernel/commit/d3ee06a541f0f6e8613060ddbefd2b85bfdf0b03
首先用示波器量一下mipi clk是否有输出
775这个片子需要dsi时钟,然后复位,3399发mipi cmd初始化
先不用接屏,正常情况下lvds都会有稳定时钟输出
我就说几个关键点
1、3399 mipi输出时钟要正确稳定;
2:mipi时钟正常后775才能复位发送mipi命令
3、dts命令参数需要根据lvds屏微调几个寄存器,这个需要问东芝拿文档
4、dts里把lvds,edp等都有disabled,保证vop控制器只输出mipi信号
-------摘取 Firefly开源技术交流② ywmen 描述
Hi,
No I have problem to compile kernel:
CC arch/arm64/kernel/topology.o
arch/arm64/kernel/topology.c: In function ‘parse_cluster’:
arch/arm64/kernel/topology.c:133:40: warning: ‘%d’ directive output may be truncated writing between 1 and 10 bytes into a region of size 3 [-Wformat-truncation=]
error, forbidden warning: topology.c:133
scripts/Makefile.build:258: recipe for target ‘arch/arm64/kernel/topology.o’ failed
make[1]: *** [arch/arm64/kernel/topology.o] Error 1
Makefile:983: recipe for target ‘arch/arm64/kernel’ failed
make: *** [arch/arm64/kernel] Error 2
make: *** Odotetaan keskeneräisiä töitä…
CC fs/hfsplus/catalog.o
kernel/relay.c: In function ‘relay_create_buf_file’:
kernel/relay.c:420:35: warning: ‘snprintf’ output may be truncated before the last format character [-Wformat-truncation=]
error, forbidden warning: relay.c:420
scripts/Makefile.build:258: recipe for target ‘kernel/relay.o’ failed
make[1]: *** [kernel/relay.o] Error 1
make[1]: *** Odotetaan keskeneräisiä töitä…
CC fs/hfsplus/dir.o
Makefile:983: recipe for target ‘kernel’ failed
make: *** [kernel] Error 2
CC fs/xfs/xfs_discard.o
In file included from fs/xfs/xfs_inode.h:22:0,
from fs/xfs/xfs_bmap_util.c:28:
fs/xfs/xfs_bmap_util.c: In function ‘xfs_swap_extents_check_format’:
fs/xfs/libxfs/xfs_inode_fork.h:90:30: warning: ‘<<’ in boolean context, did you mean ‘<’ ? [-Wint-in-bool-context]
error, forbidden warning: xfs_inode_fork.h:90
scripts/Makefile.build:258: recipe for target ‘fs/xfs/xfs_bmap_util.o’ failed
make[2]: *** [fs/xfs/xfs_bmap_util.o] Error 1
make[2]: *** Odotetaan keskeneräisiä töitä…
scripts/Makefile.build:403: recipe for target ‘fs/xfs’ failed
make[1]: *** [fs/xfs] Error 2
Makefile:983: recipe for target ‘fs’ failed
make: *** [fs] Error 2
Is the problem in gcc compiler, config file or dts file ?
I use Your instructions on resource page.
BR,
Pekka
peksuj Posted at 6/7/2018 16:51
Hi,
http://en.t-firefly.com/doc/product/info/290.html
Hi,
I make all just exacly with that page instructions. I even reinstall Ubuntu, but still same error. I didnt find any help for that error from internet. Is there a new GCC version of aarch64 compiler? My gcc-aarch46 version is 7.3.0. Did You test that instructions?
Thanks for help.
Pekka
Hi,
Good news! Many hard hours I finly get compiling success. I try Ubuntu 18 whit different computers but every time same erros when compiling. Then I install Ubuntu 16 and have error when try install aarch64 compiler. I then use “sudo apt-get install gcc-5-aarch64-linux-gnu” and get compiling finished. I think that problem can be in aarch64 copiler 7.3.0 version? I used aarch64 version 5.4.0.
Now I get signal to LVDS display and seeing some stripes. I try set LVDS parameters to dts file. After setting parameters correctly (I think so) I only get blank screen, not anymore something abnormal.
xrandr say:
DSI-0 connected 960x1080+0+0
But my display is 1920x1080 15,6" (dual LVDS) AUO G156HTN02.1
Thanks.
Pekka
Hi,
I use this settings:
&dsi {
status = “okay”;
dsi_panel: panel {
compatible =“simple-panel-dsi”;
reg = <0>;
//ddc-i2c-bu
//power-supply = <&vcc_lcd>;
backlight = <&backlight>;
enable-gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio2 27 GPIO_ACTIVE_HIGH>;
bus-format = <MEDIA_BUS_FMT_RGB888_1X24>; //MEDIA_BUS_FMT_RGB666_1X18
dsi,lvds-force-clk = <800>; // 800/2/3 ~= 65Mhz
dsi,lanes = <4>;
    dsi,channel = <0>;
    enable-delay-ms = <35>;
    prepare-delay-ms = <6>;
    unprepare-delay-ms = <0>;
    disable-delay-ms = <20>;
    size,width = <120>;
    size,height = <170>;
    status = "okay";
	panel-init-sequence = [
		29 00 06 3C 01 05 00 03 00
		29 00 06 14 01 03 00 00 00
		29 00 06 64 01 03 00 00 00
		29 00 06 68 01 03 00 00 00
		29 00 06 6C 01 03 00 00 00
		29 00 06 70 01 03 00 00 00
		29 00 06 34 01 1F 00 00 00
		29 00 06 10 02 1F 00 00 00
		29 00 06 04 01 01 00 00 00
		29 00 06 04 02 01 00 00 00
		29 00 06 50 04 20 01 F0 03
		29 00 06 54 04 08 00 08 00
		29 00 06 58 04 20 03 20 00
		29 00 06 5C 04 04 00 0B 00
		29 00 06 60 04 00 05 11 00
		29 00 06 64 04 01 00 00 00
		29 00 06 A0 04 06 80 44 00
		29 00 06 A0 04 06 80 04 00
		29 00 06 04 05 04 00 00 00
		29 00 06 80 04 00 01 02 03
		29 00 06 84 04 04 07 05 08
		29 00 06 88 04 09 0A 0E 0F
		29 00 06 8C 04 0B 0C 0D 10
		29 00 06 90 04 16 17 11 12
		29 00 06 94 04 13 14 15 1B
		29 00 06 98 04 18 19 1A 06
		29 00 06 9C 04 31 00 00 00
	panel-exit-sequence = [
		05 05 01 28
		05 78 01 10
		native-mode = <&timing0>;
		timing0: timing0 {
			clock-frequency = <65000000>;
			hactive = <960>; //800
			vactive = <1080>; // 1280
			hsync-len = <10>;   //8//20, 50
			hback-porch = <0>;  //8//50, 56
			hfront-porch = <95>;//32//50, 30 //1580
			vsync-len = <10>; //4
			vback-porch = <0>; //11
			vfront-porch = <20>; //17
			hsync-active = <0>;
			vsync-active = <0>;
			de-active = <0>;
			pixelclk-active = <0>;
			swap-rb = <0>;
			swap-rg = <0>;
			swap-gb = <0>;
Nothing wasn’t change when I try use different bus-format:s. I look that my display use VESA standard.
And how I tell config that I use two channel LVDS?
What about panel-init-sequence? I dont find any detail for that in display manual?
Link for manual: http://www.display-solution.com/pdf/tft-displays/AUO/AUO_G156HTN02.0_20160418.pdf
Thanks.
Pekka
peksuj Posted at 6/11/2018 18:20
Hi,
This display match attached file.rk3399-firefly-aio-lvds-Dual.rar (3.59 KB)
Hi,
Thanks for that file. I get error when compiling that: “rk3399-firefly-port.dtsi: No such file or directory”. I l
search that in kernel from github but didnt find it. Can I use some other dtsi file?
I try to test changing include files, more errors. Try to use &dsi section to old lvds file but problems with lcd pins…
I think we are very close to success :slight_smile:
Thanks,
Pekka
I also try use “screen-type = <SCREEN_DUAL_MIPI>;” wich I found in kernel/Documentation/devicetree/bindings/video/rockchip_mipidsi_lcd.txt. But get error for that instance…
I use Your sending dts &dsi section and add to &pinctrl section “lcd_panel_pwr_en” function. It now compile but only single LVDS and no picture in display and trying to make two views in display.
I think that I need go back to Raspberry Pi… I use now about 100 hour and three week only trying to get dual LVDS port to work…
Pekka
Hi,
How I can get second LVDS channel to work? I cant get there any signals. I look output with osciloscope and I find signals in first channel but nothing in second channel.
Thanks,
Pekka
Die Ausbildungsmaterialien zur GIAC GCIH Zertifizierungsprüfung aus ExamFragen sind nicht nur der Grundstein auf dem Weg zu Ihrem Erfolg, sie können Ihnen auch dabei helfen, Ihre Fähigkeiten in der IT-Branche effektiver zu entfalten. Nach mehrjährigen Bemühungen beträgt die Hit-Rate von GIAC GCIH Zertifizierungsprüfung von ExamFragen bereits 100%. Wenn Sie die Zertifizierungsprüfung nicht bestehen, nachdem Sie unsere Fragenpool gekauft haben, werden wir alle Ihre bezahlten Summe zurückgeben.
VCESoft 提供下載的 Splunk 的 SPLK-4001 證照考試的問題範例,使你購買無風險的過程,這是一個使用版的練習題,讓你看得到考題的問題和答案的品質,以及在你決定購買之前的價值,相信 Splunk 的 SPLK-4001 證照考試的樣品足以定性,成為眾多考生滿意的產品。該考題還包括PDF格式和模擬考試測試版本兩種,你可以根據自己的情況去選擇適合自己的。
