EMMC booting issues
Had the ROC now for about 2 months.. just got the emmc from libre.. using the flashing tool for windows using type A to type A usb cable.. I am able to see it as Maskrom.. and only Maskrom (wont change to anything else no matter how long I press that button).. installed the 05-14-2018 new Ubuntu image (btw was a real hassle to download, download connections droped a lot) and even older images.. Everyting installs ok..
Download Boot Start
Download Boot Success
Wait for Maskrom Start
Wait for Maskrom Success
Download Roc-RK33XXXXXXXXXXXXXX-20180514.IMG
Download image OK
When I go to boot from eMMC the thing just sits there.. Red and green light are on instead of (RED)..
When I boot with SD card it works perfectly.. and I can see the emmc partitions when I boot into Ubuntu..
I haven’t had any luck booting just with the eMMC..
btw using all windows tools.. etcher for SD and Android tool for non android for emmc..
Anybody has any clues whats going on??
You could try this https://github.com/armbian/config. You can add it to your OS but, you will need the dependencies (you will need to find working ones or add ppas) If that’s too complicated. It’s built into Armbian. You boot OS on SD. Then Run Armbianconfig. You can install to USB3 or EMMC. I’m using a HD dock/hub. It’s fast but, the OS is still in development, as are all the OS’s. Itried USB3 memory stick too (get one with heat synks and no case it gets hot!!!). Way faster than EMMC It uses the SD for the boot record then boots the OS.from where you moved it too.
It will be a while until you can get a supported OS. Donations to Firefly or your preferred OS could help speed things along. I’m just waiting patently like you. I have no connection to anyone. I just own the board lol
多くの人はICF-ACC試験は難しいと思っています。しかし、ICF-ACC試験参考書を持たれば、自分の努力に加えて、きっとICF-ACC試験に合格できます。ICF-ACC試験参考書について、もっと詳しいことを知りたい場合、ICF会社のウエブサイトを訪問して頂きます。
Can’t get enough of this content, definitely liking it. The Latest exam DCPLA questions answers was the key to my promotion and raise. Now it’s free to everyone. Wishing you all a successful career boost!
NSE7_SSE_AD-25試験に参加する前に、試験を知りたい場合、弊社の公式サイトを訪問できます。そして、弊社のNSE7_SSE_AD-25試験ガイドのデモをダウンロードすることは簡単で、便利です。クリックするだけ必要からです。後、弊社のNSE7_SSE_AD-25資料はすべてNSE7_SSE_AD-25試験に関わることがわかります。NSE7_SSE_AD-25資料の全てのページはNSE7_SSE_AD-25試験に関連しています。NSE7_SSE_AD-25資料は素晴らしいものです。
Wenn Sie die ZertSoft Website klicken, wundern Sie sich vielleicht, dass viele Leute jedentag ZertSoft besuchen. Das ist ganz normal. Wir bieten den Kandidaten zahlreiche Schulungsunterlagen, mit denen sie die Fortinet FCSS_EFW_AD-7.6 Prüfung bestehen können. Das heißt, dass die Schulungsunterlagen wirklich wirksam sind. Wenn Sie die Fortinet FCSS_EFW_AD-7.6 Fragenkatalog kaufen wollen, verpassen Sie ZertSoft nicht. Und Sie werden sicher mit unseren Produkten zufrieden.
Your article was so unique, thank you for sharing this fresh perspective. This Valid Databricks-Certified-Data-Engineer-Associate test collection sheet was instrumental in my promotion and pay raise. It’s now free to everyone. Wishing you success in your promotions!
