Changing Kernel version in Linux
Hi everyone,
I just bought a RK-3399, I installed the Firefly-RK3399-ubuntu16.04-20180416112819.img on it. I want to use it with a Intel Realsense camera 415. My first issue is the kernel version, because the installation script of the camera use: uname -r. Thus when I typed uname -r in the firefly ubuntu the outcome is:
4.4.77
but sadly under that kernel number there are not installed packages in /usr/src where the scripts is looking for some stuffs. However, there is all what is needed under the kernel version 4.4.0-128-generic but I dont know how to change to that kernel version because in firefly ubuntu does not work grub.
I hacked the uname program to give all the results that I want but at the end of the compilation of realsense library fails and I tired of patching this in a hacky way when the solution should be simple.
Does someone know how to change the kernel version in firefly linux?
Regards,
Felipe
And /boot directory is empty and gpardet is not recognizing the emmc partition disk format.
With the latest ubuntu 18.04 firmware for Firefly-RK3399, the partition layout will change
from the non-standard scheme of rknand= in parameter.txt to standard gpt.
This article is absolutely brilliant, thank you for sharing. I was promoted and received a raise with the help of the Valid exam L6M3 objectives pdf. Now it’s available for free to all. Best wishes for your promotions!
Fast2test의 제품들은 모두 우리만의 거대한IT업계엘리트들로 이루어진 그룹 즉 관련업계예서 권위가 있는 전문가들이 자기만의 지식과 지금까지의 경험으로 최고의 IT인증관련자료를 만들어냅니다. Fast2test의 문제와 답은 정확도 적중률이 아주 높습니다. 우리의 덤프로 완벽한Microsoft인증SC-100-KR시험대비를 하시면 되겠습니다. 이렇게 어려운 시험은 우리Microsoft인증SC-100-KR덤프로 여러분의 고민과 꿈을 한방에 해결해드립니다.
Wenn Sie sich noch anstrengend um die Oracle N16300GC10 Zertifizierungsprüfung bemühen, dann haben Sie einen großen Fehler gemacht. Durch fleißiges Lernen können Sie sicher die Prüfung bestehen. Aber Sie können vielleicht das erwartete Ziel vielleicht nicht erreichen. Im Zeitalter des Internets gibt es zahlreiche erfolgreiche IT-Zertifizierungen. Die Schulungsunterlagen zur Oracle N16300GC10 Zertifizierungsprüfung von ZertFragen sind sehr gut. Sie sind zielgerichtet und verprechen Ihnen, die Oracle N16300GC10 Prüfung 100% zu bestehen. Diese Schulungsunterlagen sind nicht nur rational, sondern können viel Zeit ersparen. Sie können mit der ersparten Zeit etwas anderes lernen. So können Sie bessere Resultate bei weniger Einsatz erzielen.
CDT学習クイズの合格率は99%で、CDT実践ガイドは高いヒット率を高めます。当社のCDTテストトレントは専門家によって編集され、Construction Specifications Institute提供される回答と質問は実際の試験に基づいています。CDT試験問題の内容は、理解して習得するのが簡単です。試験の準備を万全にするために、当社のソフトウェアは、実際の試験を刺激する機能と、速度の調整に役立つタイミング機能を提供します。CDTガイド急流のこれらのメリットに基づいて、CDT試験に高い確率で合格できます。
Such an amazing article, I appreciate your generosity in sharing it. The D-AV-DY-23 valid test camp pdf test played a pivotal role in my promotion and pay raise—get it for free today!
