Ubuntu 16.04 - One Wire testing
We are missing a particular library
firefly@firefly:~$ modprobe wire
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file ‘/lib/modules/4.4.77/modules.dep.bin’
modprobe: FATAL: Module wire not found in directory /lib/modules/4.4.77
I know that firefly has HIGHLY customised their kernel to fill there needs, and there are many bits that can be missing depending on what you need to do. As a baseline system, it is wonderful, but push it a little, and if falls down in many ways.
We really don’t want to get into customised building of the kernel if we don’t have to.
Any suggestions anyone?
Hi,
I have a similar problem tryong to use iptables:
modprobe iptables
modprobe: FATAL: Module iptables not found in directory /lib/modules/4.4.77
I’m using 8 firfly RK3399 to buil a HPC cluster managed with SLURM. One of the card is used as NAT server. With a previous version I was able to complete my task, but with Firefly-RK3399-ubuntu16.04-20180416112819.img and some other found going aroud in internet I’m not able to complete my task.
Has someone suggestions on how to solve this issue?
Hi, sara.bertocco. It is interesting to hear that you build the HPC cluster
using the Firefly-RK3399.
It seems that there’re no kernel module files installed to the rootfs.
I suggest that you build the kernel, adding missing module as builtin,
and flash the new kernel to the board.
當我們第一次開始提供NCARB的Project-Planning-Design考試的問題及答案和考試模擬器,我們做夢也沒有想到,我們將做出的聲譽,我們現在要做的是我們難以置信的擔保形式,Testpdf的擔保,你會把你的NCARB的Project-Planning-Design考試用來嘗試我們NCARB的Project-Planning-Design培訓產品之一,這是正確的,合格率100%,我們能保證你的結果。
