Error -110 whilst initializing SD card
Just received my Renegade board. Nice little piece of kit but I can’t say I’m impressed with the online instructions and resources. The preferred SD flashing utility is, contrary to what’s stated, available for Windows only. Etcher works fine on my Mac but the downloaded disk image is not recognized. Adding an “.img” extension allows Etcher to proceed but who knows if that is the right thing to do. In any case, I get a consistent Error -110 during the boot process and then the thing hangs. This has occurred with a fresh SanDisk 32Gb SD card, a known-good 32Gb card from a Raspberry Pi, and a second known-good 8Gb card from a Raspberry Pi.
So I’m stuck. Any suggestions?
I really appreciate your work, it left a profound impact on me. The C_ARCON_2508 latest test cram materials exam is almost here. Hope I ace it!
발달한 네트웨크 시대에 인터넷에 검색하면 많은HP인증 HPE7-A03시험공부자료가 검색되어 어느 자료로 시험준비를 해야 할지 망서이게 됩니다. 이 글을 보는 순간 다른 공부자료는 잊고ExamPassdump의HP인증 HPE7-A03시험준비 덤프를 주목하세요. 최강 IT전문가팀이 가장 최근의HP인증 HPE7-A03 실제시험 문제를 연구하여 만든HP인증 HPE7-A03덤프는 기출문제와 예상문제의 모음 공부자료입니다. ExamPassdump의HP인증 HPE7-A03덤프만 공부하면 시험패스의 높은 산을 넘을수 있습니다.
Your article is powerful, thank you for sharing! This is the Online Virginia-Life-Annuities-and-Health-Insurance bootcamps test that helped me achieve a promotion and raise. It’s available to you for free today, and I wish you success in reaching your career goals.
