@Kenn, As mentioned by @slaeyer, v1.2.7 seems to be available only for RK339. The SDInstaller tool also does not show v1.2.7 for RK3328. Pls confirm whether RK339 image can also be used for RK3328. Thank you.
slaeyer Posted at 7/27/2018 00:07
The link provided for the RK3328 board is the same as the RK3399 image, will this image work on an R …
Hello, Station OS for ROC-RK3328-CC v1.27 has been released, because the development of Station OS is based on Firefly-RK3399, so the release of Station OS for ROC-RK3328-CC will be a little later.
@Kenn, I ran into these blocker issues with v1.2.7 that did not let me proceed:
The system would not recognize my external Hard disk. I tried with both Seagate as well as WD 2TB HDD (does not have external power) connected to the USB 3.0 port. Due to this I could not try actually playing any media.
HDMI-CEC feature is not implemented in the Android core. Due to this, the TV remote cannot be used to interact with the Station OS. Had to test with USB mouse but this is not a usable option for me as I sit far away from the TV and Renegade box.
Kodi, even in Expert mode, does not support audio pass-through. So I doubt that, even if I manage to play some media, Atmos 7.1 audio will be supported.
So, overall, I was not able to use this build as a Media Center (and I am not into Retro gaming). I will look out for fixes for above mentioned issues in the ‘Update Notes’ of upcoming builds. Thanks!
The content of this article has been very helpful to my personal growth. Free NCP-US exam pass4sure test papers for everyone—promotions and salary raises await!
