Update:1. Update AOSP android-8.1.0_r33
2. Fix mouse click problem
3. Optimize system and fix some bug.
4. Support mipi-csi ov13850
5. Support spdif output.
Pls erase the flash first , reboot the board and then flash image
downloaded the last firmware available, that is Firefly-RK3399_Android8.1.0_HDMI_181023.img,
and the update tool v1.31 for android 8 ('ive also tried the v1.34).
rebooted into “loader” mode bu pressing power, and holding recovery button for 3 sec.
run “./upgrade_tool uf ../../Firefly-RK3399_Android8.1.0_HDMI_181023.img” as a super user
expected - flashed firmware
real - system pass “Test Device Start” and “Test Device Successful”, and then halt at “Check Chip Start” for at least 30 minutes.
also upgrade_tool EF, hangs for a long time, bat has no effect.
What is the right way to update to the last firmware ?
before you install, remove the old firmware with the OLD update_tool (the same used to install, update_tool 1.24 in my case)
after that you can install the new firmware with the new android 8 tool
I’m grateful for your article, it truly made an impact on me. Sharing the Frenquent Data-Engineer-Associate update exam that got me my promotion and salary raise—it’s free for all today. Hope you all achieve your professional dreams!
